Archives de la liste
Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock()
Chronologique Discussions
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Jonathan Adamczewski <jadamcze@utas.edu.au>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock()
- Date: Wed, 27 Apr 2011 18:00:33 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Jonathan Adamczewski, le Sat 16 Apr 2011 09:44:49 +0200, a écrit :
> clSetKernelArg(kernel, i, STARPU_VARIABLE_GET_ELEMSIZE(buffer[i]),
> &STARPU_VARIABLE_GET_PTR(buffer[i]));
Err, this should be
clSetKernelArg(kernel, i, sizeof(cl_mem),
as what clSetKernelArg expects is not the size of the buffer, but the
size of the pointer. You need to pass
separately as another kernel parameter.
> Unregistering the second variable causes an assert to fail in
> _starpu_spin_unlock() - the assert checking the return value of
> pthread_spin_unlock() fails. According to gdb, lock->lock contains the
> value
> 0xfeeefeee, which looks rather suspicious.
Indeed. I guess valgrind is not of much help here.
Samuel
- [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 16/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 16/04/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Samuel Thibault, 27/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 28/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Samuel Thibault, 28/04/2011
