Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Jonathan Adamczewski <jadamcze@utas.edu.au>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Building starpu examples with MSVC
- Date: Sun, 3 Apr 2011 00:51:19 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Jonathan Adamczewski, le Thu 31 Mar 2011 14:58:29 +0200, a écrit :
> 03_c89_examples_makefiles.diff:
> Add -std=c89 to Makefile.am files in examples directory. Probably
> should not be applied yet - I am not set up to build the CUDA
> examples, so don't know if more warnings/errors are yet to be uncovered.
Ok. Does MSVC like -std=c89 too? If so, the patch shouldn't be a
problem.
> ffs() and sqrtf() are not available when compiling with -std=c89.
Not a problem: simply add #define _BSD_SOURCE before includes to get
them back.
> There should be no problems caused by applying the first three
> diffs.
I have applied them, thanks !
Samuel
- Re: [Starpu-devel] Building starpu examples with MSVC, Samuel Thibault, 03/04/2011
- Re: [Starpu-devel] Building starpu examples with MSVC, Jonathan Adamczewski, 03/04/2011
