Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions
- Date: Wed, 8 Jul 2020 23:00:16 +0200
On 7/8/20 10:37 PM, Agnishom Chattopadhyay wrote:
> Does loading ssreflect change the standard behaviour of tacticals like
> in/by/with/etc? This is a problem since a large part of my proof script
> uses things like rewrite H in H0.
yes it does, it is explained in
https://coq.inria.fr/distrib/current/refman/proof-engine/ssreflect-proof-language.html
in particular rewrite has a slighy different semantics
but has some extra capability like a powerful pattern selection.
If you want to do use the standard rewrite, just add <- in front the
first theorem. So rewrite ->H in H0 should work.
Laurent
- [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Agnishom Chattopadhyay, 07/08/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Laurent Thery, 07/08/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Erik Martin-Dorel, 07/08/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Agnishom Chattopadhyay, 07/08/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Agnishom Chattopadhyay, 07/09/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Laurent Thery, 07/09/2020
- Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions, Kyle Stemen, 07/09/2020
