Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Linker errors in make while trying to build starpu
- Date: Mon, 14 Nov 2011 14:30:14 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
With reference to my earleir email, I thought I would brief about what I am trying to build.
Trying to build Starpu with NVIDIA opencl implementation, and my own app added in basic_examples/ (Have edited the examples/Makefile.am to build my source files)
The basic examples and all build/work fine.
Using the Configure command:
./configure --with-opencl-include-dir=/usr/include/CL/ --with-opencl-lib-dir=/usr/lib/ CFLAGS="-I/home/deshpandea/lpng155/ -I/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/ -I/home/deshpandea/zlib-1.2.5/" LIBS="/lib/x86_64-linux-gnu/libpng12.so.0.44.0" LIBS="/lib/x86_64-linux-gnu/libz.so.1.2.3.4" LIBS="/home/deshpandea/moviSimStarPU/trunk/moviSim/moviSimDll.so" LIBS="/usr/lib32/libm.a" LDFLAGS="-l:/usr/lib32/libstdc++.so.6.0.14" LDFLAGS="-l:/usr/local/cuda/lib64/libcudart.so" LDFLAGS="-l:/usr/local/cuda/lib64/libcublas.so" LIBS="/usr/lib/libOpenCL.so.1.0.0" --enable-debug --enable-verbose --disable-cuda
Pls see the config.log attached.
Make Errors faced:
These all are lib. functions which my app. refers to . I have those necessary libraries(libpng and libz) installed , added thsoe paths to my LD_LIBRARY_PATH and even explicitly tried to link the starpu app with those libs my mentioning them in the configure command above, but still they seem not to be found and I get errors as undefined references.
Pls. see the attached make command stdin, stderr redirection outputs.
Any pointers would help.
thank you.
On Sat, Nov 12, 2011 at 2:45 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASD D, le Fri 11 Nov 2011 13:21:36 +0100, a écrit :
> These are very basic primitives in opencl which even ver 1.0 spec supports, soProbably yes. Please provide config.log and the output of the make
> I suspect there is something else going wrong here in my build like the OpenCL
> lib. Not getting linked to starpu build itself?
command.
Samuel
Making all in src
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/src'
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/src'
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I.
-I../src/common -I../include -I../gcc-plugin/src -I../include/ -D_GNU_SOURCE
-W -Wall -Wextra -I/usr/local/cuda/include -I/usr/include/CL/
-DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-barrier.lo
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c -o libstarpu_la-barrier.lo
`test -f 'common/barrier.c' || echo './'`common/barrier.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include
-I../gcc-plugin/src -I../include/ -D_GNU_SOURCE -W -Wall -Wextra
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c common/barrier.c -fPIC -DPIC
-o .libs/libstarpu_la-barrier.o
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c common/barrier.c -o
libstarpu_la-barrier.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-barrier.Tpo .deps/libstarpu_la-barrier.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-hash.lo
-MD -MP -MF .deps/libstarpu_la-hash.Tpo -c -o libstarpu_la-hash.lo `test -f
'common/hash.c' || echo './'`common/hash.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-hash.lo -MD
-MP -MF .deps/libstarpu_la-hash.Tpo -c common/hash.c -fPIC -DPIC -o
.libs/libstarpu_la-hash.o
-MP -MF .deps/libstarpu_la-hash.Tpo -c common/hash.c -o libstarpu_la-hash.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-hash.Tpo .deps/libstarpu_la-hash.Plo
libstarpu_la-htable32.lo -MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c -o
libstarpu_la-htable32.lo `test -f 'common/htable32.c' || echo
'./'`common/htable32.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-htable32.lo
-MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c common/htable32.c -fPIC -DPIC
-o .libs/libstarpu_la-htable32.o
-MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c common/htable32.c -o
libstarpu_la-htable32.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable32.Tpo .deps/libstarpu_la-htable32.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-rwlock.lo
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c -o libstarpu_la-rwlock.lo `test
-f 'common/rwlock.c' || echo './'`common/rwlock.c
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c common/rwlock.c -fPIC -DPIC -o
.libs/libstarpu_la-rwlock.o
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c common/rwlock.c -o
libstarpu_la-rwlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-rwlock.Tpo .deps/libstarpu_la-rwlock.Plo
libstarpu_la-starpu_spinlock.lo -MD -MP -MF
.deps/libstarpu_la-starpu_spinlock.Tpo -c -o libstarpu_la-starpu_spinlock.lo
`test -f 'common/starpu_spinlock.c' || echo './'`common/starpu_spinlock.c
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_spinlock.o
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -o
libstarpu_la-starpu_spinlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_spinlock.Tpo
.deps/libstarpu_la-starpu_spinlock.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-timing.lo
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c -o libstarpu_la-timing.lo `test
-f 'common/timing.c' || echo './'`common/timing.c
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c common/timing.c -fPIC -DPIC -o
.libs/libstarpu_la-timing.o
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c common/timing.c -o
libstarpu_la-timing.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-timing.Tpo .deps/libstarpu_la-timing.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-fxt.lo -MD
-MP -MF .deps/libstarpu_la-fxt.Tpo -c -o libstarpu_la-fxt.lo `test -f
'common/fxt.c' || echo './'`common/fxt.c
-MP -MF .deps/libstarpu_la-fxt.Tpo -c common/fxt.c -fPIC -DPIC -o
.libs/libstarpu_la-fxt.o
-MP -MF .deps/libstarpu_la-fxt.Tpo -c common/fxt.c -o libstarpu_la-fxt.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-fxt.Tpo .deps/libstarpu_la-fxt.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-utils.lo
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c -o libstarpu_la-utils.lo `test -f
'common/utils.c' || echo './'`common/utils.c
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c common/utils.c -fPIC -DPIC -o
