Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Compiling starpu on Mac OS
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Cc: Raymond.Namyst@labri.fr
  • Subject: [Starpu-devel] Compiling starpu on Mac OS
  • Date: Thu, 31 Mar 2011 15:17:37 +0530
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=WiraE7ezIac/I6MZESdG7KLC5IAy37n0nHUmpg7Z5oiErcyWsA5Rk6x8J+DpU7DElp waN/R9xehjl7UqY3qGlkkPXsj1QWDYR/ohuOgI0eyhpLmcvDXYf3EhHKwa/FNMgp6+Og BZ5uS1cS6AHmTA+uSeOaQtGg3yQ79BeyFaask=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Machine: MacBook Pro running Snow Leopard.
nvcc -V says:
oggy:starpu alleon$ nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2010 NVIDIA Corporation
Built on Thu_Nov_11_15:26:50_PST_2010
Cuda compilation tools, release 3.2, V0.2.1221
I would like to evaluate starpu. I just grab the sources from svn (rev 3420)
autogen.sh && ./configure && make
Compilation is going file until the link which fails.
I noticed that I am using CUDA and not OpenCL. Is that OK ?
Then what am I doing wrong ?
Thanks for your help.
Guillaume
libtool: link: gcc -dynamiclib -o .libs/libstarpu.0.dylib
.libs/libstarpu_la-barrier.o .libs/libstarpu_la-hash.o
.libs/libstarpu_la-htable32.o .libs/libstarpu_la-rwlock.o
.libs/libstarpu_la-starpu_spinlock.o .libs/libstarpu_la-timing.o
.libs/libstarpu_la-fxt.o .libs/libstarpu_la-utils.o
.libs/libstarpu_la-jobs.o .libs/libstarpu_la-task.o
.libs/libstarpu_la-task_bundle.o .libs/libstarpu_la-workers.o
.libs/libstarpu_la-combined_workers.o .libs/libstarpu_la-topology.o
.libs/libstarpu_la-debug.o .libs/libstarpu_la-errorcheck.o
.libs/libstarpu_la-progress_hook.o .libs/libstarpu_la-cg.o
.libs/libstarpu_la-dependencies.o
.libs/libstarpu_la-implicit_data_deps.o .libs/libstarpu_la-tags.o
.libs/libstarpu_la-task_deps.o .libs/libstarpu_la-htable.o
.libs/libstarpu_la-data_concurrency.o
.libs/libstarpu_la-perfmodel_history.o
.libs/libstarpu_la-perfmodel_bus.o .libs/libstarpu_la-perfmodel.o
.libs/libstarpu_la-regression.o .libs/libstarpu_la-sched_policy.o
.libs/libstarpu_la-priorities.o .libs/libstarpu_la-parallel_task.o
.libs/libstarpu_la-eager_central_policy.o
.libs/libstarpu_la-eager_central_priority_policy.o
.libs/libstarpu_la-work_stealing_policy.o
.libs/libstarpu_la-deque_modeling_policy_data_aware.o
.libs/libstarpu_la-heft.o .libs/libstarpu_la-random_policy.o
.libs/libstarpu_la-stack_queues.o .libs/libstarpu_la-deque_queues.o
.libs/libstarpu_la-fifo_queues.o
.libs/libstarpu_la-detect_combined_workers.o
.libs/libstarpu_la-parallel_heft.o
.libs/libstarpu_la-parallel_greedy.o
.libs/libstarpu_la-driver_common.o .libs/libstarpu_la-memory_nodes.o
.libs/libstarpu_la-write_back.o .libs/libstarpu_la-coherency.o
.libs/libstarpu_la-data_request.o .libs/libstarpu_la-progress.o
.libs/libstarpu_la-copy_driver.o .libs/libstarpu_la-filters.o
.libs/libstarpu_la-sort_data_handles.o .libs/libstarpu_la-memalloc.o
.libs/libstarpu_la-footprint.o .libs/libstarpu_la-datastats.o
.libs/libstarpu_la-user_interactions.o .libs/libstarpu_la-reduction.o
.libs/libstarpu_la-data_interface.o
.libs/libstarpu_la-bcsr_interface.o .libs/libstarpu_la-csr_interface.o
.libs/libstarpu_la-matrix_filters.o
.libs/libstarpu_la-matrix_interface.o
.libs/libstarpu_la-block_filters.o
.libs/libstarpu_la-block_interface.o
.libs/libstarpu_la-vector_interface.o
.libs/libstarpu_la-bcsr_filters.o .libs/libstarpu_la-csr_filters.o
.libs/libstarpu_la-vector_filters.o
.libs/libstarpu_la-variable_interface.o
.libs/libstarpu_la-void_interface.o .libs/libstarpu_la-malloc.o
.libs/libstarpu_la-execute_on_all.o
.libs/libstarpu_la-starpu_create_sync_task.o
.libs/libstarpu_la-starpu_cublas.o .libs/libstarpu_la-file.o
.libs/libstarpu_la-starpu_data_cpy.o
.libs/libstarpu_la-starpu_insert_task.o
.libs/libstarpu_la-starpu_insert_task_utils.o
.libs/libstarpu_la-starpu_task_list.o .libs/libstarpu_la-starpu_fxt.o
.libs/libstarpu_la-starpu_fxt_mpi.o
