coq-club - Re: [Coq-Club] records ?
  • From: Agnishom Chattopadhyay <agnishom AT cmi.ac.in>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] records ?
  • Date: Sun, 5 Sep 2021 22:20:40 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=agnishom AT cmi.ac.in; spf=Pass smtp.mailfrom=agnishom AT cmi.ac.in; spf=None smtp.helo=postmaster AT mail.cmi.ac.in
  • Ironport-hdrordr: A9a23:P5ctP63cZVLXX6V4PQqYKAqjBKskLtp133Aq2lEZdPU1SL38qynApoV46faZslcssQ8b9uxoSZPvfZq0z/cciuR8AV7IZniEhILHFuFfBFTZqQHdJw==
  • Ironport-phdr: A9a23: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
Locate locates notation that is defined by the programmer. I believe that "{|" is syntax which is part of Gallina.
As for the next step, have you tried split? You can also try solving this with exact.
--agnishom
On Sun, Sep 5, 2021, 21:25 Jeremy Dawson <Jeremy.Dawson AT anu.edu.au> wrote:
Hi,
I have a hypothesis (got by playing around with someone else's code) of
the form {| c := ccc ; i := iii |}
The command Locate "{|". produces no results.
I found in the documentation a syntax definition
term_record::={| field_def*; ;? |}
but I can't find anything about what that means or what you can do with it.
Does it mean I have a thing of type ccc and another thing of type iii?
If so how do I actually get hold of those things?
Then, when I have a goal of the form {| c := ccc ; i := iii |}
what does that mean and what is the next step to solving it?
Thanks
Jeremy
