coq-club - Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Commands/Tools for Debugging Universe Inconsistency?
  • Date: Fri, 10 Apr 2020 11:12:26 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=liyao AT seas.upenn.edu; spf=Pass smtp.mailfrom=liyao AT seas.upenn.edu; spf=None smtp.helo=postmaster AT mail-qt1-f195.google.com
  • Ironport-phdr: 9a23:oTG5vBMGAruP66KDrS4l6mtUPXoX/o7sNwtQ0KIMzox0K/n7rarrMEGX3/hxlliBBdydsK0UzbeO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6a8TWO6msZHQy6Pg5oLMz0HJTThoK5zbOc4ZrWNjRBg3KZYPsmKBSnpAL5rcQfms1/Mqs3zF3ErmYeKLce/n9hOV/Gx0W03cy35pM2q30B6cJkzNZJVODBR4p9SLVZCDo8NGVsup/wuBDYCxaX630aFGgaj0gRWlWX3FTBRp709xDCmK991S2dZ5OkSLk1XXG78/4uRka51WEIMDk29GyRgct13voC/ECR4idnyouRW7m7ceJkd/qDL8gXTHEHQ95cUSoHD4+hPdMC
And another question I have is: are there some principles on when to name a
universe? If I am designing a library, what are the things I should consider
for when I should name a universe and when I should not?
Best,
Yao
> On Apr 10, 2020, at 11:09 AM, Yao Li
> <liyao AT seas.upenn.edu>
> wrote:
> I see. That makes sense.
> However, I am getting Foo.2 from a library. Any way to bind it to a stable
> universe outside the library?
> Another question is what are the cases that Coq >= 8.10 will automatically
> name universes? When the codebase is large, naming many universes manually
> would be painful...
> Best,
> Yao
>> On Apr 10, 2020, at 10:57 AM, Gaëtan Gilbert
>> <gaetan.gilbert AT skyskimmer.net>
>> wrote:
>> The Foo.number universes are unstable (for instance the number changes if
>> you backtrack and rerun the command which generated the universe) so you
>> can't put them into a script.
>> Instead you have to ensure they get a name when created (so eg if you have
>> Definition foo := Type. (* produces Type@{Foo.123} *)
>> you can replace it by
>> Universe foo_univ.
>> Definition foo := Type@{foo_univ}.
>> Coq >=8.10 will automatically name universes in some cases (for instance
>> the above example actually uses the name "foo.u0" not "Foo.123").
>> Gaëtan Gilbert
>> On 10/04/2020 17:42, Yao Li wrote:
>>> Hi Christian,
>>> Thanks for the pointers! They are helpful. In particular, I find your
>>> suggestion of using the “Constraint” command quite useful. I would like
>>> to reiterate that suggestion here:
>>>> - once one has located the spot where needlessly strong constraints
>>>> (usually
>>>> U = V for some U and V) are enforced, one can precede said
>>>> lemma/definition
>>>> with a "Contraint" command ruling out the equality (e.g., Contraint U <
>>>> V) to
>>>> force backtracking within the definition/lemma. Afterwards, the desired
>>>> parallel structure can be reestablished.
>>> However, I have universe variables whose names are in the form of
>>> “Foo.2”, which cannot be parsed by Coq, even under “Constraint” command
>>> (Coq would complain:"Error: Syntax Error: Lexer: Undefined token”). This
>>> prevents me from putting any constraints regarding “Foo.2”. Is this a bug
>>> or did I miss something?
>>> Best,
>>> Yao
>>>> On Apr 10, 2020, at 3:30 AM, Christian Doczkal
>>>> <christian.doczkal AT inria.fr
>>>> <mailto:christian.doczkal AT inria.fr>>
>>>> wrote:
>>>> Hi,
>>>> the subject has been discussed on this list before, and I am not aware
>>>> of any tooling advances made since then. The two treads I have been
>>>> involved in are:
>>>> https://sympa.inria.fr/sympa/arc/coq-club/2018-09/msg00008.html
>>>> https://sympa.inria.fr/sympa/arc/coq-club/2019-11/msg00087.html
>>>> I hope this helps!
>>>> Best,
>>>> Christian
>>>> On 4/10/20 1:14 AM, Yao Li wrote:
>>>>> Dear All,
>>>>> I am having some recurring universe inconsistency problems lately and I
>>>>> would like to know if there are any commands/tools for helping me
>>>>> debugging what happened.
>>>>> For example, a recurring pattern is that Coq complains to me that it
>>>>> cannot unify two universe levels (assuming they are u1 and u4) because
>>>>> “u1 <= u2 < u3 <= u4” or “u1 <= u2 < u3 = u4”. I would like to know
>>>>> where the constraints concerning u3 and u4 (and perhaps other relevant
>>>>> constraints as well) are generated—or better yet, why. However, I
>>>>> haven’t found a tool for doing that.
>>>>> I have tried “Set Printing Universes”. Unfortunately, the constraints
>>>>> concerning u3 and u4 cannot be found at any relevant definitions. I
>>>>> have also tried “Print Universes”, but I cannot find what I’m looking
>>>>> for in the sea of constraints that Coq shows me.
>>>>> Best,
>>>>> Yao
