Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Installation of starpu on macbook
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Installation of starpu on macbook
  • Date: Tue, 1 Mar 2011 12:02:57 +0530
  • Bcc:
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Sir,
I have been trying to install starpu 0.4 on my 13 inch macbook pro. However, there are problems:
First for configure step I commented -march = i686. This made configure work.
But now I am getting the following errors during make
core/perfmodel/perfmodel_bus.c: In function ‘benchmark_all_gpu_devices’:
core/perfmodel/perfmodel_bus.c:398: error: ‘cpu_set_t’ undeclared (first use in this function)
core/perfmodel/perfmodel_bus.c:398: error: (Each undeclared identifier is reported only once
core/perfmodel/perfmodel_bus.c:398: error: for each function it appears in.)
core/perfmodel/perfmodel_bus.c:398: error: expected ‘;’ before ‘former_process_affinity’
core/perfmodel/perfmodel_bus.c:399: warning: implicit declaration of function ‘sched_getaffinity’
core/perfmodel/perfmodel_bus.c:399: error: ‘former_process_affinity’ undeclared (first use in this function)
core/perfmodel/perfmodel_bus.c:430: warning: implicit declaration of function ‘sched_setaffinity’
make[2]: *** [libstarpu_la-perfmodel_bus.lo] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Please note that I have installed hwloc software also. Could you help me in this regard.
The config.log and config.status files are attached.
With Thanks and Regards
Mrs Rakhi Hemani
Senior Lecturer
CS/IT, JIIT NOIDA
Extension - 261
x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x—x---x---x---x---x---x---x---x---x---x---x---x---x---x
Disclaimer: This message and any files transmitted with it are not necessarily the views of JIIT. This message is confidential and intended solely for the use of the individual or entity to whom it is addressed. If you are not the intended recipient or agent responsible for delivering to the intended recipient, you are hereby notified that any use, review, dissemination, distribution or copying is strictly prohibited. The Institute is not responsible for the Viruses, Trojans, Spy wares present in attachments, if any, and it accepts no liability for any damage caused by the same.
Attachment: config.status
Description: Binary data
Attachment: config.log
Haut de le page
