Archives de la liste
- To: George Russell <george@codeplay.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU SVN and OpenCL on CPU
- Date: Thu, 24 Feb 2011 11:33:53 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, See the attached patch. However, I'm using Git and I don't know if this patch is compatible with other patch systems. If you want to apply it with Git: git svn clone --stdlayout svn://scm.gforge.inria.fr/svn/starpu cd starpu git apply blabla.patch Cheers Sylvain Le 23/02/2011 21:40, George Russell a écrit : 4D6570A2.80108@codeplay.com"> Hi, |
Date: Thu, 24 Feb 2011 11:10:01 +0100
Subject: [PATCH] OpenCL CPU devices patch
src/datawizard/copy_driver.c | 21 +++++---
src/datawizard/interfaces/variable_interface.c | 65 ++++++++++++++++++-----
src/drivers/opencl/driver_opencl.c | 29 ++++++++++-
src/drivers/opencl/driver_opencl.h | 6 ++
4 files changed, 97 insertions(+), 24 deletions(-)
diff --git a/src/datawizard/copy_driver.c b/src/datawizard/copy_driver.c
index 48309fe..f6fd3f7 100644
--- a/src/datawizard/copy_driver.c
+++ b/src/datawizard/copy_driver.c
@@ -290,10 +290,11 @@ void
_starpu_driver_wait_request_completion(starpu_async_channel *async_channel
#ifdef STARPU_USE_OPENCL
case STARPU_OPENCL_RAM:
- if ((*async_channel).opencl_event == NULL) STARPU_ABORT();
- cl_int err = clWaitForEvents(1,
&((*async_channel).opencl_event));
- if (err != CL_SUCCESS) STARPU_OPENCL_REPORT_ERROR(err);
- clReleaseEvent((*async_channel).opencl_event);
+ if ((*async_channel).opencl_event != NULL) {
+ cl_int err = clWaitForEvents(1,
+ if (err != CL_SUCCESS) STARPU_OPENCL_REPORT_ERROR(err);
+ clReleaseEvent((*async_channel).opencl_event);
break;
#endif
@@ -328,10 +329,14 @@ unsigned
_starpu_driver_test_request_completion(starpu_async_channel *async_chan
cl_int event_status;
cl_event opencl_event = (*async_channel).opencl_event;
- if (opencl_event == NULL) STARPU_ABORT();
- cl_int err = clGetEventInfo(opencl_event,
CL_EVENT_COMMAND_EXECUTION_STATUS, sizeof(event_status), &event_status, NULL);
- success = (event_status == CL_COMPLETE);
+ if (opencl_event != NULL) {
+ cl_int err = clGetEventInfo(opencl_event,
+ success = (event_status == CL_COMPLETE);
+ else {
+ success = 1;
break;
#endif
diff --git a/src/datawizard/interfaces/variable_interface.c
b/src/datawizard/interfaces/variable_interface.c
index 4a4fb0d..7cdedff 100644
--- a/src/datawizard/interfaces/variable_interface.c
+++ b/src/datawizard/interfaces/variable_interface.c
@@ -54,8 +54,8 @@ static const struct starpu_data_copy_methods
variable_copy_data_methods_s = {
.ram_to_opencl = copy_ram_to_opencl,
.opencl_to_ram = copy_opencl_to_ram,
- .opencl_to_opencl = copy_opencl_to_opencl,
- .ram_to_opencl_async = copy_ram_to_opencl_async,
+ .opencl_to_opencl = NULL, //copy_opencl_to_opencl,
+ .ram_to_opencl_async = copy_ram_to_opencl_async,
.opencl_to_ram_async = copy_opencl_to_ram_async,
#endif
.cuda_to_spu = NULL,
@@ -218,13 +218,13 @@ static ssize_t allocate_variable_buffer_on_node(void
*interface_, uint32_t dst_n
- int ret;
- void *ptr;
- ret = _starpu_opencl_allocate_memory(&ptr,
elemsize, CL_MEM_READ_WRITE);
- addr = (uintptr_t)ptr;
- if (ret) {
- fail = 1;
+ int ret;
+ void *ptr;
+ ret = _starpu_opencl_allocate_memory(&ptr, elemsize,
CL_MEM_READ_WRITE);
+ addr = (uintptr_t)ptr;
+ if (ret) {
+ fail = 1;
break;
#endif
@@ -257,9 +257,9 @@ static void free_variable_buffer_on_node(void *interface,
uint32_t node)
break;
#endif
- case STARPU_OPENCL_RAM:
clReleaseMemObject((void*)STARPU_VARIABLE_GET_PTR(interface));
- break;
+ case STARPU_OPENCL_RAM:
+ clReleaseMemObject((void*)STARPU_VARIABLE_GET_PTR(interface));
+ break;
#endif
default:
assert(0);
@@ -350,11 +350,29 @@ static int copy_ram_to_opencl_async(void
*src_interface, unsigned src_node __att
starpu_variable_interface_t *dst_variable = dst_interface;
int err,ret;
+ cl_device_type typ = _starpu_opencl_device_type();
+ cl_context ctx = _starpu_opencl_context();
+ if (typ == CL_DEVICE_TYPE_CPU) {
+ clReleaseMemObject((void*)(STARPU_VARIABLE_GET_PTR(dst_variable)));
