- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Silly question about decidable equality and inequality
- Date: Wed, 24 Jun 2020 09:06:08 +0200
Le 24/06/2020 à 07:30, Gabriel Scherer a écrit :
> On the other hand, you could define a "smaller" type of inequivalence
> for a type (as an inductive presentation if you can, for example) that
> has better properties. This comes up often in cases where you need to
> reason on elements being equal, as the definition of inequivalence as a
> function makes it hard to reason about.
> For natural numbers for example, one definition of inequivalence might
> be something like
> Inductive different :=
> | Bigger : forall (k : nat), m = n + S k -> different m n
> | Smaller : forall (k : nat), m + S k = n -> different m n.
If one is going the way of representing disequalities by equalities to
ensure uniqueness of proofs, then the boolean encoding seems a bit simpler:
Definition different m n := Nat.eqb m n = false.
Best regards,
Guillaume
- [Coq-Club] Silly question about decidable equality and inequality, Talia Ringer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Jason Gross, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Gabriel Scherer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Talia Ringer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Xavier Leroy, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Thorsten Altenkirch, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Dominique Larchey-Wendling, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Guillaume Allais, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Yannick Forster, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Guillaume Melquiond, 06/24/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Silly question about decidable equality and inequality, Pierre-Marie Pédrot, 06/25/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Bob Atkey, 06/25/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Thorsten Altenkirch, 06/25/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Pierre-Marie Pédrot, 06/26/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Ambrus Kaposi, 06/24/2020
