- From: Xavier Leroy <xavier.leroy AT college-de-france.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Qed opacity and Coq standard library
- Date: Wed, 21 Apr 2021 19:12:29 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=xavier.leroy AT college-de-france.fr; spf=Pass smtp.mailfrom=xavier.leroy AT college-de-france.fr; spf=None smtp.helo=postmaster AT smtpout02-ext2.partage.renater.fr
- Ironport-hdrordr: A9a23:BKUF56OA1n3B8MBcT6P155DYdL4zR+YMi2QD/UoZc20yTuWzkceykPMHkSLugDEKV3063fyGMq+MQXTTnKQFmLU5F7GkQQXgpS+UPJhvhLGD/xTMEzDzn9QtsptIXLN5DLTLfD1HpOb8pDK1CtMxhOSAmZrY4dv263t2VwllZ+VB4m5Ce36mO2l3QAUDOpYjDpqb4aN81lmdUE8aZMi6GXUJNtKrz7arqLvcbRELHBIh4gWV5AnYk4LSKBSEwgwYFwpG3LZKywb4ujbk7aauuezT8G6/60bv6f1t6aHc4+oGKsjJrsQOMD3jhkKTeYx9V9S50QwdkaWA7lAlldWJjjUBG4BI633XdnyouheF4WPd+QdrxXnlx1qVxUHmvNW8fjQnEMBM7Lg0TjLpr24pvNRxy8twrh+knqsSNh/LkCTj69WgbX5XqnY=
Hi,
At some point in my project, I use Defined rather than Qed to have transparent proofs and use the Compute mechanisms to evaluate some statements. This works nicely for my own theorems, but I am stuck when this involves theorems provided by the Coq standard library, NoDup_dec in my case, but ultimately this might extend to more situations.
One quick and dirty work-around is to copy/paste the code, change Qed into Defined and voila! But this is not satisfactory.
I could find some blog posts like this one https://plv.csail.mit.edu/blog/computing-with-opaque-proofs.html by Clément Pit-Claudel on this topic, but again it seems this imposes some rework.
I understand Qed and Defined are different for a reason, I am just curious whether there is a systematic way to change Qed into Defined on a case by case basis, or if we are forced to this type of modifications.
Is there some suggested readings on this topic?
Thanks
- [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/20/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jean-Christophe Léchenet, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Fabian Kunze, 04/23/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Pierre-Marie Pédrot, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Xavier Leroy, 04/21/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Jerome Hugues, 04/23/2021
- Re: [Coq-Club] Qed opacity and Coq standard library, Pierre Courtieu, 04/23/2021
