Archives de la liste
- To: "rakhi.hemani" <rakhi.hemani@jiit.ac.in>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Installation of starpu on macbook
- Date: Tue, 01 Mar 2011 08:16:54 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear mrs Hermani, Thanks for your report. We have fixed the compilation on Mac recently, so that if you take our last svn tarball, it should compile and work fine. It is available at http://starpu.gforge.inria.fr/testing/starpu-nightly-latest.tar.gz Concerning hwloc, StarPU relies on pkg-config to detect where hwloc is installed. If you type "pkg-config hwloc --libs" this should for instance tell you the link flags required by hwloc, otherwise it will tell you that pkg-config cannot find hwloc, in that case you should update PKG_CONFIG_PATH. Best, Cédric On 01/03/2011 07:32, rakhi.hemani wrote: Dear Sir, I have been trying to install starpu 0.4 on my 13 inch macbook pro. However, there are problems: First for configure step I commented -march = i686. This made configure work. But now I am getting the following errors during make core/perfmodel/perfmodel_bus.c: In function ‘benchmark_all_gpu_devices’: core/perfmodel/perfmodel_bus.c:398: error: ‘cpu_set_t’ undeclared (first use in this function) core/perfmodel/perfmodel_bus.c:398: error: (Each undeclared identifier is reported only once core/perfmodel/perfmodel_bus.c:398: error: for each function it appears in.) core/perfmodel/perfmodel_bus.c:398: error: expected ‘;’ before ‘former_process_affinity’ core/perfmodel/perfmodel_bus.c:399: warning: implicit declaration of function ‘sched_getaffinity’ core/perfmodel/perfmodel_bus.c:399: error: ‘former_process_affinity’ undeclared (first use in this function) core/perfmodel/perfmodel_bus.c:430: warning: implicit declaration of function ‘sched_setaffinity’ make[2]: *** [libstarpu_la-perfmodel_bus.lo] Error 1 make[1]: *** [all-recursive] Error 1 make: *** [all-recursive] Error 1 Please note that I have installed hwloc software also. Could you help me in this regard. The config.log and config.status files are attached. With Thanks and Regards ************************************************************************* Mrs Rakhi Hemani Senior Lecturer CS/IT, JIIT NOIDA Extension - 261 ************************************************************************* x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x—x---x---x---x---x---x---x---x---x---x---x---x---x---x Disclaimer: This message and any files transmitted with it are not necessarily the views of JIIT. This message is confidential and intended solely for the use of the individual or entity to whom it is addressed. If you are not the intended recipient or agent responsible for delivering to the intended recipient, you are hereby notified that any use, review, dissemination, distribution or copying is strictly prohibited. The Institute is not responsible for the Viruses, Trojans, Spy wares present in attachments, if any, and it accepts no liability for any damage caused by the same. x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x---x—x---x---x---x---x---x---x---x---x---x---x---x---x---x _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] Installation of starpu on macbook, rakhi.hemani, 01/03/2011
- Re: [Starpu-devel] Installation of starpu on macbook, Cédric Augonnet, 01/03/2011
