- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] cases in leq proof
- Date: Wed, 23 Dec 2020 00:46:51 +0100 (CET)
Dear Patricia,
Here are some possible low-level proofs for you are asking.
Notice that you can directly proceed by induction on S n <= m,
you have to generalize the result to the case of n <= m instead.
The only result imported from StdLib is plus_comm
which you can also show by two (nested) inductions.
Best,
Dominique
Require Import Arith.
Theorem le_plus n m : n <= m -> exists k, k+n = m.
Proof.
induction 1 as [ | m H IH ].
+ exists 0; trivial.
+ destruct IH as (k & Hk).
exists (S k).
rewrite <- Hk; trivial.
Qed.
Theorem S_plus_comm k n : S k + n = k + S n.
Proof.
do 2 (rewrite (plus_comm k); simpl).
trivial.
Qed.
Theorem le_to_exist n m : S n <= m -> exists k, S k + n = m.
Proof.
intros H.
destruct le_plus with (1 := H) as (k & Hk).
exists k; rewrite <- Hk.
apply S_plus_comm.
Qed.
De: "Patricia Peratto" <psperatto AT vera.com.uy>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Mardi 22 Décembre 2020 22:15:38
Objet: Re: [Coq-Club] cases in leq proof
Thank you by your help. I would like to apply inversionto know how to manage proofs in Prop.I get the message:Inversion would require case analysis on sort
Set which is not allowed for inductive
definition le.De: "Adam Chlipala" <adamc AT csail.mit.edu>
Para: coq-club AT inria.fr
Enviados: Martes, 22 de Diciembre 2020 17:21:23
Asunto: Re: [Coq-Club] cases in leq proof
It's certainly a good exercise to learn how to work with "le" proofs in a more fundamental way, but your example falls within linear arithmetic, a decidable theory, so there is a very simple proof.
Require Import Omega.
Theorem le_to_exist : forall n m,
S n <= m
Proof.
intros.
exists (m - S n).
omega.
Qed.
On 12/22/20 3:16 PM, Patricia Peratto wrote:
I want to prove:
Theorem le_to_exist (n m:nat)(p:le (S n) m):
exists_prop nat
(fun (k:nat)=>add (S k) n = m).
Patricia
Para: "coq-club" <coq-club AT inria.fr>
Enviados: Martes, 22 de Diciembre 2020 17:04:08
Asunto: [Coq-Club] cases in leq proof
Is there some way to make a case analisis over a proofof a leq proposition?
Regards,Patricia
- [Coq-Club] cases in leq proof, Patricia Peratto, 12/22/2020
- Re: [Coq-Club] cases in leq proof, Adam Chlipala, 12/22/2020
- Re: [Coq-Club] cases in leq proof, Patricia Peratto, 12/22/2020
- Re: [Coq-Club] cases in leq proof, Robbert Krebbers, 12/22/2020
- Re: [Coq-Club] cases in leq proof, Dominique Larchey-Wendling, 12/23/2020
- Re: [Coq-Club] cases in leq proof, Castéran Pierre, 12/23/2020
