Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Deadlocks
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Deadlocks
  • Date: Tue, 24 Aug 2010 17:16:44 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
My program deadlocks with the following stack trace:
^C
Program received signal SIGINT, Interrupt.
__lll_lock_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:136
136 ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S: No such file or directory.
in ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S
(gdb) bt
#0 __lll_lock_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:136
#1 0x00007ffff566e0e9 in _L_lock_953 () from /lib/libpthread.so.0
#2 0x00007ffff566df0b in __pthread_mutex_lock (mutex=0x7fffe84f3248) at pthread_mutex_lock.c:61
#3 0x00007ffff6c8a289 in starpu_task_declare_deps_array (task=<value optimized out>, ndeps=1, task_array=<value optimized out>) at ../../src/core/dependencies/task_deps.c:84
#4 0x00007ffff6c88dea in _starpu_detect_implicit_data_deps_with_handle (pre_sync_task=0x7fffe84f7fd0, post_sync_task=0x7fffe84f7fd0, handle=0xc77ce0, mode=3) at ../../src/core/dependencies/implicit_data_deps.c:61
#5 0x00007ffff6c88fb9 in _starpu_detect_implicit_data_deps (task=0x7fffe84f7fd0) at ../../src/core/dependencies/implicit_data_deps.c:182
#6 0x00007ffff6c86035 in starpu_task_submit (task=0x7fffe84f7fd0) at ../../src/core/task.c:214
#7 0x00007ffff7bd901d in commandQueueEnqueueBarrierEvent () from /home/shenry/.usr/lib/libsocl.so
#8 0x0000000000417d59 in viennacl::ocl::kernel::start1D(unsigned int const&, unsigned int const&) ()
#9 0x000000000041da5e in viennacl::linalg::inner_prod_impl<float, 1u> ()
#10 0x000000000042a673 in viennacl::vector<float, 1u> viennacl::linalg::solve<viennacl::compressed_matrix<float, 4u>, viennacl::vector<float, 1u> >(viennacl::compressed_matrix<float, 4u> const&, viennacl::vector<float, 1u> const&, viennacl::linalg::cg_tag const&) ()
#11 0x000000000045d0b9 in int run_benchmark<float>() ()
#12 0x000000000041e496 in main ()
If I disable implicit data dependency flag on my data, I don't have this problem. Now the problem is unfinishing task:
^C
pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:162
162 ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S: No such file or directory.
in ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S
(gdb) bt
#0 pthread_cond_wait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/x86_64/pthread_cond_wait.S:162
#1 0x00007ffff6c81d53 in _starpu_wait_job (j=0x7fffd4008920) at ../../src/core/jobs.c:109
#2 0x00007ffff6c82a1c in starpu_task_submit (task=0x7fffd40087c0) at ../../src/core/task.c:247
#3 0x00007ffff7bd865b in commandQueueEnqueueBarrierEvent (cq=0x7fffe80b0250, ev=0x7fffd4008790) at ../lib/helpers_commandqueue.c.inc:62
#4 0x00007ffff7bd86a1 in commandQueueEnqueueEvent (cq=0x7fffe80b0250, ev=0x7fffd4008790) at ../lib/helpers_commandqueue.c.inc:72
#5 0x00007ffff7bda9a2 in soclEnqueueReadBuffer (cq=0x7fffe80b0250, buffer=0x7fffebb970e0, blocking=1, offset=0, cb=4, ptr=0x7fffffffd52c, num_events=0, events=0x0, event=0x0) at ../lib/cl_enqueuereadbuffer.c.inc:125
#6 0x000000000042a897 in viennacl::vector<float, 1u> viennacl::linalg::solve<viennacl::compressed_matrix<float, 4u>, viennacl::vector<float, 1u> >(viennacl::compressed_matrix<float, 4u> const&, viennacl::vector<float, 1u> const&, viennacl::linalg::cg_tag const&) ()
#7 0x000000000045d0b9 in int run_benchmark<float>() ()
#8 0x000000000041e496 in main ()
How can I debug this to understand why my task never terminates?
Cheers
Sylvain
  • [Starpu-devel] Deadlocks, Sylvain HENRY, 24/08/2010
Haut de le page
