- From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Silly question about decidable equality and inequality
- Date: Wed, 24 Jun 2020 09:06:45 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout01-ext4.partage.renater.fr
On Wed, Jun 24, 2020 at 8:52 AM Talia Ringer <tringer AT cs.washington.edu> wrote:
Thanks, that is very helpful! Part of the motivation for this was trying to understand why I find it more difficult to reason about { n : nat | n <> 0 } than I do about the inductive positives. It seems like it may be easier to reason about a different refinement of nats.
Right. There are many other ways to write this subset type that behave well w.r.t. equality:
{ n : nat | Nat.eqb n 0 = false }
{ n : nat | 0 < n } (* I believe that Nat.le and Nat.lt have unique proofs *)
{ n : nat | match n with O => False | S _ => True end }
etc.
- Xavier Leroy
(This is not for personal proving purposes, just academic curiosity.)On Tue, Jun 23, 2020, 10:31 PM Gabriel Scherer <gabriel.scherer AT gmail.com> wrote:Pierre-Marie's typical example defines (A -> B) in the guest type theory as (bool * (A -> B)) in the host theory, with a type-preserving translation, and (=) in the guest as just (=) in the host. For any function you can get another distinct (but observably equivalent in the guest) function by flipping the boolean. This also applies if B is False.On the other hand, you could define a "smaller" type of inequivalence for a type (as an inductive presentation if you can, for example) that has better properties. This comes up often in cases where you need to reason on elements being equal, as the definition of inequivalence as a function makes it hard to reason about.For natural numbers for example, one definition of inequivalence might be something likeInductive different :=| Bigger : forall (k : nat), m = n + S k -> different m n| Smaller : forall (k : nat), m + S k = n -> different m n.and this one should inherit contractibility from equality.On Wed, Jun 24, 2020 at 6:12 AM Jason Gross <jasongross9 AT gmail.com> wrote:As I understand it, with funext, you can prove irrelevance for all proofs of x <> y of any type (because False is an hProp). However, without funext, you can't really prove anything about equality of most function spaces (just like without K nor univalence, you can't really prove anything about equality of most types). (I think there's actually a deeper relationship here, probably along the same lines of how univalence implies funext. I don't understand it fully myself, but I believe Dan Licata has a blog post on how knowing about equality in a universe gives you things about equality of functions between types in that universe.). In general, I think all you can say is that if you can prove that `A -> B` is isomorphic to some non-arrow-type `C` when you assume funext, then you can probably embed `C` into `A -> B` even without funext. So you can lower-bound the number of distinct functions of a given type, but you can't upper-bound it without funext in general. (Exception: you can upper-bound the number of functions from `A -> B` when `A` is inhabited and `B` is not; the upper-bound is 0.)I believe Pierre-Marie Pedrot has some models of type-theory (or pointers to them) which contradict funext. I'm not sure whether or not any of them allow for multiple proofs of `A -> False`, though I could believe that they might.-JasonOn Tue, Jun 23, 2020, 22:25 Talia Ringer <tringer AT cs.washington.edu> wrote:Hi all,I think this should be obvious, but I'm having trouble thinking right now. I figure I'll ask in case somebody knows the answer.Suppose I have a type with decidable equality, like nat. Then provably I have that all proofs of n = m for n m : nat are equal to each other, without assuming UIP as an axiom. That much I know.From this, can I say anything about proofs of n <> m for n m : nat without assuming functional extensionality? For example, are all proofs of 0 <> 1 equal to each other? If not, are they provably related in any interesting way?Talia
- [Coq-Club] Silly question about decidable equality and inequality, Talia Ringer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Jason Gross, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Gabriel Scherer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Talia Ringer, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Xavier Leroy, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Thorsten Altenkirch, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Dominique Larchey-Wendling, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Guillaume Allais, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Yannick Forster, 06/24/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Guillaume Melquiond, 06/24/2020
- <Possible follow-up(s)>
- Re: [Coq-Club] Silly question about decidable equality and inequality, Pierre-Marie Pédrot, 06/25/2020
- Re: [Coq-Club] Silly question about decidable equality and inequality, Bob Atkey, 06/25/2020
