Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Building StarPU from SVN on OSX [patch]
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Building StarPU from SVN on OSX [patch]
  • Date: Thu, 24 Feb 2011 15:21:58 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I have attached a patch to get StarPU OpenCL working (partly!) on OSX 10.6
This patch primarily does two things; it fixed the include paths for the CL headers in C code (these are, for some reason, different on OSX), and it ifdefs out the cpu_set_t code on OSX (as is done on Windows) as that type seems not to be supported on OSX. (it also fixed some compilation errors re INT_MAX by including limits.h)
Note that the changes I have made to configure.ac are essentially broken; It needs to conditionally handle OSX (which I don't know how to do, especially). However, there are ~3 things to note: The header test needed to be changed, which I have done; but it should test the CL/cl.h on non OSX, and OpenCL/opencl.h on OSX. I did not get the library check to work on OSX; I just forced the enable_opencl to be on. At least for OSX 10.6, OpenCL is supplied with the OS, and in a fixed location. So, OpenCL could be enabled on OSX 10.6 by default, unless explicitly disabled. I did however, add the "-framework OpenCL" to the LD_FLAGS to get it to link. Again, this should be OSX specific.
I forced the target to i686 to get the pthread configure check to pass; I believe this results in the compilation of a 32bit executable. I guess StarPU will simply not build for X86_64?
Now, the bad part: It seems broken, in the same way as the ATI CPU OpenCL was e.g. it appears to hang/deadlock in the same place.
./configure --target=i686-apple-darwin10 --with-opencl-include-dir=/System/Library/Frameworks/OpenCL.framework/Versions/A/Headers/
imac:StarPU grrussel$ examples/basic_examples/vector_scal
BEFORE : First element was 1.000000
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 1
[starpu][_starpu_opencl_init] Platform: Apple - Apple
[starpu][_starpu_opencl_init]   1 devices detected
Current configuration does not match the performance model (OpenCL: (stored) 0 != (current) 1), recalibrating...[starpu][benchmark_all_gpu_devices] Benchmarking the speed of the bus
[starpu][_starpu_opencl_init_context] Initialising context for dev 0
[starpu][_starpu_opencl_deinit_context] De-initialising context for dev 0
[starpu][measure_bandwidth_between_host_and_dev] BANDWIDTH GPU 0 CPU 0 - htod 16782.898438 - dtoh 15493.679688 - 22841.186270
[starpu][measure_bandwidth_between_host_and_dev] BANDWIDTH GPU 0 CPU 1 - htod 15700.906250 - dtoh 15363.750000 - 21967.322803
[starpu][measure_bandwidth_between_host_and_dev] BANDWIDTH GPU 0 BEST CPU 0
[starpu][benchmark_all_gpu_devices] Benchmarking the speed of the bus is done.
done
[starpu][load_sched_policy] Use eager scheduler (greedy policy)
[starpu][_starpu_launch_drivers] initialising worker 0
[starpu][_starpu_opencl_get_device_name] Device 0 : [GeForce 9400]
[starpu][_starpu_opencl_worker] OpenCL (GeForce 9400) dev id 0 thread is ready to run on CPU 0 !
[starpu][_starpu_opencl_locate_file] Trying to locate <examples/basic_examples/vector_scal_opencl_kernel.cl>
[starpu][starpu_opencl_load_opencl_from_file] Source file name : <examples/basic_examples/vector_scal_opencl_kernel.cl>
[starpu][_starpu_opencl_load_program_source] OpenCL kernel </* StarPU --- Runtime system for heterogeneous multicore architectures.
 * Copyright (C) 2010  Centre National de la Recherche Scientifique
 * StarPU is free software; you can redistribute it and/or modify
 * it under the terms of the GNU Lesser General Public License as published by
 * the Free Software Foundation; either version 2.1 of the License, or (at
 * your option) any later version.
 * StarPU is distributed in the hope that it will be useful, but
 * WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 * See the GNU Lesser General Public License in COPYING.LGPL for more details.
__kernel void vector_mult_opencl(__global float* val, int nx, float factor)
        const int i = get_global_id(0);
        if (i < nx) {
                val[i] *= factor;
^C
Cheers,
George
On 23/02/2011 21:47, George Russell wrote:
4D657251.3070402@codeplay.com"> Hi,
as a follow up to this;
The autogen.sh script invokes libtool on OSX, but that should (on OSX) be glibtool
The OpenCL checks don't work on OSX, for two reasons; the includes are different, and the library linking system is also different.
