Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Function renaming
- Date: Wed, 05 May 2010 14:55:50 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Latest version of the renaming (done in r2080). Comments welcomed on
those marked with OK and ???. Cheers, Nathalie On 04/05/2010 16:15, Nathalie Furmento wrote: 4BE02BEB.8060405@labri.fr"> On 04/05/2010 14:40, Nathalie Furmento wrote:4BE015BB.7060704@labri.fr">Hi starpu devel!New version ... |
starpu_shutdown OK
starpu_helper_init_cublas starpu_helper_cublas_init
done
starpu_helper_shutdown_cublas starpu_helper_cublas_shutdown
done
starpu_deregister_progression_hook
starpu_progression_hook_deregister done
starpu_register_progression_hook
starpu_progression_hook_register done
starpu_get_worker_id starpu_worker_get_id
done
starpu_get_worker_devid starpu_worker_get_devid
done
starpu_get_worker_memory_node starpu_worker_get_memory_node
done
starpu_get_worker_name starpu_worker_get_name
done
starpu_get_worker_type starpu_worker_get_type
done
starpu_get_worker_count starpu_worker_get_count
done
starpu_wake_all_blocked_workers ???
starpu_get_cpu_worker_count starpu_cpu_worker_get_count
done
starpu_get_spu_worker_count starpu_spu_worker_get_count
done
starpu_get_opencl_worker_count
starpu_opencl_worker_get_count done
starpu_get_cuda_worker_count starpu_cuda_worker_get_count
done
starpu_get_local_cuda_stream starpu_cuda_get_local_stream
done
starpu_display_codelet_stats ???
starpu_tag_declare_deps OK
starpu_tag_declare_deps_array OK
starpu_tag_notify_from_apps OK
starpu_tag_remove OK
starpu_tag_wait OK
starpu_tag_wait_array OK
starpu_create_sync_task ???
starpu_task_create OK
starpu_task_declare_deps_array OK
starpu_task_deinit OK
starpu_task_destroy OK
starpu_wait_all_tasks starpu_task_wait_for_all
done
starpu_wait_task starpu_task_wait
done
starpu_task_init OK
starpu_submit_task starpu_task_submit
done
starpu_execute_on_each_worker ???
starpu_data_handle OK
starpu_delete_data starpu_data_unregister
done
starpu_malloc_pinned_if_possible
starpu_data_malloc_pinned_if_possible done
starpu_free_pinned_if_possible
starpu_data_free_pinned_if_possible done
starpu_sync_data_with_mem starpu_data_sync_with_mem
done
starpu_sync_data_with_mem_non_blocking
starpu_data_sync_with_mem_non_blocking done
starpu_release_data_from_mem starpu_data_release_from_mem
done
starpu_advise_if_data_is_important
starpu_data_advise_as_important done
starpu_request_data_allocation
starpu_data_request_allocation done
starpu_prefetch_data_on_node starpu_data_prefetch_on_node
done
starpu_data_set_wb_mask OK
starpu_get_sub_data starpu_data_get_sub_data
done
starpu_data_get_child OK
starpu_partition_data starpu_data_partition
done
starpu_unpartition_data starpu_data_unpartition
done
starpu_data_create_children OK
starpu_get_handle_interface_id ???
starpu_test_if_data_is_allocated_on_node
starpu_data_test_if_allocated_on_node done
starpu_data_get_interface_on_node OK
starpu_map_filters OK
starpu_get_block_elemsize starpu_block_get_elemsize
done
starpu_get_block_local_ldy starpu_block_get_local_ldy
done
starpu_get_block_local_ldz starpu_block_get_local_ldz
done
starpu_get_block_local_ptr starpu_block_get_local_ptr
done
starpu_get_block_nx starpu_block_get_nx
done
starpu_get_block_ny starpu_block_get_ny
done
starpu_get_block_nz starpu_block_get_nz
done
starpu_register_block_data starpu_block_data_register
done
starpu_block_filter_func ???
starpu_block_filter_func_vector ???
starpu_canonical_block_filter_bcsr ???
starpu_vertical_block_filter_func ???
starpu_vertical_block_filter_func_csr ???
starpu_get_bcsr_c starpu_bcsr_get_c
done
starpu_get_bcsr_elemsize starpu_bcsr_get_elemsize
done
starpu_get_bcsr_firstentry starpu_bcsr_get_firstentry
done
starpu_get_bcsr_local_colind starpu_bcsr_get_local_colind
done
starpu_get_bcsr_local_nzval starpu_bcsr_get_local_nzval
done
starpu_get_bcsr_local_rowptr starpu_bcsr_get_local_rowptr
done
starpu_get_bcsr_nnz starpu_bcsr_get_nnz
done
starpu_get_bcsr_nrow starpu_bcsr_get_nrow
done
starpu_get_bcsr_r starpu_bcsr_get_r
done
starpu_register_bcsr_data starpu_bcsr_data_register
done
starpu_get_csr_elemsize starpu_csr_get_elemsize
done
starpu_get_csr_firstentry starpu_csr_get_firstentry
done
starpu_get_csr_local_colind starpu_csr_get_local_colind
done
starpu_get_csr_local_nzval starpu_csr_get_local_nzval
done
starpu_get_csr_local_rowptr starpu_csr_get_local_rowptr
done
starpu_get_csr_nnz starpu_csr_get_nnz
done
starpu_get_csr_nrow starpu_csr_get_nrow
done
starpu_register_csr_data starpu_csr_data_register
done
starpu_get_matrix_elemsize starpu_matrix_get_elemsize
done
starpu_get_matrix_local_ld starpu_matrix_get_local_ld
done
starpu_get_matrix_local_ptr starpu_matrix_get_local_ptr
done
starpu_get_matrix_nx starpu_matrix_get_nx
done
starpu_get_matrix_ny starpu_matrix_get_ny
done
starpu_register_matrix_data starpu_matrix_data_register
done
starpu_divide_in_2_filter_func_vector
starpu_vector_divide_in_2_filter_func done
starpu_register_vector_data starpu_vector_data_register
done
starpu_get_vector_elemsize starpu_vector_get_elemsize
done
starpu_get_vector_local_ptr starpu_vector_get_local_ptr
done
starpu_get_vector_nx starpu_vector_get_nx
done
starpu_list_filter_func_vector
starpu_vector_list_filter_func done
starpu_trace_user_event ???
starpu_list_models ???
starpu_perfmodel_debugfilepath OK
starpu_perfmodel_get_arch_name OK
starpu_load_history_debug ???
starpu_force_bus_sampling ???
- [Starpu-devel] Function renaming, Nathalie Furmento, 04/05/2010
- Re: [Starpu-devel] Function renaming, Nathalie Furmento, 04/05/2010
- [Starpu-devel] Huge API Update: Function renaming, Nathalie Furmento, 05/05/2010
- Re: [Starpu-devel] Function renaming, Nathalie Furmento, 05/05/2010