.libs/libstarpu_la-utils.o
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c common/utils.c -o
libstarpu_la-utils.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-utils.Tpo .deps/libstarpu_la-utils.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-jobs.lo
-MD -MP -MF .deps/libstarpu_la-jobs.Tpo -c -o libstarpu_la-jobs.lo `test -f
'core/jobs.c' || echo './'`core/jobs.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-jobs.lo -MD
-MP -MF .deps/libstarpu_la-jobs.Tpo -c core/jobs.c -fPIC -DPIC -o
.libs/libstarpu_la-jobs.o
-MP -MF .deps/libstarpu_la-jobs.Tpo -c core/jobs.c -o libstarpu_la-jobs.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-jobs.Tpo .deps/libstarpu_la-jobs.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-task.lo
-MD -MP -MF .deps/libstarpu_la-task.Tpo -c -o libstarpu_la-task.lo `test -f
'core/task.c' || echo './'`core/task.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-task.lo -MD
-MP -MF .deps/libstarpu_la-task.Tpo -c core/task.c -fPIC -DPIC -o
.libs/libstarpu_la-task.o
-MP -MF .deps/libstarpu_la-task.Tpo -c core/task.c -o libstarpu_la-task.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-task.Tpo .deps/libstarpu_la-task.Plo
libstarpu_la-task_bundle.lo -MD -MP -MF .deps/libstarpu_la-task_bundle.Tpo -c
-o libstarpu_la-task_bundle.lo `test -f 'core/task_bundle.c' || echo
'./'`core/task_bundle.c
core/task_bundle.c -fPIC -DPIC -o .libs/libstarpu_la-task_bundle.o
core/task_bundle.c -o libstarpu_la-task_bundle.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_bundle.Tpo .deps/libstarpu_la-task_bundle.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-workers.lo
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c -o libstarpu_la-workers.lo
`test -f 'core/workers.c' || echo './'`core/workers.c
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c core/workers.c -fPIC -DPIC -o
.libs/libstarpu_la-workers.o
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c core/workers.c -o
libstarpu_la-workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-workers.Tpo .deps/libstarpu_la-workers.Plo
libstarpu_la-combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-combined_workers.Tpo -c -o
libstarpu_la-combined_workers.lo `test -f 'core/combined_workers.c' || echo
'./'`core/combined_workers.c
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -fPIC
-DPIC -o .libs/libstarpu_la-combined_workers.o
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -o
libstarpu_la-combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-combined_workers.Tpo
.deps/libstarpu_la-combined_workers.Plo
libstarpu_la-topology.lo -MD -MP -MF .deps/libstarpu_la-topology.Tpo -c -o
libstarpu_la-topology.lo `test -f 'core/topology.c' || echo
'./'`core/topology.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-topology.lo
-MD -MP -MF .deps/libstarpu_la-topology.Tpo -c core/topology.c -fPIC -DPIC
-o .libs/libstarpu_la-topology.o
-MD -MP -MF .deps/libstarpu_la-topology.Tpo -c core/topology.c -o
libstarpu_la-topology.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-topology.Tpo .deps/libstarpu_la-topology.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-debug.lo
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c -o libstarpu_la-debug.lo `test -f
'core/debug.c' || echo './'`core/debug.c
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c core/debug.c -fPIC -DPIC -o
.libs/libstarpu_la-debug.o
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c core/debug.c -o
libstarpu_la-debug.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-debug.Tpo .deps/libstarpu_la-debug.Plo
libstarpu_la-errorcheck.lo -MD -MP -MF .deps/libstarpu_la-errorcheck.Tpo -c
-o libstarpu_la-errorcheck.lo `test -f 'core/errorcheck.c' || echo
'./'`core/errorcheck.c
core/errorcheck.c -fPIC -DPIC -o .libs/libstarpu_la-errorcheck.o
core/errorcheck.c -o libstarpu_la-errorcheck.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-errorcheck.Tpo .deps/libstarpu_la-errorcheck.Plo
libstarpu_la-progress_hook.lo -MD -MP -MF
.deps/libstarpu_la-progress_hook.Tpo -c -o libstarpu_la-progress_hook.lo
`test -f 'core/progress_hook.c' || echo './'`core/progress_hook.c
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -fPIC -DPIC -o
.libs/libstarpu_la-progress_hook.o
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -o
libstarpu_la-progress_hook.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress_hook.Tpo
.deps/libstarpu_la-progress_hook.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-cg.lo -MD
-MP -MF .deps/libstarpu_la-cg.Tpo -c -o libstarpu_la-cg.lo `test -f
'core/dependencies/cg.c' || echo './'`core/dependencies/cg.c
-MP -MF .deps/libstarpu_la-cg.Tpo -c core/dependencies/cg.c -fPIC -DPIC -o
.libs/libstarpu_la-cg.o
-MP -MF .deps/libstarpu_la-cg.Tpo -c core/dependencies/cg.c -o
libstarpu_la-cg.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-cg.Tpo .deps/libstarpu_la-cg.Plo
libstarpu_la-dependencies.lo -MD -MP -MF .deps/libstarpu_la-dependencies.Tpo
-c -o libstarpu_la-dependencies.lo `test -f
'core/dependencies/dependencies.c' || echo
'./'`core/dependencies/dependencies.c
-c core/dependencies/dependencies.c -fPIC -DPIC -o
.libs/libstarpu_la-dependencies.o
-c core/dependencies/dependencies.c -o libstarpu_la-dependencies.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-dependencies.Tpo .deps/libstarpu_la-dependencies.Plo
libstarpu_la-implicit_data_deps.lo -MD -MP -MF
.deps/libstarpu_la-implicit_data_deps.Tpo -c -o
libstarpu_la-implicit_data_deps.lo `test -f
'core/dependencies/implicit_data_deps.c' || echo
'./'`core/dependencies/implicit_data_deps.c
core/dependencies/implicit_data_deps.c -fPIC -DPIC -o
.libs/libstarpu_la-implicit_data_deps.o
core/dependencies/implicit_data_deps.c -o libstarpu_la-implicit_data_deps.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-implicit_data_deps.Tpo
.deps/libstarpu_la-implicit_data_deps.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-tags.lo
-MD -MP -MF .deps/libstarpu_la-tags.Tpo -c -o libstarpu_la-tags.lo `test -f
'core/dependencies/tags.c' || echo './'`core/dependencies/tags.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-tags.lo -MD
-MP -MF .deps/libstarpu_la-tags.Tpo -c core/dependencies/tags.c -fPIC -DPIC
