- From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?
- Date: Tue, 30 Jan 2024 15:24:06 +0100 (CET)
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=Pass smtp.mailfrom=dominique.larchey-wendling AT loria.fr; spf=None smtp.helo=postmaster AT zcs-store7.inria.fr
Indeed, as Xavier remarks, I forgot to say that the order should
be a *total* order ie "any two elements are always comparable".
If the order is partial like eg the flat order (equality,
which is antisymmetric btw) then of course the stated
result does not hold.
Concerning the stability property of MergeSort, doesn't it depend on
the way you split the pre-ordered list? Would it work with a split like:
let split =
let rec loop a b = function
| [] -> (rev a,rev b)
| x::l -> loop b (x::a) l
in loop [] []
Dominique
De: "xavier leroy" <xavier.leroy AT college-de-france.fr>
À: "coq-club" <coq-club AT inria.fr>
Envoyé: Mardi 30 Janvier 2024 15:04:35
Objet: Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?
On Tue, Jan 30, 2024 at 2:44 PM Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr> wrote:Dear Suneel,The spec of MergeSort should be enough:if two lists are sorted and *permutable*, then they are equal.Only if the ordering used is antisymmetric. If you sort pairs of integers on their first components, for example,[ (0, 10) ; (0, 5) ; (1, 1) ]and[ (0, 5) ; (0, 10) ; (1, 1) ]are both sorted, and are permutable, but are not equal.The property Suneel wants to prove is probably true for all orders, but only because merge sort is stable, i.e. preserves the relative ordering of list elements that compare as equal.Stability of merge sort is not proved in the Coq standard library as far as I can tell, but here is a proof for a different implementation of merge sort: https://xavierleroy.org/coq/Mergesort.html- Xavier LeroyBest,DominiqueDe: "Suneel Sarswat" <suneel.sarswat AT gmail.com>
Envoyé: Mardi 30 Janvier 2024 14:08:27
Objet: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?Dear Members,I have list L of unique records type.I have defined ordertype "dec" on these records. I am using MergeSort module from standard library. Now I need to prove a basic result on this list. Any help would be appreciated.Lemma sort_sorted L:Sorted dec L -> L = sort dec L.Thanks,Suneel
- [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Suneel Sarswat, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Kazuhiko Sakaguchi, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Suneel Sarswat, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Dominique Larchey-Wendling, 01/30/2024
- Re: [Coq-Club] Merge Sort: Sorted L -> L = sort dec L?, Xavier Leroy, 01/30/2024
