- From: Richard Dapoigny <richard.dapoigny AT univ-smb.fr>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Proving the pairing axiom
- Date: Sun, 29 Dec 2024 23:25:38 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=richard.dapoigny AT univ-smb.fr; spf=Pass smtp.mailfrom=richard.dapoigny AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout01-ext2.partage.renater.fr
- Dkim-filter: OpenDKIM Filter v2.10.3 zmtaout05.partage.renater.fr 9B0D8A00E5
- Ironport-sdr: 6771cc64_3N3LEtSLlhGj4dGyqCXWVCZeWAvjTtbzS9HYFddrXEVq88N /ba8nqk8S2hDKETwcPMJjRZReHF93REFwrddaOw==
Proof.
intros;split.
- intro Ha;unfold set_eq, In in Ha;destruct A as [f];cbn in Ha;unfold ι;f_equal;eapply functional_extensionality;intro y;specialize (Ha y); destruct (eqobject_dec x y) as [Hb | Hb].
-- assert (True = True);[ sfirstorder | rewrite Ha in H;sfirstorder ].
-- assert ((False = True) -> False);[ sauto lq: on | rewrite Ha in H;sfirstorder use: PropExtensionalityFacts.PropExt_imp_RefutPropExt,
in_singleton, propositional_extensionality unfold: In, ι, prop_degeneracy ].
- intro Ha;subst;sfirstorder.
Qed.
To: "coq-club" <coq-club AT inria.fr>
Sent: Sunday, December 29, 2024 11:17:13 PM
Sent: Saturday, December 28, 2024 11:17 AM
To: coq-club AT inria.fr <coq-club AT inria.fr>
On 28 Dec 2024, at 14:41, richard <richard.dapoigny AT univ-smb.fr> wrote:
Dear Coq user,
I am working on sets with characteristic functions and a datatype called object for wich equality is decidable.
Singletons called ι are also defined in this context. An excerpt of the code is given below.
Definition object: Type := t.
Definition eqobject_dec := eq_dec.
Inductive N : Type :=
| Caract : (object -> Prop) -> N.
Definition caract (s :N)(a:object) : Prop := let (f) := s in f a.
Definition In (s :N)(a:object) : Prop := caract s a = True.
Definition incl (s1 s2 :N) := forall a:object, In s1 a -> In s2 a.
Definition set_eq (s1 s2 :N) := forall a:object, In s1 a = In s2 a.Definition ι (a:object) :=
Caract
(fun a':object =>
match eqobject_dec a a' with
| left h => True
| right h => False
end).My question is the following : is there a possibility to prove the pairing axiom with these assumptions, i.e. to prove that
Lemma pairN : forall (x:object)(A:N), set_eq (ι x) A <-> ι x = A.
In addition we assume classical logic.
Thanks in advance,
Richard
- [Coq-Club] Proving the pairing axiom, richard, 12/28/2024
- Re: [Coq-Club] Proving the pairing axiom, mukesh tiwari, 12/28/2024
- Re: [Coq-Club] Proving the pairing axiom, Richard Dapoigny, 12/29/2024
- Re: [Coq-Club] Proving the pairing axiom, Jason Hu, 12/29/2024
