- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using SerAPI in a plugin
- Date: Tue, 21 Sep 2021 18:44:49 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=Pass smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mx7.cs.washington.edu
- Ironport-hdrordr: A9a23:1bMnIqFr+6bJVSVkpLqEj8eALOsnbusQ8zAXPidKKCC9E/b3qynApoV56faZskdyZJhCo7+90de7IU80nKQdieJ6AV7IZmXbUQWTQb1f0Q==
- Ironport-phdr: A9a23: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
Just for the record for the future I guess, I couldn't get Dune working with the original plugin (even without SerAPI) because the plugin has many subdirectories, and I can't figure out a way to get the .v theory that loads the plugin to begin with to link to all of them. I can sort of hack it by adding a lot of "declare ML module" lines in the top-level theory for every subdirectory, but if I do that, coqdep gives me a number of warnings like "declared ML module contexts has not been found!" and then the build does not progress any further. I tried messing with the paths in a few different ways but couldn't figure anything out that got rid of the warning.My work-in-progress is here: https://github.com/uwplse/coq-plugin-lib/tree/dune . I hope I figure it out at some point since this is a serious blocker for integrating a machine learning model into an existing plugin. Probably I will try to corner Emilio and talk him into a synchronous call :). But if anyone has encountered this before, I'd love to hear how you resolved it.TaliaOn Wed, Sep 8, 2021 at 12:43 AM Talia Ringer <tringer AT cs.washington.edu> wrote:Thanks, this path looks really promising and I'll try it as soon as I get the chance.On Tue, Sep 7, 2021, 7:55 PM Lasse Blaauwbroek <lasse AT blaauwbroek.eu> wrote:With dune, Coq's libraries are split into sub-libraries, such as 'coq.plugins.ltac'. When you need to use a particular API file, you check which library it is in (by opening the dune file in the directory of that file), and add that library as a dep. The repo I linked does this with 'coq.plugins.ltac'.
On 08/09/2021 02:50, Talia Ringer wrote:
Thanks, with Dune though I can't even get my Coq plugin without SerAPI to load Constr, Environ, and other necessary modules. I have no idea what I'm supposed to depend on to get those.
On Tue, Sep 7, 2021 at 7:47 PM Lasse Blaauwbroek <lasse AT blaauwbroek.eu> wrote:
I have an example plugin that does exactly this here: https://github.com/LasseBlaauwbroek/serapi-example
I think I built this again 8.11 at the time, but I'm not sure (I didn't try to recompile the plugin before this email). Word of warning: Using SerAPI in a Coq plugin can be rather difficult due to its dependencies.
Lasse
On 08/09/2021 02:30, Talia Ringer wrote:
Hi all,
Have any of you gotten plugins that call out to SerAPI working, especially on Coq 8.9 (I am bound to 8.9 because of a dependency)? If so, I'd really love to see some example plugins. This is a major blocker for me and a student on a project.
I'm open to any build system at this point, but I haven't managed to get Dune working even without SerAPI---it gives me a bunch of errors failing to find Constr, Environ, and so on. The Dune tutorial didn't seem to address those errors. I don't know where to find the list of Coq libraries I can try to depend on from within a Dune project.
Without using Dune, using the normal _CoqProject and so on, I can get it to build if I build from source, which is already hacky. But then it fails to load:
File "./theories/Plib.v", line 1, characters 0-25:
Error:
while loading /home/talia/coq-plugin-lib/src/plib.cmxs:
error loading shared library: /home/talia/coq-plugin-lib/src/plib.cmxs: undefined symbol: camlPlib__Serapi_goals__anon_fn$5bcoq$2dserapi$2fserapi$2fserapi_goals$2eml$3a66$2c31$2d$2d47$5d_175_closure
Help with either of these paths would be strongly appreciated.
Talia
- [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Jason Gross, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Lasse Blaauwbroek, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/08/2021
- Re: [Coq-Club] Using SerAPI in a plugin, Talia Ringer, 09/22/2021
