- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How can I extract data from this exists Prop?
- Date: Thu, 27 Aug 2020 00:29:48 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=Pass smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT se22-yh-out3.route25.eu
- Ironport-phdr: 9a23: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
You may be able to do that, but that sounds rather adhoc/specialized.
Again, I think the point is that *if* you are in the fortunate situation that you are dealing with lists of countable types, you can get this for free from very generic infrastructure from extracting witnesses from existentials in libraries like ssreflect or std++. The point is not that such libraries give the most general theorem for free.
If you are not in that fortunate situation, or you want to obtain the most general theorem, then well, you have to construct the witness in some other way, for example using your proof.
On 27/08/2020 00.22, jonikelee AT gmail.com wrote:
On Thu, 27 Aug 2020 00:03:18 +0200
Robbert Krebbers <mailinglists AT robbertkrebbers.nl> wrote:
I think the point of Emilio's message was that with countability you
can get the proof for free, and no proof effort is needed. I don't
think his point was that the countability stuff is truly needed.
If so, can't one set up some typeclasses (or canonical structures) so
that left inverses, when registered, get found and used automatically?
That still would not add requirements to A or require decidable
equality.
Emilio can probably correct me if I'm getting this wrong.
On 26/08/2020 23.30, Arthur Azevedo de Amorim wrote:
That is a good point. It actually follows because (x ++) has a left
inverse: drop (length x). We don't even need the existence proof to
extract the witness!
On Wed, Aug 26, 2020 at 5:16 PM jonikelee AT gmail.com
<jonikelee AT gmail.com> wrote:
It turns out that no assumptions about the countability of list
element's type is necessary, nor does one have to use a decidable
equality:
Require Export Coq.Lists.List.
Import ListNotations.
Definition isPrefixOf{A} (x y : list A) :=
exists z, x ++ z = y. (*note: plain Leibniz = here*)
Definition extract : forall {A}{y x : list A}(P : isPrefixOf x y),
{z | x ++ z = y}. Proof.
intro A. induction y. all:intros x P.
- exists []. destruct P as (z & E). rewrite app_nil_r. apply
app_eq_nil in E. tauto.
- destruct x as [|b x].
{ exists (a::y). reflexivity. }
enough (a=b /\ isPrefixOf x y) as (e & Q).
{ specialize (IHy x Q) as (z & f). exists z. cbn. congruence.
} destruct P as (z & E). cbn in E. injection E. intros H1 H2.
split.
+ congruence.
+ exists z. exact H1.
Defined.
On Tue, 25 Aug 2020 16:31:10 -0400
"jonikelee AT gmail.com" <jonikelee AT gmail.com> wrote:
Oh - sorry, it wasn't intended to be off-list. Thanks for the
detailed explanation.
On Tue, 25 Aug 2020 20:58:12 +0200
Not sure if this was intended to be off-list.
It's like that, but more complicated for the general case. Since
bool is finite, termination is trivial. For types are are
countable, not non-finite, (take p : nat → bool) you need to
find a suitable termination measure.
On 8/25/20 8:54 PM, jonikelee AT gmail.com wrote:
On Tue, 25 Aug 2020 20:37:47 +0200
The mentioned proof makes use of the following theorem:
(∃ x : A, P x) → { x : A | P x }
under the assumption that 1.) A is countable, and 2.) the
predicate is decidable.
I see. I missed that there was a double "==" in isPrefixOf. Ok,
so this is just something like:
Definition extract{P : bool -> bool}(e : exists b, P b = true) :
{b | P b = true}. Proof.
assert bool as b by constructor.
destruct (P b) eqn:E.
- exists b. exact E.
- destruct (P (negb b)) eqn:E2.
+ exists (negb b). exact E2.
+ exfalso. destruct e as (b' & F), b, b'.
all:cbn in *. all:congruence.
Defined.
OK - not as magical as I thought. Thanks.
This theorem holds intuitively because you can write an
algorithm that searches for the witness. Because A is
countable, it can simply enumerate all elements. Then, because
P is decidable, it can test for each element if P holds or
not. Now, since (∃ x : A, P x) holds, this algorithm will
terminate, i.e. finally find a witness.
The Coq standard library also includes a version of this
theorem, see
https://coq.inria.fr/distrib/current/stdlib/Coq.Logic.ConstructiveEpsilon.html
Also std++ includes a version of this theorem, see
https://gitlab.mpi-sws.org/iris/stdpp/-/blob/master/theories/countable.v#L84
choiceType in ssreflect (or the Countable type class in std++)
expresses that a type is countable, and is used to
automatically infer assumption (1) in the above theorem.
Hope this helps!
On 8/25/20 8:27 PM, jonikelee AT gmail.com wrote:
Can someone explain to a non-ssreflect/non-mathcomp user how
choiceType works? It looks like it must rely on an axiom.
Are there any types that fulfill it? For example, is there a
non-axiomatic way in which bool is a choiceType?
Because, the ability to pull the necessary x out of "exists
x, P x" seems magical. How would a program using this
extract?
On Tue, 25 Aug 2020 19:15:14 +0200
Emilio Jesús Gallego Arias <e AT x80.org> wrote:
Hi Agnishom,
Agnishom Chattopadhyay <agnishom AT cmi.ac.in> writes:
I have a function that is something like this:
Definition isPrefixOf (x : list A) (y : list A) :=
Now, I want to define a witness function. Informally, it can
be described as follows: Given x and y such that (isPrefixOf
x y), return z which satisfies the criteria exists z, x ++ z
= y.
I would try to define it this way, but that would not work
(possibly because exists z, x ++ z = y is a Prop and we are
asking for something in Type) :
Definition witness (x y : list A) {H : isPrefixOf x y} :
list A. destruct H.
Abort.
If you can afford to work with a type A which has a notion of
choice principle you can indeed write your witness function.
Example:
From mathcomp Require Import all_ssreflect.
Set Implicit Arguments.
Unset Strict Implicit.
Unset Printing Implicit Defensive.
Variable (A : choiceType).
exists z, x ++ z == y.
Definition extract x y (w : isPrefixOf x y) : list A :=
xchoose w.
Kind regards,
Emilio
- Re: [Coq-Club] How can I extract data from this exists Prop?, (continued)
- Re: [Coq-Club] How can I extract data from this exists Prop?, Agnishom Chattopadhyay, 08/10/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Emilio Jesús Gallego Arias, 08/25/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Agnishom Chattopadhyay, 08/25/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, jonikelee AT gmail.com, 08/25/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Robbert Krebbers, 08/25/2020
- Message not available
- Re: [Coq-Club] How can I extract data from this exists Prop?, jonikelee AT gmail.com, 08/26/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Arthur Azevedo de Amorim, 08/26/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Robbert Krebbers, 08/27/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, jonikelee AT gmail.com, 08/27/2020
- Re: [Coq-Club] How can I extract data from this exists Prop?, Clément Pit-Claudel, 08/27/2020
