- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] records ?
- Date: Mon, 6 Sep 2021 14:57:32 +1000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mukeshtiwari.iiitm AT gmail.com; spf=Pass smtp.mailfrom=mukeshtiwari.iiitm AT gmail.com; spf=None smtp.helo=postmaster AT mail-ed1-f52.google.com
- Ironport-hdrordr: A9a23:Xw4R9asKXyM8vghxq344JbQt7skDd9V00zEX/kB9WHVpmwKj5qSTdZMgpGbJYVcqKRcdcLW7UpVoLkm8yXcY2/hzAV7AZniAhILLFu9fBOLZqlWKdkHDH4hmpMVdmodFZ+EYZmIbsS+V2njcL+od
- Ironport-phdr: A9a23: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
Hi Jeremy,
The thing "{| c := ccc ; i := iii |}" is record data type [1] and you can also think of it as inductive data type with one constructor. I wrote a simple example, see below.
Require Import Coq.Strings.String.
Record person := mk_name
age : nat
Lemma identity : forall p q : person, p = q -> q = p.
Proof.
intros ? ? Hpq.
p, q: person
Hpq: p = q
1/1
q = p
destruct q. destruct p.
(* The context looks like:
name1: string
age1: nat
name0: string
age0: nat
Hpq: {| name := name1; age := age1 |} = {| name := name0; age := age0 |}
1/1
{| name := name0; age := age0 |} = {| name := name1; age := age1 |}
inversion Hpq. (* get the equality between the corresponding fields *)
name1: string
age1: nat
name0: string
age0: nat
H0: name1 = name0
H1: age1 = age0
1/1
{| name := name0; age := age0 |} = {| name := name0; age := age0 |}
reflexivity.
Qed.
Theorem identity_function : forall p: person, person.
Proof.
intros p.
(* see the type of pn and qn *)
remember (name p ) as pn.
remember (age p) as qn.
exact ( {| name := name(p); age := age(p) |}).
you can write 'exact p' or you can provide it using the constructor
exact (mk_name EmptyString 10).
Defined.
However, in your case, I believe, it will be type error because {| c := ccc ; i := iii |} is not of Type, Set, or Prop.
Best,
Mukesh
[1] https://coq.inria.fr/refman/language/core/records.html
age : nat
Proof.
intros ? ? Hpq.
p, q: person
Hpq: p = q
1/1
q = p
name1: string
age1: nat
name0: string
age0: nat
1/1
name1: string
age1: nat
name0: string
age0: nat
H0: name1 = name0
H1: age1 = age0
1/1
reflexivity.
Qed.
" If so how do I actually get hold of those things?"
You can access the individual field by using the corresponding field names, e.g., if you have a person p, then you can access its name by (name p) and age by (age p).
"Then, when I have a goal of the form {| c := ccc ; i := iii |} what does that mean and what is the next step to solving it?"
When we have a goal, say, of A (Type, Set, or Prop), then we need to produce a witness of A. For example, in the example below,
I am producing a person as a return type, and I can do that in many ways. I can just return p, or I can construct any arbitrary person
by using the constructor 'mk_name'.
Proof.
intros p.
Defined.
Best,
Mukesh
On Mon, Sep 6, 2021 at 12:25 PM Jeremy Dawson <Jeremy.Dawson AT anu.edu.au> wrote:
Hi,
I have a hypothesis (got by playing around with someone else's code) of
The command Locate "{|". produces no results.
I found in the documentation a syntax definition
term_record::={| field_def*; ;? |}
but I can't find anything about what that means or what you can do with it.
Does it mean I have a thing of type ccc and another thing of type iii?
Thanks
Jeremy
- [Coq-Club] records ?, Jeremy Dawson, 09/06/2021
- Re: [Coq-Club] records ?, Agnishom Chattopadhyay, 09/06/2021
- Re: [Coq-Club] records ?, Jeremy Dawson, 09/06/2021
- Re: [Coq-Club] records ?, Madhukar, 09/06/2021
- Re: [Coq-Club] records ?, mukesh tiwari, 09/06/2021