-o .libs/libstarpu_la-tags.o
-MP -MF .deps/libstarpu_la-tags.Tpo -c core/dependencies/tags.c -o
libstarpu_la-tags.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-tags.Tpo .deps/libstarpu_la-tags.Plo
libstarpu_la-task_deps.lo -MD -MP -MF .deps/libstarpu_la-task_deps.Tpo -c -o
libstarpu_la-task_deps.lo `test -f 'core/dependencies/task_deps.c' || echo
'./'`core/dependencies/task_deps.c
core/dependencies/task_deps.c -fPIC -DPIC -o .libs/libstarpu_la-task_deps.o
core/dependencies/task_deps.c -o libstarpu_la-task_deps.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_deps.Tpo .deps/libstarpu_la-task_deps.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-htable.lo
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c -o libstarpu_la-htable.lo `test
-f 'core/dependencies/htable.c' || echo './'`core/dependencies/htable.c
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c core/dependencies/htable.c
-fPIC -DPIC -o .libs/libstarpu_la-htable.o
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c core/dependencies/htable.c -o
libstarpu_la-htable.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable.Tpo .deps/libstarpu_la-htable.Plo
libstarpu_la-data_concurrency.lo -MD -MP -MF
.deps/libstarpu_la-data_concurrency.Tpo -c -o
libstarpu_la-data_concurrency.lo `test -f
'core/dependencies/data_concurrency.c' || echo
'./'`core/dependencies/data_concurrency.c
core/dependencies/data_concurrency.c -fPIC -DPIC -o
.libs/libstarpu_la-data_concurrency.o
core/dependencies/data_concurrency.c -o libstarpu_la-data_concurrency.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_concurrency.Tpo
.deps/libstarpu_la-data_concurrency.Plo
libstarpu_la-perfmodel_history.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_history.Tpo -c -o
libstarpu_la-perfmodel_history.lo `test -f
'core/perfmodel/perfmodel_history.c' || echo
'./'`core/perfmodel/perfmodel_history.c
core/perfmodel/perfmodel_history.c -fPIC -DPIC -o
.libs/libstarpu_la-perfmodel_history.o
core/perfmodel/perfmodel_history.c: In function ‘parse_arch’:
core/perfmodel/perfmodel_history.c:221: warning: comparison between signed
and unsigned integer expressions
core/perfmodel/perfmodel_history.c:225: warning: comparison between signed
core/perfmodel/perfmodel_history.c:237: warning: comparison between signed
core/perfmodel/perfmodel_history.c:238: warning: comparison between signed
core/perfmodel/perfmodel_history.c:242: warning: comparison between signed
core/perfmodel/perfmodel_history.c -o libstarpu_la-perfmodel_history.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_history.Tpo
.deps/libstarpu_la-perfmodel_history.Plo
libstarpu_la-perfmodel_bus.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_bus.Tpo -c -o libstarpu_la-perfmodel_bus.lo
`test -f 'core/perfmodel/perfmodel_bus.c' || echo
'./'`core/perfmodel/perfmodel_bus.c
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -fPIC
-DPIC -o .libs/libstarpu_la-perfmodel_bus.o
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -o
libstarpu_la-perfmodel_bus.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_bus.Tpo
.deps/libstarpu_la-perfmodel_bus.Plo
libstarpu_la-perfmodel.lo -MD -MP -MF .deps/libstarpu_la-perfmodel.Tpo -c -o
libstarpu_la-perfmodel.lo `test -f 'core/perfmodel/perfmodel.c' || echo
'./'`core/perfmodel/perfmodel.c
core/perfmodel/perfmodel.c -fPIC -DPIC -o .libs/libstarpu_la-perfmodel.o
core/perfmodel/perfmodel.c -o libstarpu_la-perfmodel.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel.Tpo .deps/libstarpu_la-perfmodel.Plo
libstarpu_la-regression.lo -MD -MP -MF .deps/libstarpu_la-regression.Tpo -c
-o libstarpu_la-regression.lo `test -f 'core/perfmodel/regression.c' || echo
'./'`core/perfmodel/regression.c
core/perfmodel/regression.c -fPIC -DPIC -o .libs/libstarpu_la-regression.o
core/perfmodel/regression.c -o libstarpu_la-regression.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-regression.Tpo .deps/libstarpu_la-regression.Plo
libstarpu_la-sched_policy.lo -MD -MP -MF .deps/libstarpu_la-sched_policy.Tpo
-c -o libstarpu_la-sched_policy.lo `test -f 'core/sched_policy.c' || echo
'./'`core/sched_policy.c
-c core/sched_policy.c -fPIC -DPIC -o .libs/libstarpu_la-sched_policy.o
-c core/sched_policy.c -o libstarpu_la-sched_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sched_policy.Tpo .deps/libstarpu_la-sched_policy.Plo
libstarpu_la-priorities.lo -MD -MP -MF .deps/libstarpu_la-priorities.Tpo -c
-o libstarpu_la-priorities.lo `test -f 'core/priorities.c' || echo
'./'`core/priorities.c
core/priorities.c -fPIC -DPIC -o .libs/libstarpu_la-priorities.o
core/priorities.c -o libstarpu_la-priorities.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-priorities.Tpo .deps/libstarpu_la-priorities.Plo
libstarpu_la-parallel_task.lo -MD -MP -MF
.deps/libstarpu_la-parallel_task.Tpo -c -o libstarpu_la-parallel_task.lo
`test -f 'core/parallel_task.c' || echo './'`core/parallel_task.c
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -fPIC -DPIC -o
.libs/libstarpu_la-parallel_task.o
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -o
libstarpu_la-parallel_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_task.Tpo
.deps/libstarpu_la-parallel_task.Plo
libstarpu_la-eager_central_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_policy.Tpo -c -o
libstarpu_la-eager_central_policy.lo `test -f
'sched_policies/eager_central_policy.c' || echo
'./'`sched_policies/eager_central_policy.c
sched_policies/eager_central_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_policy.o
sched_policies/eager_central_policy.c -o libstarpu_la-eager_central_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_policy.Tpo
.deps/libstarpu_la-eager_central_policy.Plo
libstarpu_la-eager_central_priority_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_priority_policy.Tpo -c -o
libstarpu_la-eager_central_priority_policy.lo `test -f
'sched_policies/eager_central_priority_policy.c' || echo
'./'`sched_policies/eager_central_priority_policy.c
sched_policies/eager_central_priority_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_priority_policy.o
sched_policies/eager_central_priority_policy.c -o
libstarpu_la-eager_central_priority_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_priority_policy.Tpo
