- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using SerAPI in a plugin
- Date: Wed, 8 Sep 2021 02:54:58 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lasse AT blaauwbroek.eu; spf=Pass smtp.mailfrom=lasse AT blaauwbroek.eu; spf=None smtp.helo=postmaster AT mail.blaauwbroek.eu
- Ironport-hdrordr: A9a23:POT3jKNZ7FoBkMBcTsyjsMiBIKoaSvp037BZ7TEXdfU1SL39qynKpp4mPHDP6Ar5NEtPpTnEAtjkfZq+z+8W3WByB9aftWDd0QPCEGgh1+TfKlbbdhEWmNQw6U4tSdkcNOHN
- Ironport-phdr: A9a23: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
With dune, Coq's libraries are split into sub-libraries, such as 'coq.plugins.ltac'. When you need to use a particular API file, you check which library it is in (by opening the dune file in the directory of that file), and add that library as a dep. The repo I linked does this with 'coq.plugins.ltac'.
I have an example plugin that does exactly this here: https://github.com/LasseBlaauwbroek/serapi-example
I think I built this again 8.11 at the time, but I'm not sure (I didn't try to recompile the plugin before this email). Word of warning: Using SerAPI in a Coq plugin can be rather difficult due to its dependencies.
Lasse
Hi all,
Have any of you gotten plugins that call out to SerAPI working, especially on Coq 8.9 (I am bound to 8.9 because of a dependency)? If so, I'd really love to see some example plugins. This is a major blocker for me and a student on a project.
I'm open to any build system at this point, but I haven't managed to get Dune working even without SerAPI---it gives me a bunch of errors failing to find Constr, Environ, and so on. The Dune tutorial didn't seem to address those errors. I don't know where to find the list of Coq libraries I can try to depend on from within a Dune project.
Without using Dune, using the normal _CoqProject and so on, I can get it to build if I build from source, which is already hacky. But then it fails to load:File "./theories/Plib.v", line 1, characters 0-25:
Error:
while loading /home/talia/coq-plugin-lib/src/plib.cmxs:
error loading shared library: /home/talia/coq-plugin-lib/src/plib.cmxs: undefined symbol: camlPlib__Serapi_goals__anon_fn$5bcoq$2dserapi$2fserapi$2fserapi_goals$2eml$3a66$2c31$2d$2d47$5d_175_closure
- [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Jason Gross, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Lasse Blaauwbroek, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/22/2021
