Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: ASD D <ajitsdeshpande@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Error while building StarpU library
- Date: Fri, 28 Oct 2011 19:30:15 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
ASD D, le Fri 28 Oct 2011 18:20:36 +0100, a écrit :
> BTW - This same example(Vector_scale) works fine under Windows+MingW setup,
> when configured to use openCL.
> So something to do with the Linux version shared library of openCL or
> moviSim
> may be.
> Need to dig more. Any pointers.
As I said, “you need to add some printfs in
starpu_opencl_load_opencl_from_string and starpu_opencl_load_kernel to
see what happens (e.g. bad device ID, or such thing).“
Samuel
- [Starpu-devel] Error while building StarpU library, ASD D, 27/10/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Error while building StarpU library, Samuel Thibault, 27/10/2011
- Re: [Starpu-devel] Error while building StarpU library, ASD D, 27/10/2011
- Re: [Starpu-devel] Error while building StarpU library, Samuel Thibault, 28/10/2011
- Re: [Starpu-devel] Error while building StarpU library, ASD D, 28/10/2011