.deps/libstarpu_la-eager_central_priority_policy.Plo
libstarpu_la-work_stealing_policy.lo -MD -MP -MF
.deps/libstarpu_la-work_stealing_policy.Tpo -c -o
libstarpu_la-work_stealing_policy.lo `test -f
'sched_policies/work_stealing_policy.c' || echo
'./'`sched_policies/work_stealing_policy.c
sched_policies/work_stealing_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-work_stealing_policy.o
sched_policies/work_stealing_policy.c:122: warning: ‘select_workerq’ defined
but not used
sched_policies/work_stealing_policy.c -o libstarpu_la-work_stealing_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-work_stealing_policy.Tpo
.deps/libstarpu_la-work_stealing_policy.Plo
libstarpu_la-deque_modeling_policy_data_aware.lo -MD -MP -MF
.deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo -c -o
libstarpu_la-deque_modeling_policy_data_aware.lo `test -f
'sched_policies/deque_modeling_policy_data_aware.c' || echo
'./'`sched_policies/deque_modeling_policy_data_aware.c
sched_policies/deque_modeling_policy_data_aware.c -fPIC -DPIC -o
.libs/libstarpu_la-deque_modeling_policy_data_aware.o
sched_policies/deque_modeling_policy_data_aware.c -o
libstarpu_la-deque_modeling_policy_data_aware.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo
.deps/libstarpu_la-deque_modeling_policy_data_aware.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-heft.lo
-MD -MP -MF .deps/libstarpu_la-heft.Tpo -c -o libstarpu_la-heft.lo `test -f
'sched_policies/heft.c' || echo './'`sched_policies/heft.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-heft.lo -MD
-MP -MF .deps/libstarpu_la-heft.Tpo -c sched_policies/heft.c -fPIC -DPIC -o
.libs/libstarpu_la-heft.o
-MP -MF .deps/libstarpu_la-heft.Tpo -c sched_policies/heft.c -o
libstarpu_la-heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-heft.Tpo .deps/libstarpu_la-heft.Plo
libstarpu_la-random_policy.lo -MD -MP -MF
.deps/libstarpu_la-random_policy.Tpo -c -o libstarpu_la-random_policy.lo
`test -f 'sched_policies/random_policy.c' || echo
'./'`sched_policies/random_policy.c
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -fPIC
-DPIC -o .libs/libstarpu_la-random_policy.o
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -o
libstarpu_la-random_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-random_policy.Tpo
.deps/libstarpu_la-random_policy.Plo
libstarpu_la-stack_queues.lo -MD -MP -MF .deps/libstarpu_la-stack_queues.Tpo
-c -o libstarpu_la-stack_queues.lo `test -f 'sched_policies/stack_queues.c'
|| echo './'`sched_policies/stack_queues.c
-c sched_policies/stack_queues.c -fPIC -DPIC -o
.libs/libstarpu_la-stack_queues.o
-c sched_policies/stack_queues.c -o libstarpu_la-stack_queues.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-stack_queues.Tpo .deps/libstarpu_la-stack_queues.Plo
libstarpu_la-deque_queues.lo -MD -MP -MF .deps/libstarpu_la-deque_queues.Tpo
-c -o libstarpu_la-deque_queues.lo `test -f 'sched_policies/deque_queues.c'
|| echo './'`sched_policies/deque_queues.c
-c sched_policies/deque_queues.c -fPIC -DPIC -o
.libs/libstarpu_la-deque_queues.o
-c sched_policies/deque_queues.c -o libstarpu_la-deque_queues.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-deque_queues.Tpo .deps/libstarpu_la-deque_queues.Plo
libstarpu_la-fifo_queues.lo -MD -MP -MF .deps/libstarpu_la-fifo_queues.Tpo -c
-o libstarpu_la-fifo_queues.lo `test -f 'sched_policies/fifo_queues.c' ||
echo './'`sched_policies/fifo_queues.c
sched_policies/fifo_queues.c -fPIC -DPIC -o .libs/libstarpu_la-fifo_queues.o
sched_policies/fifo_queues.c -o libstarpu_la-fifo_queues.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-fifo_queues.Tpo .deps/libstarpu_la-fifo_queues.Plo
libstarpu_la-detect_combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-detect_combined_workers.Tpo -c -o
libstarpu_la-detect_combined_workers.lo `test -f
'sched_policies/detect_combined_workers.c' || echo
'./'`sched_policies/detect_combined_workers.c
sched_policies/detect_combined_workers.c -fPIC -DPIC -o
.libs/libstarpu_la-detect_combined_workers.o
sched_policies/detect_combined_workers.c -o
libstarpu_la-detect_combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-detect_combined_workers.Tpo
.deps/libstarpu_la-detect_combined_workers.Plo
libstarpu_la-parallel_heft.lo -MD -MP -MF
.deps/libstarpu_la-parallel_heft.Tpo -c -o libstarpu_la-parallel_heft.lo
`test -f 'sched_policies/parallel_heft.c' || echo
'./'`sched_policies/parallel_heft.c
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -fPIC
-DPIC -o .libs/libstarpu_la-parallel_heft.o
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -o
libstarpu_la-parallel_heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_heft.Tpo
.deps/libstarpu_la-parallel_heft.Plo
libstarpu_la-parallel_greedy.lo -MD -MP -MF
.deps/libstarpu_la-parallel_greedy.Tpo -c -o libstarpu_la-parallel_greedy.lo
`test -f 'sched_policies/parallel_greedy.c' || echo
'./'`sched_policies/parallel_greedy.c
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c
-fPIC -DPIC -o .libs/libstarpu_la-parallel_greedy.o
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c -o
libstarpu_la-parallel_greedy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_greedy.Tpo
.deps/libstarpu_la-parallel_greedy.Plo
libstarpu_la-driver_common.lo -MD -MP -MF
.deps/libstarpu_la-driver_common.Tpo -c -o libstarpu_la-driver_common.lo
`test -f 'drivers/driver_common/driver_common.c' || echo
'./'`drivers/driver_common/driver_common.c
.deps/libstarpu_la-driver_common.Tpo -c drivers/driver_common/driver_common.c
-fPIC -DPIC -o .libs/libstarpu_la-driver_common.o
-o libstarpu_la-driver_common.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_common.Tpo
.deps/libstarpu_la-driver_common.Plo
libstarpu_la-memory_nodes.lo -MD -MP -MF .deps/libstarpu_la-memory_nodes.Tpo
-c -o libstarpu_la-memory_nodes.lo `test -f 'datawizard/memory_nodes.c' ||
echo './'`datawizard/memory_nodes.c
-c datawizard/memory_nodes.c -fPIC -DPIC -o .libs/libstarpu_la-memory_nodes.o
-c datawizard/memory_nodes.c -o libstarpu_la-memory_nodes.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memory_nodes.Tpo .deps/libstarpu_la-memory_nodes.Plo
libstarpu_la-write_back.lo -MD -MP -MF .deps/libstarpu_la-write_back.Tpo -c
-o libstarpu_la-write_back.lo `test -f 'datawizard/write_back.c' || echo
