coq-club - Re: [Coq-Club] Showing proof of type ~(P -> Q)?
  • From: Daniel Kuhse <daniel.kuhse AT tu-dortmund.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Showing proof of type ~(P -> Q)?
  • Date: Sat, 19 Sep 2020 05:42:22 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=daniel.kuhse AT tu-dortmund.de; spf=Pass smtp.mailfrom=daniel.kuhse AT tu-dortmund.de; spf=None smtp.helo=postmaster AT unimail.uni-dortmund.de
  • Ironport-phdr: 9a23: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
 I don't think there is generally any real way around proving the statement directly (i.e. proving that for all a b, both P and ~Q hold).
By the way, is it true that if I prove ex3: forall a b, P -> ~Q, then from ex3, I can prove ex?
Counterexample: Assume for all a b, ~P holds, then ex3 holds, but not ex since both P->~Q and P-> Q hold due to ~P
Daniel Kuhse
Am Sa., 19. Sept. 2020 um 04:39 Uhr schrieb Kumar, Ashish <azk640 AT psu.edu>:
Actually I do have to show theorem ex (i.e. theorem ex is correct).
But, your answer makes me realize that my informal proof was incorrect. Any ideas?
With regards,
Ashish
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Donald Sebastian Leung <donaldsebleung AT gmail.com>
Sent: Friday, September 18, 2020 10:31 PM
To: coq-club AT inria.fr <coq-club AT inria.fr>
I think you might be confusing the following two propositions:
- It is not the case that P -> Q for any a, b (ex : ~ (forall (a b : A), P -> Q))
- For any given pair of values a, b, P -> Q is decidedly false (ex : forall (a b : A), ~(P -> Q))
The informal proof you gave would work for the former example while you are asking for a proof of the latter example.
~ Donald
Kumar, Ashish <azk640 AT psu.edu> 於 2020年9月19日 週六 上午9:44寫道:
Suppose I have a theorem of the form:
Theorem ex: forall (a b: A), ~(P -> Q).
(where A has type 'Type' defined earlier, and a and b are used in the propositions P and Q.)
How do I go about proving this?
I realize that an informal proof for this would involve me showing there exists some value a and b, where P holds but Q does not hold i.e. informally, I would be proving the lemma ex2: exists (a b: A), P /\ ~Q. How can I prove ex2 from ex1 in Coq??
With regards,
Ashsih