The includes in C code to use OpenCL should be
#ifdef __APPLE__
#include <OpenCL/opencl.h>
#else
#include <CL/cl.h>
#endif
The command to compile (and link) the code uses OSX's framework switch to gcc e.g. gcc -o foo foo.c -framework OpenCL
Knowing that, however, is not much help to me in getting a working configure.ac ;-)
Cheers,
George
On 23/02/2011 17:31, George Russell wrote:
4D653678.7080007@codeplay.com"> Hi,
I was also attempting to build StarPU from SVN on OSX.
However, on running the autogen.sh, I get the following output:
imac:StarPU grrussel$ sh autogen.sh
libtool: unknown option character `-' in: --version
Usage: libtool -static [-] file [...] [-filelist listfile[,dirname]] [-arch_only arch] [-sacLT]
Usage: libtool -dynamic [-] file [...] [-filelist listfile[,dirname]] [-arch_only arch] [-o output] [-install_name name] [-compatibility_version #] [-current_version #] [-seg1addr 0x#] [-segs_read_only_addr 0x#] [-segs_read_write_addr 0x#] [-seg_addr_table <filename>] [-seg_addr_table_filename <file_system_path>] [-all_load] [-noall_load]
Libtool is missing, please install it.
It looks like I have the wrong libtool installed? It would be the default from the OSX developer tools.
Is there any special care needed in compiling on OSX?
Cheers,
George
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Index: include/starpu_opencl.h
--- include/starpu_opencl.h (revision 3238)
+++ include/starpu_opencl.h (working copy)
@@ -19,7 +19,11 @@
#define __STARPU_OPENCL_H__
#ifdef STARPU_USE_OPENCL
+#ifdef __APPLE__
+#include <OpenCL/opencl.h>
+#else
#include <CL/cl.h>
+#endif
#ifdef __cplusplus
extern "C" {
Index: src/core/workers.h
--- src/core/workers.h (revision 3238)
+++ src/core/workers.h (working copy)
@@ -79,8 +79,10 @@
char name[32];
#ifndef STARPU_HAVE_WINDOWS
+#ifndef __APPLE__
cpu_set_t initial_cpu_set;
cpu_set_t current_cpu_set;
+#endif /* __APPLE__ */
#endif /* STARPU_HAVE_WINDOWS */
#ifdef STARPU_HAVE_HWLOC
hwloc_cpuset_t initial_hwloc_cpu_set;
@@ -96,7 +98,9 @@
int combined_workerid[STARPU_NMAXWORKERS];
+#ifndef __APPLE__
cpu_set_t cpu_set;
hwloc_cpuset_t hwloc_cpu_set;
Index: src/core/topology.c
--- src/core/topology.c (revision 3238)
+++ src/core/topology.c (working copy)
@@ -723,11 +723,13 @@
workerarg->memory_node = memory_node;
+#ifndef __APPLE__
/* Save the initial cpuset */
CPU_ZERO(&workerarg->initial_cpu_set);
CPU_SET(workerarg->bindid, &workerarg->initial_cpu_set);
CPU_ZERO(&workerarg->current_cpu_set);
CPU_SET(workerarg->bindid, &workerarg->current_cpu_set);
Index: src/core/combined_workers.c
--- src/core/combined_workers.c (revision 3238)
+++ src/core/combined_workers.c (working copy)
@@ -114,7 +114,9 @@
/* Note that we maintain both the cpu_set and the hwloc_cpu_set so
that
* the application is not forced to use hwloc when it is available. */
+#ifndef __APPLE__
CPU_ZERO(&combined_worker->cpu_set);
+#endif
@@ -125,6 +127,7 @@
int id = workerid_array[i];
+#ifndef __APPLE__
#ifdef CPU_OR
CPU_OR(&combined_worker->cpu_set,
@@ -136,6 +139,7 @@
CPU_SET(j, &combined_worker->cpu_set);
#endif
Index: src/datawizard/copy_driver.h
--- src/datawizard/copy_driver.h (revision 3238)
+++ src/datawizard/copy_driver.h (working copy)
@@ -30,8 +30,12 @@
#endif
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
#endif
+#endif
struct starpu_data_request_s;
struct starpu_data_replicate_s;
Index: src/drivers/opencl/driver_opencl.h
--- src/drivers/opencl/driver_opencl.h (revision 3238)
+++ src/drivers/opencl/driver_opencl.h (working copy)
@@ -24,7 +24,11 @@
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
+#endif
extern
int _starpu_opencl_init_context(int devid);
Index: tests/datawizard/increment_redux_v2.c
--- tests/datawizard/increment_redux_v2.c (revision 3238)
+++ tests/datawizard/increment_redux_v2.c (working copy)
@@ -20,8 +20,12 @@
#include <cuda.h>
#endif
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