'./'`datawizard/write_back.c
datawizard/write_back.c -fPIC -DPIC -o .libs/libstarpu_la-write_back.o
datawizard/write_back.c -o libstarpu_la-write_back.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-write_back.Tpo .deps/libstarpu_la-write_back.Plo
libstarpu_la-coherency.lo -MD -MP -MF .deps/libstarpu_la-coherency.Tpo -c -o
libstarpu_la-coherency.lo `test -f 'datawizard/coherency.c' || echo
'./'`datawizard/coherency.c
datawizard/coherency.c -fPIC -DPIC -o .libs/libstarpu_la-coherency.o
datawizard/coherency.c -o libstarpu_la-coherency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-coherency.Tpo .deps/libstarpu_la-coherency.Plo
libstarpu_la-data_request.lo -MD -MP -MF .deps/libstarpu_la-data_request.Tpo
-c -o libstarpu_la-data_request.lo `test -f 'datawizard/data_request.c' ||
echo './'`datawizard/data_request.c
-c datawizard/data_request.c -fPIC -DPIC -o .libs/libstarpu_la-data_request.o
-c datawizard/data_request.c -o libstarpu_la-data_request.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-data_request.Tpo .deps/libstarpu_la-data_request.Plo
libstarpu_la-progress.lo -MD -MP -MF .deps/libstarpu_la-progress.Tpo -c -o
libstarpu_la-progress.lo `test -f 'datawizard/progress.c' || echo
'./'`datawizard/progress.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-progress.lo
-MD -MP -MF .deps/libstarpu_la-progress.Tpo -c datawizard/progress.c -fPIC
-DPIC -o .libs/libstarpu_la-progress.o
-MD -MP -MF .deps/libstarpu_la-progress.Tpo -c datawizard/progress.c -o
libstarpu_la-progress.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress.Tpo .deps/libstarpu_la-progress.Plo
libstarpu_la-copy_driver.lo -MD -MP -MF .deps/libstarpu_la-copy_driver.Tpo -c
-o libstarpu_la-copy_driver.lo `test -f 'datawizard/copy_driver.c' || echo
'./'`datawizard/copy_driver.c
datawizard/copy_driver.c -fPIC -DPIC -o .libs/libstarpu_la-copy_driver.o
datawizard/copy_driver.c -o libstarpu_la-copy_driver.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-copy_driver.Tpo .deps/libstarpu_la-copy_driver.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-filters.lo
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c -o libstarpu_la-filters.lo
`test -f 'datawizard/filters.c' || echo './'`datawizard/filters.c
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c datawizard/filters.c -fPIC
-DPIC -o .libs/libstarpu_la-filters.o
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c datawizard/filters.c -o
libstarpu_la-filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-filters.Tpo .deps/libstarpu_la-filters.Plo
libstarpu_la-sort_data_handles.lo -MD -MP -MF
.deps/libstarpu_la-sort_data_handles.Tpo -c -o
libstarpu_la-sort_data_handles.lo `test -f 'datawizard/sort_data_handles.c'
|| echo './'`datawizard/sort_data_handles.c
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c
-fPIC -DPIC -o .libs/libstarpu_la-sort_data_handles.o
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c -o
libstarpu_la-sort_data_handles.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sort_data_handles.Tpo
.deps/libstarpu_la-sort_data_handles.Plo
libstarpu_la-memalloc.lo -MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c -o
libstarpu_la-memalloc.lo `test -f 'datawizard/memalloc.c' || echo
'./'`datawizard/memalloc.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-memalloc.lo
-MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c datawizard/memalloc.c -fPIC
-DPIC -o .libs/libstarpu_la-memalloc.o
-MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c datawizard/memalloc.c -o
libstarpu_la-memalloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memalloc.Tpo .deps/libstarpu_la-memalloc.Plo
libstarpu_la-footprint.lo -MD -MP -MF .deps/libstarpu_la-footprint.Tpo -c -o
libstarpu_la-footprint.lo `test -f 'datawizard/footprint.c' || echo
'./'`datawizard/footprint.c
datawizard/footprint.c -fPIC -DPIC -o .libs/libstarpu_la-footprint.o
datawizard/footprint.c -o libstarpu_la-footprint.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-footprint.Tpo .deps/libstarpu_la-footprint.Plo
libstarpu_la-datastats.lo -MD -MP -MF .deps/libstarpu_la-datastats.Tpo -c -o
libstarpu_la-datastats.lo `test -f 'datawizard/datastats.c' || echo
'./'`datawizard/datastats.c
datawizard/datastats.c -fPIC -DPIC -o .libs/libstarpu_la-datastats.o
datawizard/datastats.c -o libstarpu_la-datastats.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-datastats.Tpo .deps/libstarpu_la-datastats.Plo
libstarpu_la-user_interactions.lo -MD -MP -MF
.deps/libstarpu_la-user_interactions.Tpo -c -o
libstarpu_la-user_interactions.lo `test -f 'datawizard/user_interactions.c'
|| echo './'`datawizard/user_interactions.c
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c
-fPIC -DPIC -o .libs/libstarpu_la-user_interactions.o
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c -o
libstarpu_la-user_interactions.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-user_interactions.Tpo
.deps/libstarpu_la-user_interactions.Plo
libstarpu_la-reduction.lo -MD -MP -MF .deps/libstarpu_la-reduction.Tpo -c -o
libstarpu_la-reduction.lo `test -f 'datawizard/reduction.c' || echo
'./'`datawizard/reduction.c
datawizard/reduction.c -fPIC -DPIC -o .libs/libstarpu_la-reduction.o
datawizard/reduction.c -o libstarpu_la-reduction.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-reduction.Tpo .deps/libstarpu_la-reduction.Plo
libstarpu_la-data_interface.lo -MD -MP -MF
.deps/libstarpu_la-data_interface.Tpo -c -o libstarpu_la-data_interface.lo
`test -f 'datawizard/interfaces/data_interface.c' || echo
'./'`datawizard/interfaces/data_interface.c
datawizard/interfaces/data_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-data_interface.o
datawizard/interfaces/data_interface.c -o libstarpu_la-data_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_interface.Tpo
.deps/libstarpu_la-data_interface.Plo
libstarpu_la-bcsr_interface.lo -MD -MP -MF
.deps/libstarpu_la-bcsr_interface.Tpo -c -o libstarpu_la-bcsr_interface.lo
`test -f 'datawizard/interfaces/bcsr_interface.c' || echo
'./'`datawizard/interfaces/bcsr_interface.c
datawizard/interfaces/bcsr_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-bcsr_interface.o
