Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Huge API Update: Function renaming
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Huge API Update: Function renaming
  • Date: Wed, 05 May 2010 14:51:48 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Many of the public StarPU functions have been renamed (see r2080). This has been done to provide a more consistent API.
To help with your own StarPU applications, i attach some script files to automatically update your code towards the new API.
Regards,
Nathalie
s/\bstarpu_submit_task\b/starpu_task_submit/g
s/\bstarpu_wait_task\b/starpu_task_wait/g
s/\bstarpu_helper_init_cublas\b/starpu_helper_cublas_init/g
s/\bstarpu_helper_shutdown_cublas\b/starpu_helper_cublas_shutdown/g
s/\bstarpu_deregister_progression_hook\b/starpu_progression_hook_deregister/g
s/\bstarpu_register_progression_hook\b/starpu_progression_hook_register/g
s/\bstarpu_get_worker_id\b/starpu_worker_get_id/g
s/\bstarpu_get_worker_devid\b/starpu_worker_get_devid/g
s/\bstarpu_get_worker_memory_node\b/starpu_worker_get_memory_node/g
s/\bstarpu_get_worker_name\b/starpu_worker_get_name/g
s/\bstarpu_get_worker_type\b/starpu_worker_get_type/g
s/\bstarpu_get_worker_count\b/starpu_worker_get_count/g
s/\bstarpu_get_cpu_worker_count\b/starpu_cpu_worker_get_count/g
s/\bstarpu_get_spu_worker_count\b/starpu_spu_worker_get_count/g
s/\bstarpu_get_opencl_worker_count\b/starpu_opencl_worker_get_count/g
s/\bstarpu_get_cuda_worker_count\b/starpu_cuda_worker_get_count/g
s/\bstarpu_get_local_cuda_stream\b/starpu_cuda_get_local_stream/g
s/\bstarpu_wait_all_tasks\b/starpu_task_wait_for_all/g
s/\bstarpu_delete_data\b/starpu_data_unregister/g
s/\bstarpu_malloc_pinned_if_possible\b/starpu_data_malloc_pinned_if_possible/g
s/\bstarpu_free_pinned_if_possible\b/starpu_data_free_pinned_if_possible/g
s/\bstarpu_sync_data_with_mem\b/starpu_data_sync_with_mem/g
s/\bstarpu_sync_data_with_mem_non_blocking\b/starpu_data_sync_with_mem_non_blocking/g
s/\bstarpu_release_data_from_mem\b/starpu_data_release_from_mem/g
s/\bstarpu_advise_if_data_is_important\b/starpu_data_advise_as_important/g
s/\bstarpu_request_data_allocation\b/starpu_data_request_allocation/g
s/\bstarpu_prefetch_data_on_node\b/starpu_data_prefetch_on_node/g
s/\bstarpu_get_sub_data\b/starpu_data_get_sub_data/g
s/\bstarpu_partition_data\b/starpu_data_partition/g
s/\bstarpu_unpartition_data\b/starpu_data_unpartition/g
s/\bstarpu_test_if_data_is_allocated_on_node\b/starpu_data_test_if_allocated_on_node/g
s/\bstarpu_get_block_elemsize\b/starpu_block_get_elemsize/g
s/\bstarpu_get_block_local_ldy\b/starpu_block_get_local_ldy/g
s/\bstarpu_get_block_local_ldz\b/starpu_block_get_local_ldz/g
s/\bstarpu_get_block_local_ptr\b/starpu_block_get_local_ptr/g
s/\bstarpu_get_block_nx\b/starpu_block_get_nx/g
s/\bstarpu_get_block_ny\b/starpu_block_get_ny/g
s/\bstarpu_get_block_nz\b/starpu_block_get_nz/g
s/\bstarpu_register_block_data\b/starpu_block_data_register/g
s/\bstarpu_get_bcsr_c\b/starpu_bcsr_get_c/g
s/\bstarpu_get_bcsr_elemsize\b/starpu_bcsr_get_elemsize/g
s/\bstarpu_get_bcsr_firstentry\b/starpu_bcsr_get_firstentry/g
s/\bstarpu_get_bcsr_local_colind\b/starpu_bcsr_get_local_colind/g
s/\bstarpu_get_bcsr_local_nzval\b/starpu_bcsr_get_local_nzval/g
s/\bstarpu_get_bcsr_local_rowptr\b/starpu_bcsr_get_local_rowptr/g
s/\bstarpu_get_bcsr_nnz\b/starpu_bcsr_get_nnz/g
s/\bstarpu_get_bcsr_nrow\b/starpu_bcsr_get_nrow/g
s/\bstarpu_get_bcsr_r\b/starpu_bcsr_get_r/g
s/\bstarpu_register_bcsr_data\b/starpu_bcsr_data_register/g
s/\bstarpu_get_csr_elemsize\b/starpu_csr_get_elemsize/g
s/\bstarpu_get_csr_firstentry\b/starpu_csr_get_firstentry/g
s/\bstarpu_get_csr_local_colind\b/starpu_csr_get_local_colind/g
s/\bstarpu_get_csr_local_nzval\b/starpu_csr_get_local_nzval/g
s/\bstarpu_get_csr_local_rowptr\b/starpu_csr_get_local_rowptr/g
s/\bstarpu_get_csr_nnz\b/starpu_csr_get_nnz/g
s/\bstarpu_get_csr_nrow\b/starpu_csr_get_nrow/g
s/\bstarpu_register_csr_data\b/starpu_csr_data_register/g
s/\bstarpu_get_matrix_elemsize\b/starpu_matrix_get_elemsize/g
s/\bstarpu_get_matrix_local_ld\b/starpu_matrix_get_local_ld/g
s/\bstarpu_get_matrix_local_ptr\b/starpu_matrix_get_local_ptr/g
s/\bstarpu_get_matrix_nx\b/starpu_matrix_get_nx/g
s/\bstarpu_get_matrix_ny\b/starpu_matrix_get_ny/g
s/\bstarpu_register_matrix_data\b/starpu_matrix_data_register/g
s/\bstarpu_divide_in_2_filter_func_vector\b/starpu_vector_divide_in_2_filter_func/g
s/\bstarpu_register_vector_data\b/starpu_vector_data_register/g
s/\bstarpu_get_vector_elemsize\b/starpu_vector_get_elemsize/g
s/\bstarpu_get_vector_local_ptr\b/starpu_vector_get_local_ptr/g
s/\bstarpu_get_vector_nx\b/starpu_vector_get_nx/g
s/\bstarpu_list_filter_func_vector\b/starpu_vector_list_filter_func/g
Attachment: rename.sh
Description: application/shellscript
Haut de le page
