Archives de la liste
Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock()
Chronologique Discussions
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock()
- Date: Thu, 28 Apr 2011 10:42:50 +1000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 28/04/11 10:37, Samuel Thibault wrote:
Jonathan Adamczewski, le Thu 28 Apr 2011 10:36:02 +1000, a écrit :
Ah, right. Would it be possible to try on Linux?I'm running under Windows, so valgrind is not an option.Unregistering the second variable causes an assert to fail inIndeed. I guess valgrind is not of much help here.
_starpu_spin_unlock() - the assert checking the return value of
pthread_spin_unlock() fails. According to gdb, lock->lock contains the
value
0xfeeefeee, which looks rather suspicious.
Possible - but probably not in the short term. I'll keep it in mind.
j.
- [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 16/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 16/04/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Samuel Thibault, 27/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Jonathan Adamczewski, 28/04/2011
- Re: [Starpu-devel] starpu_data_unregister() failing at pthread_spin_unlock(), Samuel Thibault, 28/04/2011