datawizard/interfaces/bcsr_interface.c -o libstarpu_la-bcsr_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_interface.Tpo
.deps/libstarpu_la-bcsr_interface.Plo
libstarpu_la-csr_interface.lo -MD -MP -MF
.deps/libstarpu_la-csr_interface.Tpo -c -o libstarpu_la-csr_interface.lo
`test -f 'datawizard/interfaces/csr_interface.c' || echo
'./'`datawizard/interfaces/csr_interface.c
.deps/libstarpu_la-csr_interface.Tpo -c datawizard/interfaces/csr_interface.c
-fPIC -DPIC -o .libs/libstarpu_la-csr_interface.o
-o libstarpu_la-csr_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-csr_interface.Tpo
.deps/libstarpu_la-csr_interface.Plo
libstarpu_la-matrix_filters.lo -MD -MP -MF
.deps/libstarpu_la-matrix_filters.Tpo -c -o libstarpu_la-matrix_filters.lo
`test -f 'datawizard/interfaces/matrix_filters.c' || echo
'./'`datawizard/interfaces/matrix_filters.c
datawizard/interfaces/matrix_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_filters.o
datawizard/interfaces/matrix_filters.c -o libstarpu_la-matrix_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_filters.Tpo
.deps/libstarpu_la-matrix_filters.Plo
libstarpu_la-matrix_interface.lo -MD -MP -MF
.deps/libstarpu_la-matrix_interface.Tpo -c -o
libstarpu_la-matrix_interface.lo `test -f
'datawizard/interfaces/matrix_interface.c' || echo
'./'`datawizard/interfaces/matrix_interface.c
datawizard/interfaces/matrix_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_interface.o
datawizard/interfaces/matrix_interface.c -o libstarpu_la-matrix_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_interface.Tpo
.deps/libstarpu_la-matrix_interface.Plo
libstarpu_la-block_filters.lo -MD -MP -MF
.deps/libstarpu_la-block_filters.Tpo -c -o libstarpu_la-block_filters.lo
`test -f 'datawizard/interfaces/block_filters.c' || echo
'./'`datawizard/interfaces/block_filters.c
.deps/libstarpu_la-block_filters.Tpo -c datawizard/interfaces/block_filters.c
-fPIC -DPIC -o .libs/libstarpu_la-block_filters.o
-o libstarpu_la-block_filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-block_filters.Tpo
.deps/libstarpu_la-block_filters.Plo
libstarpu_la-block_interface.lo -MD -MP -MF
.deps/libstarpu_la-block_interface.Tpo -c -o libstarpu_la-block_interface.lo
`test -f 'datawizard/interfaces/block_interface.c' || echo
'./'`datawizard/interfaces/block_interface.c
datawizard/interfaces/block_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-block_interface.o
datawizard/interfaces/block_interface.c -o libstarpu_la-block_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-block_interface.Tpo
.deps/libstarpu_la-block_interface.Plo
libstarpu_la-vector_interface.lo -MD -MP -MF
.deps/libstarpu_la-vector_interface.Tpo -c -o
libstarpu_la-vector_interface.lo `test -f
'datawizard/interfaces/vector_interface.c' || echo
'./'`datawizard/interfaces/vector_interface.c
datawizard/interfaces/vector_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_interface.o
datawizard/interfaces/vector_interface.c -o libstarpu_la-vector_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_interface.Tpo
.deps/libstarpu_la-vector_interface.Plo
libstarpu_la-bcsr_filters.lo -MD -MP -MF .deps/libstarpu_la-bcsr_filters.Tpo
-c -o libstarpu_la-bcsr_filters.lo `test -f
'datawizard/interfaces/bcsr_filters.c' || echo
'./'`datawizard/interfaces/bcsr_filters.c
-c datawizard/interfaces/bcsr_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-bcsr_filters.o
-c datawizard/interfaces/bcsr_filters.c -o libstarpu_la-bcsr_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_filters.Tpo .deps/libstarpu_la-bcsr_filters.Plo
libstarpu_la-csr_filters.lo -MD -MP -MF .deps/libstarpu_la-csr_filters.Tpo -c
-o libstarpu_la-csr_filters.lo `test -f 'datawizard/interfaces/csr_filters.c'
|| echo './'`datawizard/interfaces/csr_filters.c
datawizard/interfaces/csr_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-csr_filters.o
datawizard/interfaces/csr_filters.c -o libstarpu_la-csr_filters.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-csr_filters.Tpo .deps/libstarpu_la-csr_filters.Plo
libstarpu_la-vector_filters.lo -MD -MP -MF
.deps/libstarpu_la-vector_filters.Tpo -c -o libstarpu_la-vector_filters.lo
`test -f 'datawizard/interfaces/vector_filters.c' || echo
'./'`datawizard/interfaces/vector_filters.c
datawizard/interfaces/vector_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_filters.o
datawizard/interfaces/vector_filters.c -o libstarpu_la-vector_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_filters.Tpo
.deps/libstarpu_la-vector_filters.Plo
libstarpu_la-variable_interface.lo -MD -MP -MF
.deps/libstarpu_la-variable_interface.Tpo -c -o
libstarpu_la-variable_interface.lo `test -f
'datawizard/interfaces/variable_interface.c' || echo
'./'`datawizard/interfaces/variable_interface.c
datawizard/interfaces/variable_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-variable_interface.o
datawizard/interfaces/variable_interface.c -o
libstarpu_la-variable_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-variable_interface.Tpo
.deps/libstarpu_la-variable_interface.Plo
libstarpu_la-void_interface.lo -MD -MP -MF
.deps/libstarpu_la-void_interface.Tpo -c -o libstarpu_la-void_interface.lo
`test -f 'datawizard/interfaces/void_interface.c' || echo
'./'`datawizard/interfaces/void_interface.c
datawizard/interfaces/void_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-void_interface.o
datawizard/interfaces/void_interface.c -o libstarpu_la-void_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-void_interface.Tpo
.deps/libstarpu_la-void_interface.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-malloc.lo
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c -o libstarpu_la-malloc.lo `test
-f 'util/malloc.c' || echo './'`util/malloc.c
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c util/malloc.c -fPIC -DPIC -o
.libs/libstarpu_la-malloc.o
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c util/malloc.c -o
libstarpu_la-malloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-malloc.Tpo .deps/libstarpu_la-malloc.Plo
libstarpu_la-execute_on_all.lo -MD -MP -MF
.deps/libstarpu_la-execute_on_all.Tpo -c -o libstarpu_la-execute_on_all.lo
`test -f 'util/execute_on_all.c' || echo './'`util/execute_on_all.c
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -fPIC -DPIC
