coq-club - Re: [Coq-Club] Add LoadPath in Coq 8.12.2
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Add LoadPath in Coq 8.12.2
  • Date: Wed, 20 Jan 2021 22:08:05 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f50.google.com
  • Ironport-phdr: 9a23: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
Le mer. 20 janv. 2021 à 13:14, Jeremy Dawson
<Jeremy.Dawson AT anu.edu.au> a écrit :
> that the -Q and -R options have these two distinct
> purpose?
Yes It serves these two purposes at the same time: it tells how to
compile .v and where to look for .vo.
> In which case, I suppose you say
> coqc -Q ... xx genT.v
> (but what goes in the place of the ...)
> and if you need to use say
> coqc -Q XX xx -Q YY yy genT.v
> does the file genT.vo contain library xx.genT or yy.genT?
No. Because in your example genT.v does not seem to be in directory xx
or yy, so the two -Q commands do not affect it.
But if genT.v is in a directory foo, then
coqc -Q YY yy -Q foo xx foo/genT.v
will build foo/genT.vo with logical name xx.genT. And during the
compilation a file YY/f.vo will be accessible with name "yy.f" *and
should have be compiled to comply with this*.
Hope this helps.
> Thanks
> Jeremy
