Archives de la liste
- To: 'Cédric Augonnet' <cedric.augonnet@inria.fr>
- Cc: 'Brendan Barry' <brendan.barry@movidius.com>, starpu-devel@lists.gforge.inria.fr, cristian.cuna@movidius.com, 'David Moloney' <David.Moloney@movidius.com>
- Subject: Re: [Starpu-devel] StarPU configuration issues
- Date: Mon, 9 Aug 2010 13:19:22 +0300
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi Cedric,
I’m using the StarPU version from the SVN repository. The virtual machine is a VMware and it runs on Windows XP. Inside the virtual machine I an running a Suse Linux. Here are the logs from configuration and make check.
Best Regards, Alin Dobre
Hello
Alin, -- Cédric AUGONNET PhD student -- Runtime Team http://runtime.bordeaux.inria.fr/augonnet/ INRIA Bordeaux - LaBRI
[mailto:cedric.augonnet@inria.fr]
On 06/08/2010 12:20, Alin Dobre wrote: Hello,
I am having some trouble with configuring the StarPU. I checked out the StarPU from the SVN link provided, and I followed the steps in the StarPU documentation to configure, make and install (on Linux running in virtual machine). However, when I try to run the matvecmult example (or any other for that matter), I get the “No worker may execute this task” message.
Is there something that was not configured properly? Do I need additional HW to be in my system? (like a specific graphics card for instance?) I tried to install it also on a PC that has an nVidia graphics card and I still get the same message. Is there any other SW package that needs to be installed in order for StarPU to run? (like some additional libraries?)
Best Regards, Alin Dobre |
config.log
Description: Binary data
make_check.log
- [Starpu-devel] StarPU configuration issues, Alin Dobre, 06/08/2010
- Re: [Starpu-devel] StarPU configuration issues, Cédric Augonnet, 06/08/2010
- Re: [Starpu-devel] StarPU configuration issues, Alin Dobre, 09/08/2010
- Re: [Starpu-devel] StarPU configuration issues, Cédric Augonnet, 09/08/2010
- <Suite(s) possible(s)>
- Re: [Starpu-devel] StarPU configuration issues, Samuel Thibault, 13/08/2010