-o .libs/libstarpu_la-execute_on_all.o
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -o
libstarpu_la-execute_on_all.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-execute_on_all.Tpo
.deps/libstarpu_la-execute_on_all.Plo
libstarpu_la-starpu_create_sync_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_create_sync_task.Tpo -c -o
libstarpu_la-starpu_create_sync_task.lo `test -f
'util/starpu_create_sync_task.c' || echo './'`util/starpu_create_sync_task.c
util/starpu_create_sync_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_create_sync_task.o
util/starpu_create_sync_task.c -o libstarpu_la-starpu_create_sync_task.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_create_sync_task.Tpo
.deps/libstarpu_la-starpu_create_sync_task.Plo
libstarpu_la-starpu_cublas.lo -MD -MP -MF
.deps/libstarpu_la-starpu_cublas.Tpo -c -o libstarpu_la-starpu_cublas.lo
`test -f 'util/starpu_cublas.c' || echo './'`util/starpu_cublas.c
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_cublas.o
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -o
libstarpu_la-starpu_cublas.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_cublas.Tpo
.deps/libstarpu_la-starpu_cublas.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-file.lo
-MD -MP -MF .deps/libstarpu_la-file.Tpo -c -o libstarpu_la-file.lo `test -f
'util/file.c' || echo './'`util/file.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-file.lo -MD
-MP -MF .deps/libstarpu_la-file.Tpo -c util/file.c -fPIC -DPIC -o
.libs/libstarpu_la-file.o
-MP -MF .deps/libstarpu_la-file.Tpo -c util/file.c -o libstarpu_la-file.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-file.Tpo .deps/libstarpu_la-file.Plo
libstarpu_la-starpu_data_cpy.lo -MD -MP -MF
.deps/libstarpu_la-starpu_data_cpy.Tpo -c -o libstarpu_la-starpu_data_cpy.lo
`test -f 'util/starpu_data_cpy.c' || echo './'`util/starpu_data_cpy.c
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -fPIC -DPIC
-o .libs/libstarpu_la-starpu_data_cpy.o
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -o
libstarpu_la-starpu_data_cpy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_data_cpy.Tpo
.deps/libstarpu_la-starpu_data_cpy.Plo
libstarpu_la-starpu_insert_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task.Tpo -c -o
libstarpu_la-starpu_insert_task.lo `test -f 'util/starpu_insert_task.c' ||
echo './'`util/starpu_insert_task.c
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_insert_task.o
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -o
libstarpu_la-starpu_insert_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task.Tpo
.deps/libstarpu_la-starpu_insert_task.Plo
libstarpu_la-starpu_insert_task_utils.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task_utils.Tpo -c -o
libstarpu_la-starpu_insert_task_utils.lo `test -f
'util/starpu_insert_task_utils.c' || echo './'`util/starpu_insert_task_utils.c
util/starpu_insert_task_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_insert_task_utils.o
util/starpu_insert_task_utils.c -o libstarpu_la-starpu_insert_task_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task_utils.Tpo
.deps/libstarpu_la-starpu_insert_task_utils.Plo
libstarpu_la-starpu_task_list.lo -MD -MP -MF
.deps/libstarpu_la-starpu_task_list.Tpo -c -o
libstarpu_la-starpu_task_list.lo `test -f 'util/starpu_task_list.c' || echo
'./'`util/starpu_task_list.c
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_task_list.o
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -o
libstarpu_la-starpu_task_list.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_task_list.Tpo
.deps/libstarpu_la-starpu_task_list.Plo
libstarpu_la-starpu_fxt.lo -MD -MP -MF .deps/libstarpu_la-starpu_fxt.Tpo -c
-o libstarpu_la-starpu_fxt.lo `test -f 'debug/traces/starpu_fxt.c' || echo
'./'`debug/traces/starpu_fxt.c
debug/traces/starpu_fxt.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_fxt.o
debug/traces/starpu_fxt.c -o libstarpu_la-starpu_fxt.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt.Tpo .deps/libstarpu_la-starpu_fxt.Plo
libstarpu_la-starpu_fxt_mpi.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c -o libstarpu_la-starpu_fxt_mpi.lo
`test -f 'debug/traces/starpu_fxt_mpi.c' || echo
'./'`debug/traces/starpu_fxt_mpi.c
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_mpi.o
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -o
libstarpu_la-starpu_fxt_mpi.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_mpi.Tpo
.deps/libstarpu_la-starpu_fxt_mpi.Plo
libstarpu_la-starpu_fxt_dag.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c -o libstarpu_la-starpu_fxt_dag.lo
`test -f 'debug/traces/starpu_fxt_dag.c' || echo
'./'`debug/traces/starpu_fxt_dag.c
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_dag.o
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -o
libstarpu_la-starpu_fxt_dag.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_dag.Tpo
.deps/libstarpu_la-starpu_fxt_dag.Plo
libstarpu_la-starpu_paje.lo -MD -MP -MF .deps/libstarpu_la-starpu_paje.Tpo -c
-o libstarpu_la-starpu_paje.lo `test -f 'debug/traces/starpu_paje.c' || echo
'./'`debug/traces/starpu_paje.c
debug/traces/starpu_paje.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_paje.o
debug/traces/starpu_paje.c -o libstarpu_la-starpu_paje.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_paje.Tpo .deps/libstarpu_la-starpu_paje.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-latency.lo
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c -o libstarpu_la-latency.lo
`test -f 'debug/latency.c' || echo './'`debug/latency.c
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c debug/latency.c -fPIC -DPIC -o
.libs/libstarpu_la-latency.o
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c debug/latency.c -o
libstarpu_la-latency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-latency.Tpo .deps/libstarpu_la-latency.Plo
libstarpu_la-structures_size.lo -MD -MP -MF
.deps/libstarpu_la-structures_size.Tpo -c -o libstarpu_la-structures_size.lo
`test -f 'debug/structures_size.c' || echo './'`debug/structures_size.c
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -fPIC
-DPIC -o .libs/libstarpu_la-structures_size.o
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -o
