- From: Fabian Kunze <fabian.kunze AT cs.uni-saarland.de>
- To: Jeremy Dawson <coq-club AT inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] implicit arguments
- Date: Sun, 13 Dec 2020 08:39:34 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fabian.kunze AT cs.uni-saarland.de; spf=Pass smtp.mailfrom=fabian.kunze AT cs.uni-saarland.de; spf=None smtp.helo=postmaster AT thyone.hiz-saarland.de
- Ironport-phdr: 9a23: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
Dear Jeremy,
What are you missing from
https://coq.inria.fr/distrib/current/refman/language/extensions/implicit-arguments.html
In the beginning the page explains all the different kinds of reasons
argument could be made implicit (or better, how some arguments could be
inferred in use), and then the optons/flags are listed which enable/disable
the detection/declaration of those kinds of implicit arguments when defining
new constants.
What more would you expect to be explained there?
Best,
Fabian
12 Dec 2020 12:42:51 Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>:
> Hi Jim,
> Thanks. I think the second reference was meant to be
> https://coq.inria.fr/distrib/current/refman/language/core/definitions.html#grammar-token-term_let
> but that is for a different use of :=
> I've found a section on := used as in this case, it's at
> under the heading Explicit applications
> but it doesn't include info on when implicit argments are implicitly
> inserted
> Whereabouts can I find information about what is happening here?
> Thanks,
> Jeremy
> On 10/12/20 3:32 pm, Jim Fehrle wrote:
>> Check this section of the manual:
>> https://coq.inria.fr/distrib/current/refman/language/extensions/arguments-command.html,
>> that may have what you seek. Still lots of things in the manual need
>> improvement.
>> However, I'm not an expert on implicit arguments.
>> It's a bit hard to index :=, it's used in 77 places in the grammar. A few
>> non-alphabetic items appear in the general index, but what's there is
>> probably woefully inadequate. Here is one basic use:
>> http://localhost:63342/coq2/doc/sphinx/_build/html/language/core/definitions.html#grammar-token-term_let
>> Jim
>> On Wed, Dec 9, 2020 at 7:46 PM Jeremy Dawson <Jeremy.Dawson AT anu.edu.au
>> <mailto:Jeremy.Dawson AT anu.edu.au>> wrote:
>> Hi,
>> I have tried to find out when implicit arguments are inserted. Is this
>> in the documentation anywhere?
>> With a function
>> lja_dd_ord < About no_rpt_same.
>> no_rpt_same :
>> forall U : Type,
>> relationT U ->
>> forall (rules : list U -> U -> Type) (prems : U -> Type) (c0 : U),
>> derrec rules prems c0 -> Type
>> Arguments U, rules, prems, c0 are implicit
>> I find
>> lja_dd_ord < Check no_rpt_same seq_ord.
>> no_rpt_same seq_ord
>> : forall (rules : list (srseq (PropF ?V)) -> srseq (PropF ?V)
>> -> Type)
>> (prems0 : srseq (PropF ?V) -> Type) (c0 : srseq (PropF ?V)),
>> derrec rules prems0 c0 -> Type
>> which is as I expected (as a matter of fact, I can't find this
>> documented either, but I've discovered from experience that implicit
>> arguments (non-maximal) are inserted up to the last explicit argument)
>> but
>> lja_dd_ord < Check no_rpt_same seq_ord (prems:=prems).
>> : forall c0 : srseq (PropF V), derrec ?rules prems c0 -> Type
>> ie it seems to have inserted the implicit argument rules also.
>> What are the rules about this?
>> And if there are any tips for finding things like this in the
>> documentation, I'd appreciate it. For example, the symbol := isn't in
>> the general index, which I would have expected.
>> Thanks
>> Jeremy
- [Coq-Club] implicit arguments, Jeremy Dawson, 12/10/2020
- Re: [Coq-Club] implicit arguments, Jim Fehrle, 12/10/2020
- Re: [Coq-Club] implicit arguments, Jeremy Dawson, 12/12/2020
- Re: [Coq-Club] implicit arguments, Jim Fehrle, 12/13/2020
- Re: [Coq-Club] implicit arguments, Fabian Kunze, 12/13/2020
- Re: [Coq-Club] implicit arguments, Jeremy Dawson, 12/13/2020
