Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU configuration issues
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Alin Dobre <alin.dobre@movidius.com>
  • Cc: 'Brendan Barry' <brendan.barry@movidius.com>, starpu-devel@lists.gforge.inria.fr, cristian.cuna@movidius.com, 'David Moloney' <David.Moloney@movidius.com>
  • Subject: Re: [Starpu-devel] StarPU configuration issues
  • Date: Fri, 13 Aug 2010 13:39:03 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Alin Dobre, le Fri 06 Aug 2010 13:20:49 +0300, a écrit :
> (on Linux running in virtual machine).
As Cédric said, the given example needs an accelerator. To be able
to use the host machine's accelerator, you'll need to enable some PCI
passthrough mechanism, I don't know to which extend vmware will be able
to do that. After that you can install the drivers in the guest system,
and StarPU will see it, as if it was running in the host system.
Samuel
Haut de le page
