Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: tog <guillaume.alleon@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr, Raymond Namyst <Raymond.Namyst@labri.fr>
- Subject: Re: [Starpu-devel] Compiling starpu on Mac OS
- Date: Fri, 01 Apr 2011 16:41:05 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Running 'make check' will test all the examples provided with StarPU.
Regards,
Nathalie
On 01/04/2011 16:29, tog wrote:
Looks better. the library seems to be generated. Got a problem in the
examples.
What can be done to test the framework ?
Best Regards
Guillaume
On Fri, Apr 1, 2011 at 7:47 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
Thanks. Could you please try with the following patch?
Regards,
Nathalie
On 01/04/2011 15:57, tog wrote:
Yes, I restarted everything from the very beginning.
Here are both logs
Regards
Guillaume
On Fri, Apr 1, 2011 at 7:01 PM, Nathalie Furmento
Looks like the new variable STARPU_CUDA_LDFLAGS has not been added when
calling the linker. I might have forgotten to update some commands.
I supposed you called again "autogen.sh" and "configure" ? Running make
distclean might also help. Are you getting the error when calling make ?
Could you please send its whole output ?
Thanks,
Nathalie
On 01/04/2011 15:21, tog wrote:
Hi,
I did the update but still got a similar problem
Is there something I can do in order to help you ?
Best Regards
Guillaume
- Re: [Starpu-devel] Compiling starpu on Mac OS, Nathalie Furmento, 01/04/2011
- Re: [Starpu-devel] Compiling starpu on Mac OS, tog, 01/04/2011