.libs/libstarpu_la-starpu_fxt_dag.o .libs/libstarpu_la-starpu_paje.o
.libs/libstarpu_la-latency.o .libs/libstarpu_la-structures_size.o
.libs/libstarpu_la-profiling.o .libs/libstarpu_la-bound.o
.libs/libstarpu_la-profiling_helpers.o .libs/libstarpu_la-driver_cpu.o
.libs/libstarpu_la-driver_cuda.o -L/usr/local/cuda/lib -lm -lblas
-lcurand -lcublas -lpthread -install_name
/usr/local/lib/libstarpu.0.dylib -compatibility_version 1
-current_version 1.0 -Wl,-single_module
Undefined symbols:
"_cudaThreadExit", referenced from:
_benchmark_all_gpu_devices in libstarpu_la-perfmodel_bus.o
__starpu_cuda_worker in libstarpu_la-driver_cuda.o
"_cudaMemcpy2D", referenced from:
_copy_ram_to_cuda_async in libstarpu_la-matrix_interface.o
_copy_cuda_to_ram_async in libstarpu_la-matrix_interface.o
_copy_cuda_to_ram in libstarpu_la-matrix_interface.o
_copy_cuda_to_cuda in libstarpu_la-matrix_interface.o
_copy_ram_to_cuda in libstarpu_la-matrix_interface.o
_copy_cuda_async_common in libstarpu_la-block_interface.o
_copy_cuda_common in libstarpu_la-block_interface.o
"_cudaMemcpy2DAsync", referenced from:
"_cudaFree", referenced from:
_free_bcsr_buffer_on_node in libstarpu_la-bcsr_interface.o
_allocate_bcsr_buffer_on_node in libstarpu_la-bcsr_interface.o
_free_csr_buffer_on_node in libstarpu_la-csr_interface.o
_allocate_csr_buffer_on_node in libstarpu_la-csr_interface.o
_free_matrix_buffer_on_node in libstarpu_la-matrix_interface.o
_free_block_buffer_on_node in libstarpu_la-block_interface.o
_free_vector_buffer_on_node in libstarpu_la-vector_interface.o
_free_variable_buffer_on_node in libstarpu_la-variable_interface.o
"_cudaHostAlloc", referenced from:
_malloc_pinned_cuda_codelet in libstarpu_la-malloc.o
"_cudaEventCreate", referenced from:
__starpu_driver_copy_data_1_to_1 in libstarpu_la-copy_driver.o
"_cudaMemcpy", referenced from:
_copy_cuda_common in libstarpu_la-bcsr_interface.o
_copy_cuda_common in libstarpu_la-csr_interface.o
_copy_cuda_async_common in libstarpu_la-vector_interface.o
_copy_cuda_to_ram in libstarpu_la-vector_interface.o
_copy_cuda_to_cuda in libstarpu_la-vector_interface.o
_copy_ram_to_cuda in libstarpu_la-vector_interface.o
_copy_cuda_to_ram_async in libstarpu_la-variable_interface.o
_copy_cuda_to_ram in libstarpu_la-variable_interface.o
_copy_ram_to_cuda_async in libstarpu_la-variable_interface.o
_copy_cuda_to_cuda in libstarpu_la-variable_interface.o
_copy_ram_to_cuda in libstarpu_la-variable_interface.o
"_cudaEventSynchronize", referenced from:
__starpu_driver_wait_request_completion in libstarpu_la-copy_driver.o
"_cudaThreadSynchronize", referenced from:
"_cudaEventRecord", referenced from:
"_cudaMemcpyAsync", referenced from:
"_cudaGetErrorString", referenced from:
_allocate_matrix_buffer_on_node in libstarpu_la-matrix_interface.o
_allocate_block_buffer_on_node in libstarpu_la-block_interface.o
_allocate_vector_buffer_on_node in libstarpu_la-vector_interface.o
_allocate_variable_buffer_on_node in libstarpu_la-variable_interface.o
_free_pinned_cuda_codelet in libstarpu_la-malloc.o
"_cudaEventDestroy", referenced from:
__starpu_driver_test_request_completion in libstarpu_la-copy_driver.o
"_cudaMemset", referenced from:
"_cudaEventQuery", referenced from:
"_cudaGetDeviceCount", referenced from:
__starpu_load_bus_performance_files in libstarpu_la-perfmodel_bus.o
__starpu_get_cuda_device_count in libstarpu_la-driver_cuda.o
__starpu_init_cuda in libstarpu_la-driver_cuda.o
"_cudaFreeHost", referenced from:
"_cudaGetDeviceProperties", referenced from:
"_cudaMalloc", referenced from:
"_cudaStreamDestroy", referenced from:
"_cudaStreamSynchronize", referenced from:
"_cudaSetDevice", referenced from:
"_cudaStreamCreate", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [libstarpu.la] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
PGP KeyID: 2048R/EA31CFC9  subkeys.pgp.net
Haut de le page
