- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] implicit arguments
- Date: Thu, 10 Dec 2020 14:46:21 +1100
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=tDgZ6TUTSg0m8XgZpTYZTm/C3RgI6g272NYnOCfzZ7k=; b=Ig1lLERpK1eoUoGxaNmdpLUW97HrHtcXcG1XDN25zIR5xw7q51dp8uQR9yIcYLmScA8SNL10qWoysy0pwn0o+Pk0s4jpO/yTAxLXA96Cwkl9+izymSFdwYpZohLDUPFSL0pLd91nXoEfHF+qNRLifAYVNwUOyRl6AHd8LFSHh8IWCTWyeV0xfkdnK3CVm1SS+OhFq15bHO/Ho3TObyXh7EazlXUOJv9IygOGRnoX67n4mREshp1CyDuZXQ4Qb+8vCOy/cqu9Iejc9K3SMZDvrvee/nyHf9Gh3zpxragBwDcCHx1rDdInN03swuYArW94Mtmu2SLtl0eh4WRPBgNcEw==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=PZ/CAofhH+nknrvI0D0WMHihMgAA7MNahEYe8txTUrWvJRaYktTZ/tHRJby/xsTl/e051QZvLhXtY1Hc32FbAo4ZF1hm+1//2HtbAP48TjTw/WWiwdvRJcK5wltA3u4KrHPiKMPSuKR+Ooi4gsFuEYez94sp46lFI5BCYbY7B3sSPXAbHJhkUHrwLmtp+B98U+DmmM4Bzq98Su1qfJTHlSzThY/FWuqv95tdHH+xOkRCQxbgdyKi2yLETioL2BMpIa22EOEQgzVIW+OhqKGuswjU8Fp+T0TrRiDCACJVwXPvgDQE5LS2d3DaC19jBbxzKG+JB42DOF+UGhAn9+N6Dw==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi,
I have tried to find out when implicit arguments are inserted. Is this in the documentation anywhere?
With a function
lja_dd_ord < About no_rpt_same.
no_rpt_same :
forall U : Type,
relationT U ->
forall (rules : list U -> U -> Type) (prems : U -> Type) (c0 : U),
derrec rules prems c0 -> Type
Arguments U, rules, prems, c0 are implicit
I find
lja_dd_ord < Check no_rpt_same seq_ord.
no_rpt_same seq_ord
: forall (rules : list (srseq (PropF ?V)) -> srseq (PropF ?V) -> Type)
(prems0 : srseq (PropF ?V) -> Type) (c0 : srseq (PropF ?V)),
derrec rules prems0 c0 -> Type
which is as I expected (as a matter of fact, I can't find this documented either, but I've discovered from experience that implicit arguments (non-maximal) are inserted up to the last explicit argument)
but
lja_dd_ord < Check no_rpt_same seq_ord (prems:=prems).
: forall c0 : srseq (PropF V), derrec ?rules prems c0 -> Type
ie it seems to have inserted the implicit argument rules also.
What are the rules about this?
And if there are any tips for finding things like this in the documentation, I'd appreciate it. For example, the symbol := isn't in the general index, which I would have expected.
Thanks
Jeremy
- [Coq-Club] implicit arguments, Jeremy Dawson, 12/10/2020
- Re: [Coq-Club] implicit arguments, Jim Fehrle, 12/10/2020
- Re: [Coq-Club] implicit arguments, Jeremy Dawson, 12/12/2020
- Re: [Coq-Club] implicit arguments, Jim Fehrle, 12/13/2020
- Re: [Coq-Club] implicit arguments, Fabian Kunze, 12/13/2020
- Re: [Coq-Club] implicit arguments, Jeremy Dawson, 12/13/2020