+ dst_variable->ptr = (uintptr_t)clCreateBuffer(ctx, CL_MEM_USE_HOST_PTR
| CL_MEM_READ_WRITE, src_variable->elemsize, (char*)src_variable->ptr, &err);
+ if (STARPU_UNLIKELY(err))
+ STARPU_OPENCL_REPORT_ERROR(err);
+ if (_event != NULL)
+ *(cl_event*)_event = NULL;
+ ret = 0;
+ else {
err =
_starpu_opencl_copy_ram_to_opencl_async_sync((void*)src_variable->ptr,
(cl_mem)dst_variable->ptr, src_variable->elemsize,
0,
(cl_event*)_event, &ret);
STARPU_TRACE_DATA_COPY(src_node, dst_node, src_variable->elemsize);
return ret;
@@ -364,14 +382,33 @@ static int copy_opencl_to_ram_async(void
starpu_variable_interface_t *src_variable = src_interface;
- int err, ret;
+ int ret;
- err =
_starpu_opencl_copy_opencl_to_ram_async_sync((cl_mem)src_variable->ptr,
(void*)dst_variable->ptr, src_variable->elemsize,
+ cl_command_queue cq = _starpu_opencl_queue();
+ cl_int err;
+ void * ptr = clEnqueueMapBuffer(cq,
(cl_mem)STARPU_VARIABLE_GET_PTR(src_variable), CL_TRUE, CL_MAP_READ |
CL_MAP_WRITE, 0, src_variable->elemsize, 0, NULL, NULL, &err);
+ memcpy(dst_variable->ptr, ptr, src_variable->elemsize);
+ clEnqueueUnmapMemObject(cq, (cl_mem)src_variable->ptr, ptr, 0, NULL,
NULL);
+ //Nothing to do
+ ret = 0;
+ else {
+ int err;
+ err =
0,
return ret;
diff --git a/src/drivers/opencl/driver_opencl.c
b/src/drivers/opencl/driver_opencl.c
index 3e7fac8..6a27d44 100644
--- a/src/drivers/opencl/driver_opencl.c
+++ b/src/drivers/opencl/driver_opencl.c
@@ -119,7 +119,10 @@ cl_int _starpu_opencl_init_context(int devid)
// Create a compute context
err = 0;
- contexts[devid] = clCreateContext(NULL, 1, &devices[devid], NULL,
NULL, &err);
+ cl_platform_id platform;
+ clGetDeviceInfo(devices[devid], CL_DEVICE_PLATFORM,
sizeof(cl_platform_id), &platform, NULL);
+ cl_context_properties props[] = {CL_CONTEXT_PLATFORM,
(cl_context_properties)platform, 0};
+ contexts[devid] = clCreateContext(props, 1, &devices[devid], NULL,
NULL, &err);
// Create queue for the given device
@@ -210,6 +213,28 @@ cl_int _starpu_opencl_copy_ram_to_opencl(void *ptr,
cl_mem buffer, size_t size,
return CL_SUCCESS;
+cl_device_id _starpu_opencl_device(void) {
+ struct starpu_worker_s *worker = _starpu_get_local_worker_key();
+ return devices[worker->devid];
+cl_context _starpu_opencl_context(void) {
+ return contexts[worker->devid];
+cl_command_queue _starpu_opencl_queue(void) {
+ return queues[worker->devid];
+cl_device_type _starpu_opencl_device_type(void) {
+ cl_device_id dev = _starpu_opencl_device();
+ cl_device_type typ;
+ clGetDeviceInfo(dev, CL_DEVICE_TYPE, sizeof(cl_device_type), &typ, NULL);
+ return typ;
cl_int _starpu_opencl_copy_opencl_to_ram_async_sync(cl_mem buffer, void
*ptr, size_t size, size_t offset, cl_event *event, int *ret)
cl_int err;
@@ -292,7 +317,7 @@ void _starpu_opencl_init(void)
if (!init_done) {
cl_platform_id platform_id[STARPU_OPENCL_PLATFORM_MAX];
cl_uint nb_platforms;
- cl_device_type device_type =
CL_DEVICE_TYPE_GPU|CL_DEVICE_TYPE_ACCELERATOR;
+ cl_device_type device_type =
CL_DEVICE_TYPE_GPU|CL_DEVICE_TYPE_ACCELERATOR | CL_DEVICE_TYPE_CPU;
cl_int err;
unsigned int i;
diff --git a/src/drivers/opencl/driver_opencl.h
b/src/drivers/opencl/driver_opencl.h
index bbe6a89..44bdd9e 100644
--- a/src/drivers/opencl/driver_opencl.h
+++ b/src/drivers/opencl/driver_opencl.h
@@ -68,5 +68,11 @@ void _starpu_opencl_init(void);
extern
void *_starpu_opencl_worker(void *);
+cl_device_id _starpu_opencl_device(void);
+cl_context _starpu_opencl_context(void);
+cl_device_type _starpu_opencl_device_type(void);
+cl_command_queue _starpu_opencl_queue(void);
#endif // STARPU_USE_OPENCL
#endif // __DRIVER_OPENCL_H__
1.7.4.1
- [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Sylvain HENRY, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 23/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Sylvain HENRY, 24/02/2011
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, George Russell, 24/02/2011
- Message indisponible
- Re: [Starpu-devel] StarPU SVN and OpenCL on CPU, Samuel Thibault, 25/02/2011
