Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Getting StarPU running
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Marcus Holm <marcus.holm@it.uu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Getting StarPU running
  • Date: Mon, 7 Mar 2011 17:54:01 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Marcus Holm, le Tue 01 Mar 2011 12:10:31 +0100, a écrit :
> The assert STARPU_ASSERT(n == 1) fails in
> load_bus_latency_file_content() on line 679. I've done a little
> investigation, and can say that the sampling file "latency.hostname"
> has 10 elements and the function reads them all perfectly. But
> STARPU_MAXNODES is set to 13 in common/config.h. When I changed it to
> 10, then hello_world works, and so do the rest of the basic_examples.
Oops. That value is indeed relatively hardcoded, and can change
depending whether you have cuda or opencl enabled. I have made the
parser cleaner: when the number changes (and thus the NUMA configuration
changes), benchmarking is now automatically performed again once.
Thanks for the report,
Samuel
Haut de le page
