Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Starpu vector_scal example execution error on 32-bit linux system
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Starpu vector_scal example execution error on 32-bit linux system
  • Date: Mon, 31 Oct 2011 10:30:14 +0000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello ,
     I managed to resolve my earlier problem of getting Segmentation fault while executing vector_Scal example, which I had built on a Linux system. Since I was trying to build on a 64 bit Linux system,  I gave this CFLAGS=-m32 , and indeed it resolved the error and executed the vector_scal example fine with correct output.
But Just FYI – I am pasting a log of the execution on this 64 bit Linxu system, below where I see a strange error/warning below highlighted in RED, which seems like a corruption of some memory and subsequent print of a Backtrace. (Sorry for posting longish log messages within email). I m tryingto use it with moviSim openCL.
AFTER: First element is 3.140000
AFTER: Last element is 6430.720215               These are correct output values for vector_scal
Waiting for threads to stop...
*** glibc detected *** /home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/.libs/lt-vector_scal: double free or corruption (!prev): 0x09691e00 ***
======= Backtrace: =========
/lib32/libc.so.6(+0x6b511)[0xf71e6511]
/lib32/libc.so.6(+0x6ce1b)[0xf71e7e1b]
/lib32/libc.so.6(cfree+0x6d)[0xf71eaf8d]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZN9__gnu_cxx13new_allocatorIiE10deallocate        EPij+0x11)[0xf76aa8e1]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZNSt11_Deque_baseIiSaIiEE18_M_deallocate_n        odeEPi+0x2c)[0xf76aa910]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZNSt11_Deque_baseIiSaIiEE16_M_destroy_node        sEPPiS3_+0x22)[0xf76aa934]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZNSt11_Deque_baseIiSaIiEED2Ev+0x31)[0xf76a        ace9]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZNSt5dequeIiSaIiEED1Ev+0x66)[0xf76aae86]
/home/deshpandea/moviSimStarPU/trunk/moviSim/libOpenCL.so(_ZNSt5stackIiSt5dequeIiSaIiEEED1Ev+0x11)[0x        f76aae9d]
/home/deshpandea/moviSimStarPU/trunk/moviSim/moviLibs/Linux32/shavesDll.so(+0x18c906)[0xe0600906]
/lib32/libc.so.6(+0x2f9ef)[0xf71aa9ef]
/lib32/libc.so.6(+0x2fa4f)[0xf71aaa4f]
/lib32/libc.so.6(__libc_start_main+0xef)[0xf7191e3f]
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/.libs/lt-vector_scal[0x8048a61]
======= Memory map: ========
08048000-0804a000 r-xp 00000000 08:01 2494010                            /home/deshpandea/moviSimStar        PU/trunk/examples/basic_examples/.libs/lt-vector_scal
0804a000-0804b000 r--p 00001000 08:01 2494010                            /home/deshpandea/moviSimStar        PU/trunk/examples/basic_examples/.libs/lt-vector_scal
0804b000-08052000 rw-p 00002000 08:01 2494010                            /home/deshpandea/moviSimStar        PU/trunk/examples/basic_examples/.libs/lt-vector_scal
0958c000-09764000 rw-p 00000000 00:00 0                                  [heap]
ddc3e000-ddc6e000 r-xp 00000000 08:01 2101423                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/timersDll.so
ddc6e000-ddc6f000 rw-p 00030000 08:01 2101423                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/timersDll.so
ddc6f000-e0258000 rw-p 00000000 00:00 0
e0258000-e046a000 r-xp 00000000 08:01 2101424                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/leonDll.so
e046a000-e046c000 rw-p 00211000 08:01 2101424                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/leonDll.so
e046c000-e0474000 rw-p 00000000 00:00 0
e0474000-e0705000 r-xp 00000000 08:01 2101422                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/shavesDll.so
e0705000-e0709000 rw-p 00290000 08:01 2101422                            /home/deshpandea/moviSimStar        PU/trunk/moviSim/moviLibs/Linux32/shavesDll.so
e0709000-e0715000 rw-p 00000000 00:00 0
f4d00000-f4d21000 rw-p 00000000 00:00 0
f4d21000-f4e00000 ---p 00000000 00:00 0
f4f00000-f4f21000 rw-p 00000000 00:00 0
f4f21000-f5000000 ---p 00000000 00:00 0
So far so good.
At same time I am trying to build this vector_scal example on a 32 bit Linux(Ubuntu) there this option CFLAGS=-m32 does not help me. Even when I configure with that option, build and execute,
The log of the execution is as below –
AFTER: First element is 1.000000
AFTER: Last element is 2048.000000   This output suggests the actual scaling kernel is not executed/invoked because the example code does a loop from 1 to 2048 and multiply each scalar by a factor of 3.14(pi).
                                                         Why would the kernel not be invoked and executed is interesting?
LEON cycle count = 765
LEON power consumed = 0.0000 mW
*** glibc detected *** /home/movidius/code/moviSimStarPU/trunk/examples/basic_examples/.libs/lt-vector_scal: double free or corruption (!prev): 0x0912d620 ***
/lib/tls/i686/cmov/libc.so.6(+0x6b591)[0xb72be591]
/lib/tls/i686/cmov/libc.so.6(+0x6cde8)[0xb72bfde8]
Any help on below questions -
1] What is this double free or corruption errors above in both cases?
2] Why in the case 2, the opencl vector scale kernel doesn’t seem to be executed.
thanks.
  • [Starpu-devel] Starpu vector_scal example execution error on 32-bit linux system, ASD D, 31/10/2011
Haut de le page
