Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU SVN and OpenCL on CPU
- Date: Wed, 23 Feb 2011 16:46:06 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, I have tried to get StarPU trunk from SVN to work for OpenCL on the CPU, but have met with no success. Is this not expected to be a usable approach? I have made one change to StarPU code itself, to allow CPU OpenCL devices to provide cl_device_type device_type = CL_DEVICE_TYPE_CPU|CL_DEVICE_TYPE_GPU|CL_DEVICE_TYPE_ACCELERATOR; in the init function of the OpenCL driver. I built StarPU as follows: ./configure --with-opencl-include-dir=/home/george/Desktop/ati-stream-sdk-v2.3-lnx32/include/ --with-opencl-lib-dir=/home/george/Desktop/ati-stream-sdk-v2.3-lnx32/lib/x86 --prefix=/home/george --disable-cpu --enable-debug --enable-verbose Here is a log of the attempt to run one of the examples; It hangs, and I aborted it with Ctrl-C. george@george-VirtualBox:~/Desktop/starpu/trunk$ examples/basic_examples/vector_scal BEFORE : First element was 1.000000 [starpu][_starpu_opencl_init] Initialising OpenCL [starpu][_starpu_opencl_init] Platforms detected: 1 [starpu][_starpu_opencl_init] Platform: ATI Stream - Advanced Micro Devices, Inc. [starpu][_starpu_opencl_init] 1 devices detected [starpu][load_sched_policy] Use eager scheduler (greedy policy) [starpu][_starpu_launch_drivers] initialising worker 0 [starpu][_starpu_opencl_init_context] Initialising context for dev 0 [starpu][_starpu_opencl_get_device_name] Device 0 : [Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz] [starpu][_starpu_opencl_worker] OpenCL (Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz) dev id 0 thread is ready to run on CPU 0 ! [starpu][_starpu_opencl_locate_file] Trying to locate <examples/basic_examples/vector_scal_opencl_kernel.cl> [starpu][starpu_opencl_load_opencl_from_file] Source file name : <examples/basic_examples/vector_scal_opencl_kernel.cl> [starpu][_starpu_opencl_load_program_source] OpenCL kernel </* StarPU --- Runtime system for heterogeneous multicore architectures. * * Copyright (C) 2010 Centre National de la Recherche Scientifique * * StarPU is free software; you can redistribute it and/or modify * it under the terms of the GNU Lesser General Public License as published by * the Free Software Foundation; either version 2.1 of the License, or (at * your option) any later version. * * StarPU is distributed in the hope that it will be useful, but * WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. * * See the GNU Lesser General Public License in COPYING.LGPL for more details. */ __kernel void vector_mult_opencl(__global float* val, int nx, float factor) { const int i = get_global_id(0); if (i < nx) { val[i] *= 11.0f+factor; } } > Cheers, George ^C Compilation terminated. |
- [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Sylvain HENRY, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Sylvain HENRY, 24/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 24/02/2011
- Message indisponible
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Samuel Thibault, 25/02/2011
