- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Alternate Definition of Well-Foundedness
- Date: Sat, 18 Feb 2023 22:09:30 +0100
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=frederic.blanqui AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hi. You can have a look at the Coq library on rewriting and termination CoLoR on https://github.com/fblanqui/color/. See in particular https://github.com/fblanqui/color/tree/master/Util/Relation and https://github.com/fblanqui/color/blob/master/Util/Relation/NotSN_IS.v . Best regards, Frédéric.
Le 18/02/2023 à 21:54, mukesh tiwari a écrit :
Hi everyone,
Recently, I stumbled across the book ML for the Working Programmer [1]
and saw this text,
"Infinite decreasing chains are intuitively appealing, but other
definitions of well-foundedness permit simpler proofs. For instance, ≺
is well-founded just if every non-empty set contains a ≺-minimal
element. There also exist definitions suited for constructive logic."
(see page 246 of[1]).
In all my formalisation, and the ones that I have seen on GitHub, all
of them have used infinite decrease chains, defined in Coq library
[2]. My question is: are there any other Coq formalisations that use
other definitions of well-foundedness, not the Acc one [2].
Best,
Mukesh
[1] https://www.cl.cam.ac.uk/~lp15/MLbook/PDF/chapter6.pdf
[2] https://coq.inria.fr/library/Coq.Init.Wf.html
- [Coq-Club] Alternate Definition of Well-Foundedness, mukesh tiwari, 02/18/2023
- Re: [Coq-Club] Alternate Definition of Well-Foundedness, Frédéric Blanqui, 02/18/2023
- Re: [Coq-Club] Alternate Definition of Well-Foundedness, Dominique Larchey-Wendling, 02/18/2023
