coq-club - Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Rewriting inside map expressions to manipulate finite/indexed sum expessions
  • Date: Thu, 9 Jul 2020 01:48:54 +0200
Hi,
I am not sure I follow everything but it seems that in your particular
example you could use Nat.min_0_r.
More generally if you look at the documentation of under you can
handle binders :
https://coq.inria.fr/distrib/current/refman/proof-engine/ssreflect-proof-language.html
For example, interactively this gives:
From mathcomp Require Import ssreflect.
Require Import List PeanoNat.
Goal forall l, (map (fun i => i + 1) l) = l.
Proof.
move=> l.
under map_ext => i.
replace (i + 1) with (1 + i); last first.
by rewrite Nat.add_comm.
over.
Hope this helps
Laurent
