- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?
- Date: Tue, 30 Jan 2024 14:44:42 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Pass smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Dear Suneel,
The spec of MergeSort should be enough:
if two lists are sorted and *permutable*, then they are equal.
Best,
Dominique
De: "Suneel Sarswat" <suneel.sarswat AT gmail.com>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Mardi 30 Janvier 2024 14:08:27
Objet: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?
Dear Members,I have list L of unique records type.I have defined ordertype "dec" on these records. I am using MergeSort module from standard library. Now I need to prove a basic result on this list. Any help would be appreciated.Lemma sort_sorted L:Sorted dec L -> L = sort dec L.Thanks,Suneel
- [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Suneel Sarswat, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Kazuhiko Sakaguchi, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Suneel Sarswat, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Dominique Larchey-Wendling, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Xavier Leroy, 01/30/2024
