- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Qed opacity and Coq standard library
- Date: Wed, 21 Apr 2021 16:21:21 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jhugues AT andrew.cmu.edu; spf=Pass smtp.mailfrom=jhugues AT andrew.cmu.edu; spf=None smtp.helo=postmaster AT relay-exchange.andrew.cmu.edu
- Ironport-hdrordr: A9a23:9RCdq69wCTN+i0BFp4Ruk+G9db1zdoIgy1knxilNYDReeMCAioSKlPMUyRf7hF8qKRYdsPqHP7SNRm6Z0JZz75UYM7vKZniBhEKDKoZ+4Yz+hwDxAiGWzJ8m6Y5Me7VzYeeAbmRSot395GCDf+oI4N7Cy6ywgPeb8nEFd3APV4hFzyNUTjmWCVd3Qg4uP+tFKLO56tBcrzStPVQ7B/7LZEUtZOTIq93VmJ+OW3dvbHRL1CC0gTyl87L8GRSDty1uNg9n+6so8mTOjmXCiJmLjvChxhfQk0/V4phG8eGA9vJ/BdeBgsVQFzP0igzAXuVccoCF1QpbnMifrHIR1PjFuVMJItl64XK5RBDNnTLdny3blAsIx1Cn41mCmnfnqdH+X1sBerJ8rLMcSBHQ7E0tsZVWwMtwrh6knosSCwjBkiT778XJUB8vllPcmwtYrdIu
- Ironport-phdr: A9a23:aMn5UR0OF1KpY6JvsmDOvgMyDhhPgJ3EezUN459isYplN5qZl7zcNUDSrc9gkEXOFd2Cra4d2qyM6/CrBjZIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfLd/IA+ooQnNtcQajolvJrgswRbVv3VEfPhby3l1LlyJhRb84cmw/J9n8ytOvv8q6tBNX6bncakmVLJUFDspPXw7683trhnDUBCA5mAAXWUMkxpHGBbK4RfnVZrsqCT6t+592C6HPc3qSL0/RDqv47t3RBLulSwIMCM38HzMisxokq1UvA6hqRJ4w47Reo6VNfx+db7Zcd4VQWdNW8BcXDFDDIyhdYsCF+oPM/hFoYnhqVUArhW+CgutBOzzxTBFnWX50bE/0+k7DQ3KwA4tEtQTu3rUttX1M6ISXPixwqbW1zXDaPZW1ing44bKbxAhruyMUqxrccHMzkQvFQPFjkifqYz4ITyVzf8AvHKd7+V9T+KglWAmpxttrTiq28cgkJfGiZ8Iyl3d8yhy3Yk6K8GiRkFhfd6kDIVftzucN4ZuTM0vXWNltDsnxrMItpC1cjYHxIo7yhPDa/KKcpSE7BL/WOuTLjp2inFodK6/iRqs8Uaty/PwWMa23VtEsCZIkt/BvW0D2RzU78iIUPp9/kG51DaO0QDT8OBELloumarVMZ4t2rEwlpsPsUTDAy/5g1/6jK6Rdkk8/+io6vjnbq/4qZCBKo95jBz1PKc2msGnHOg0LAsDU3KF9eimybHu/U/0TK9UgvA5iqXVrY7WKMcBqqKnGQNY3Zgv5wywAju+zdgUg3oKIEhbdB6dkoTkO1PDLOr7APq9hVmnjS1lyOrcPrL7B5XANnjDn6nlfbZ680Nc0hQ8zdRF6JNUE70OPv3yVVPxtNPCCB85PBK7z/z9B9V7y4weQ3yAA6GDPKzOtF+I+/gjLPeRa48IoDr9Kv4l6ODyjXIhhFMRY6qk0YEJZHyiA/hrI0eUbWDyjtoOCWsKuxAxTO3uiF2MSz5TYHOyUro+5jE7FYKmAprDSZ62gLGaxii7GIBZZnpYBVGCC3vna4CEW+oWZC2MP8BhjyQIVaK9RI85yRGuqAj6xqJ7IerT4y0UrI7s1Nxo5+LIjhwy7jx1D8GF026XVW10n2UIRyU33K9lu0B9xE2DguBEhKkSHttKovhNTw0SNJjGzuU8Bcq4ElbKec7MQ1K7SP2nByswR5Q/2YldTVx6HoCAgwrE2ifiI6IairGQTMg28r/TwnXqD897x2zLy+8qikRgT8dSYz71zpVj/hTeUtaa236SkLynIPhNtAb9sVybxG/Lh3l2FQt5UKHLR3caDmPfq9jj61yERLqzT7krL1kYoeayb5BSY9istm1oAe/5Mbz2amS9gWqvQx2N2/WBYJe4Iw017GDmEEEB1jsr0zOGOAw5bg+7rmbXHXljBVnvakXj/K93rn+hQ1ByxASXKUBtyujtkiM=
Hi Jean-Christophe Thanks for the pointers. I had read them already. Unfortunately this does not provide a definite solution (or I did not quite grasp the full idea behind those posts, which is also likely). I still end up with terms like
= False /\ ([] = [] /\ (Feature (Ident "a_feature") inF eventPort (Component (Ident "") null (Ident "") [] [] [] []) [] = Feature (Ident "a_feature") inF eventPort (Component (Ident "") null (Ident "") [] [] [] []) [] \/ False) \/ False) : Prop
And I believe an evaluation strategy would reduce those basic terms to either True or False without intervention. But I fail to establish one. It works in some cases, but not on other and I am trying to understand the pattern behind those.
Generally speaking, all my definitions are based on equality of some inductive types based on nat or lists of other inductive types. So the use case is rather narrow.
Thanks,
<coq-club-request AT inria.fr> on behalf of Jean-Christophe Léchenet <jean-christophe.lechenet AT inria.fr>
Hi Jerome, Two blog posts that are relevant to this topic : Not sure if that will help in your case, though. Best, Jean-Christophe
Le 20/04/2021 à 15:48, Jerome Hugues a écrit :
- [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/20/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jean-Christophe Léchenet, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Fabian Kunze, 04/23/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Pierre-Marie Pédrot, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Xavier Leroy, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/23/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Pierre Courtieu, 04/23/2021