#endif
+#endif
static unsigned var = 0;
Index: tests/datawizard/write_only_tmp_buffer.c
--- tests/datawizard/write_only_tmp_buffer.c (revision 3238)
+++ tests/datawizard/write_only_tmp_buffer.c (working copy)
@@ -26,7 +26,13 @@
starpu_data_handle v_handle;
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
+#endif
#include <starpu_opencl.h>
static void opencl_codelet_null(void *descr[], __attribute__ ((unused)) void
*_args)
Index: tests/datawizard/sync_and_notify_data_opencl.c
--- tests/datawizard/sync_and_notify_data_opencl.c (revision 3238)
+++ tests/datawizard/sync_and_notify_data_opencl.c (working copy)
@@ -17,7 +17,12 @@
#include <starpu.h>
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
+#endif
extern struct starpu_opencl_program opencl_code;
Index: tests/datawizard/manual_reduction.c
--- tests/datawizard/manual_reduction.c (revision 3238)
+++ tests/datawizard/manual_reduction.c (working copy)
@@ -19,8 +19,12 @@
#include <cuda.h>
#endif
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
#endif
+#endif
#define INIT_VALUE 42
#define NTASKS 10000
Index: tests/datawizard/increment_redux.c
--- tests/datawizard/increment_redux.c (revision 3238)
+++ tests/datawizard/increment_redux.c (working copy)
@@ -21,8 +21,12 @@
#include <cuda.h>
#endif
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
#endif
+#endif
Index: configure.ac
--- configure.ac (revision 3238)
+++ configure.ac (working copy)
@@ -258,6 +258,7 @@
AC_HAVE_LIBRARY([cuda],[],[have_valid_cuda=no])
# To detect if we have a recent enough CUDA lib
AC_HAVE_LIBRARY([cudart],[],[have_valid_cuda=no])
@@ -443,7 +444,7 @@
# do we have a valid OpenCL setup ?
have_valid_opencl=yes
- AC_CHECK_HEADER([CL/cl.h],,[have_valid_opencl=no])
+ AC_CHECK_HEADER([OpenCL/opencl.h],,[have_valid_opencl=no])
# we are looking for the proper option in LDFLAGS, so we save the
# current value of LDFLAGS so that we can add new things in it and
@@ -456,7 +457,7 @@
fi
if test -d "$opencl_lib_dir"; then
- LDFLAGS="${SAVED_LDFLAGS} -L$opencl_lib_dir "
+ LDFLAGS="${SAVED_LDFLAGS} -L$opencl_lib_dir -framework OpenCL"
fi
AC_HAVE_LIBRARY([OpenCL],[],[have_valid_opencl=no])
@@ -466,7 +467,8 @@
fi
# now we enable OpenCL if and only if a proper setup is available
- enable_opencl=$have_valid_opencl
+ #enable_opencl=$have_valid_opencl
+ enable_opencl=yes
fi
AC_MSG_CHECKING(whether OpenCL should be used)
Index: autogen.sh
--- autogen.sh (revision 3238)
+++ autogen.sh (working copy)
@@ -16,7 +16,7 @@
# See the GNU Lesser General Public License in COPYING.LGPL for more details.
-if ! libtool --version > /dev/null
+if ! glibtool --version > /dev/null
then
echo "Libtool is missing, please install it."
exit 1
Index: examples/cholesky/cholesky_implicit.c
--- examples/cholesky/cholesky_implicit.c (revision 3238)
+++ examples/cholesky/cholesky_implicit.c (working copy)
@@ -17,7 +17,7 @@
#include "cholesky.h"
+#include <limits.h>
* Create the codelets
Index: examples/mult/sgemm.c
--- examples/mult/sgemm.c (revision 3238)
+++ examples/mult/sgemm.c (working copy)
@@ -14,6 +14,6 @@
details.
#include "simple.h"
#include "xgemm.c"
Index: examples/mult/xgemm.c
--- examples/mult/xgemm.c (revision 3238)
+++ examples/mult/xgemm.c (working copy)
@@ -15,7 +15,7 @@
details.
#include <string.h>
#include <math.h>
#include <sys/types.h>
Index: examples/mandelbrot/mandelbrot.c
--- examples/mandelbrot/mandelbrot.c (revision 3238)
+++ examples/mandelbrot/mandelbrot.c (working copy)
@@ -14,7 +14,7 @@
details.
#include <starpu.h>
Index: examples/incrementer/incrementer_kernels_opencl.c
--- examples/incrementer/incrementer_kernels_opencl.c (revision 3238)
+++ examples/incrementer/incrementer_kernels_opencl.c (working copy)
@@ -17,8 +17,11 @@
#include <starpu.h>
+#ifdef __APPLE__
+#else
#include <CL/cl.h>
+#endif
extern struct starpu_opencl_program opencl_program;
void opencl_codelet(void *descr[], void *_args)
Haut de le page
