coq-club - Re: [Coq-Club] Add LoadPath in Coq 8.12.2
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Add LoadPath in Coq 8.12.2
  • Date: Wed, 20 Jan 2021 23:13:46 +1100
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=BN1SS85SPDD0zJeUslZ5umvsIdO7uQ2Z64NuD/MpcXE=; b=la0Z0NPA+jORPFhQYnXWaJ6vs/9l1YnnYPMKEa3/eX2BV5QLV1Cptt8ptn7A1y5vYU3ZeSIe4EdARM0MeaxsdIePs1ttiCaOosWEtbCrPYgnAxYwVw4mioIdzMVw3B8K7Lg9kQETH9nju6gSqw8OVwOqpbZaJPa5rdo5rMHP49P/mJtTIrC8m7nyamwMxh6Or4hFsGe5Pwsu893tEmlwL1IIiZJhrfOwZFX0ha3pueDM5VL2x9zuTCs1LInfjwi7wGlo6ity3DRGEYphpf7GYpy93kLGHsR0y2JE/ZfmU30qcyra68wNNiizYkEwpDMKEl7aRr/RsxdtqcestHPYew==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=U4Rd4HLxOzunQa3S3QIBKHfC+8w8km2NJ4n/0ZZJUAeDx0t3uuo0YTNxjEYTnFnx505yhXK9n+dYExT1oVwkmhepdGbhK0NI9S1/W8guCD06unx+u5bzObkZMjZlrh8zimM9Si7SMfCakQjs5uk2YBP1Il/BRaHG3ZNmoIYazJuonjvoESk5H8Q1ukk/0nDfuoO66wC+ABLxLOKoyR3/ooxk5l7lFiU2A87KMZX4hD2FPv0OKIwpOuk/xbWelHh97PUiVtQVPDeLGi9yy/NBxfmmkH+GMmJMlFBs95SYqsVJxNIbOJIisESF7FZa0CgSf5A83+c9L3OahkBBplhfyw==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-SY4-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23: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
On 20/1/21 7:27 pm, Guillaume Melquiond wrote:
Le 20/01/2021 à 03:13, Jeremy Dawson a écrit :
when I was trying to use CoqProject with all the suggestions various
people made.  Would that be correct?  Is "xx" here, or the absence of
it, a "logical name"?  And how does one compile a Coq file (genT.v) to
make it contain the library xx.genT rather than the library genT?
And (I know I must sound like a broken record here, but I'm just as sick
of it as anyone reading it) is this anywhere in the documentation?
Yes it is.
https://coq.inria.fr/distrib/current/refman/language/core/modules.html#libraries-and-filesystem
https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#loadpath
For short, Coq uses a virtual filesystem to locate .vo files. Paths to
files from the (potentially numerous) physical filesystems of your
computer are mapped into this single virtual filesystem (where they get
"logical" paths). If you want file /foo/bar/genT.vo to be assigned the
logical path xx.genT, you need to add the following lines to your
_CoqProject file:
-R /foo/bar xx
Remarks:
1. You can also use -Q instead of -R. See the documentation for the
difference between those two.
2. You can (and often should) use physical paths relative to the
directory of your _CoqProject file, instead of absolute ones.
3. If you invoke coqc directly rather than through the Makefile
generated by coq_makefile, you need to pass the exact same -R/-Q option
as above on its command line. (You might have to adjust the physical
paths if you are using relative ones, depending on which directory you
are running coqc from.)
4. For installed libraries, Coq takes care of automatically adding the
corresponding -R/-Q options, e.g.,
-R /path/to/coq/theories Coq
-Q /path/to/coq/user-contrib/xx xx
-Q /path/to/coq/user-contrib/yy yy
So, you do not need to mention already installed libraries in your
_CoqProject file.
5. ``Add Rec LoadPath "/foo/bar" as xx.'' is equivalent to using the -R
option. ``Add LoadPath "/foo/bar" as xx.'' is equivalent to using the -Q
option.
Best regards,
Guillaume
Thanks but I understood that the -Q and -R options control where Coq looks to find compiled .vo files. This is what I understand from
"-Q directory dirpath
Add physical path directory to the list of directories where Coq looks for a file and bind it to the logical directory dirpath."
and
"The command line option -R is a variant of -Q which has the strictly same behavior regarding loadpaths, but which also makes the corresponding .vo files available ..."
and
" Command Add LoadPath string as dirpath
dirpath
ident .* ident
This command is equivalent to the command line option -Q string dirpath"
(and I know from using it that Add LoadPath tells Coq where to look for compiled .vo files).
The question is about how to compile a file genT.v in a way that it provides library xx.genT rather than library genT, not about how to tell it where to look for files which it Imports.
Or are you saying that the -Q and -R options have these two distinct purpose? In which case, I suppose you say
coqc -Q ... xx genT.v
(but what goes in the place of the ...)
and if you need to use say
coqc -Q XX xx -Q YY yy genT.v
does the file genT.vo contain library xx.genT or yy.genT?
Thanks
Jeremy