libstarpu_la-structures_size.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-structures_size.Tpo
.deps/libstarpu_la-structures_size.Plo
libstarpu_la-profiling.lo -MD -MP -MF .deps/libstarpu_la-profiling.Tpo -c -o
libstarpu_la-profiling.lo `test -f 'profiling/profiling.c' || echo
'./'`profiling/profiling.c
profiling/profiling.c -fPIC -DPIC -o .libs/libstarpu_la-profiling.o
profiling/profiling.c -o libstarpu_la-profiling.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling.Tpo .deps/libstarpu_la-profiling.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-bound.lo
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c -o libstarpu_la-bound.lo `test -f
'profiling/bound.c' || echo './'`profiling/bound.c
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c profiling/bound.c -fPIC -DPIC -o
.libs/libstarpu_la-bound.o
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c profiling/bound.c -o
libstarpu_la-bound.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-bound.Tpo .deps/libstarpu_la-bound.Plo
libstarpu_la-profiling_helpers.lo -MD -MP -MF
.deps/libstarpu_la-profiling_helpers.Tpo -c -o
libstarpu_la-profiling_helpers.lo `test -f 'profiling/profiling_helpers.c' ||
echo './'`profiling/profiling_helpers.c
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c
-fPIC -DPIC -o .libs/libstarpu_la-profiling_helpers.o
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c -o
libstarpu_la-profiling_helpers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling_helpers.Tpo
.deps/libstarpu_la-profiling_helpers.Plo
libstarpu_la-starpu_top.lo -MD -MP -MF .deps/libstarpu_la-starpu_top.Tpo -c
-o libstarpu_la-starpu_top.lo `test -f 'top/starpu_top.c' || echo
'./'`top/starpu_top.c
top/starpu_top.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_top.o
top/starpu_top.c -o libstarpu_la-starpu_top.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_top.Tpo .deps/libstarpu_la-starpu_top.Plo
libstarpu_la-starputop_task.lo -MD -MP -MF
.deps/libstarpu_la-starputop_task.Tpo -c -o libstarpu_la-starputop_task.lo
`test -f 'top/starputop_task.c' || echo './'`top/starputop_task.c
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_task.o
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -o
libstarpu_la-starputop_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_task.Tpo
.deps/libstarpu_la-starputop_task.Plo
libstarpu_la-starputop_message_queue.lo -MD -MP -MF
.deps/libstarpu_la-starputop_message_queue.Tpo -c -o
libstarpu_la-starputop_message_queue.lo `test -f
'top/starputop_message_queue.c' || echo './'`top/starputop_message_queue.c
top/starputop_message_queue.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_message_queue.o
top/starputop_message_queue.c -o libstarpu_la-starputop_message_queue.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_message_queue.Tpo
.deps/libstarpu_la-starputop_message_queue.Plo
libstarpu_la-starputop_connection.lo -MD -MP -MF
.deps/libstarpu_la-starputop_connection.Tpo -c -o
libstarpu_la-starputop_connection.lo `test -f 'top/starputop_connection.c' ||
echo './'`top/starputop_connection.c
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c
-fPIC -DPIC -o .libs/libstarpu_la-starputop_connection.o
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c -o
libstarpu_la-starputop_connection.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_connection.Tpo
.deps/libstarpu_la-starputop_connection.Plo
libstarpu_la-driver_cpu.lo -MD -MP -MF .deps/libstarpu_la-driver_cpu.Tpo -c
-o libstarpu_la-driver_cpu.lo `test -f 'drivers/cpu/driver_cpu.c' || echo
'./'`drivers/cpu/driver_cpu.c
drivers/cpu/driver_cpu.c -fPIC -DPIC -o .libs/libstarpu_la-driver_cpu.o
drivers/cpu/driver_cpu.c -o libstarpu_la-driver_cpu.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_cpu.Tpo .deps/libstarpu_la-driver_cpu.Plo
libstarpu_la-driver_cuda.lo -MD -MP -MF .deps/libstarpu_la-driver_cuda.Tpo -c
-o libstarpu_la-driver_cuda.lo `test -f 'drivers/cuda/driver_cuda.c' || echo
'./'`drivers/cuda/driver_cuda.c
drivers/cuda/driver_cuda.c -fPIC -DPIC -o .libs/libstarpu_la-driver_cuda.o
drivers/cuda/driver_cuda.c -o libstarpu_la-driver_cuda.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_cuda.Tpo .deps/libstarpu_la-driver_cuda.Plo
libstarpu_la-driver_opencl.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl.Tpo -c -o libstarpu_la-driver_opencl.lo
`test -f 'drivers/opencl/driver_opencl.c' || echo
'./'`drivers/opencl/driver_opencl.c
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -fPIC
-DPIC -o .libs/libstarpu_la-driver_opencl.o
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -o
libstarpu_la-driver_opencl.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl.Tpo
.deps/libstarpu_la-driver_opencl.Plo
libstarpu_la-driver_opencl_utils.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl_utils.Tpo -c -o
libstarpu_la-driver_opencl_utils.lo `test -f
'drivers/opencl/driver_opencl_utils.c' || echo
'./'`drivers/opencl/driver_opencl_utils.c
drivers/opencl/driver_opencl_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-driver_opencl_utils.o
drivers/opencl/driver_opencl_utils.c -o libstarpu_la-driver_opencl_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl_utils.Tpo
.deps/libstarpu_la-driver_opencl_utils.Plo
/bin/bash ../libtool --tag=CC --mode=link gcc -W -Wall -Wextra
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -version-number 0:0:0
-no-undefined -l:/usr/local/cuda/lib64/libcublas.so -o libstarpu.la -rpath
/usr/local/lib libstarpu_la-barrier.lo libstarpu_la-hash.lo
libstarpu_la-htable32.lo libstarpu_la-rwlock.lo
libstarpu_la-starpu_spinlock.lo libstarpu_la-timing.lo libstarpu_la-fxt.lo
libstarpu_la-utils.lo libstarpu_la-jobs.lo libstarpu_la-task.lo
libstarpu_la-task_bundle.lo libstarpu_la-workers.lo
libstarpu_la-combined_workers.lo libstarpu_la-topology.lo
libstarpu_la-debug.lo libstarpu_la-errorcheck.lo
libstarpu_la-progress_hook.lo libstarpu_la-cg.lo libstarpu_la-dependencies.lo
libstarpu_la-implicit_data_deps.lo libstarpu_la-tags.lo
libstarpu_la-task_deps.lo libstarpu_la-htable.lo
libstarpu_la-data_concurrency.lo libstarpu_la-perfmodel_history.lo
libstarpu_la-perfmodel_bus.lo libstarpu_la-perfmodel.lo
libstarpu_la-regression.lo libstarpu_la-sched_policy.lo
libstarpu_la-priorities.lo libstarpu_la-parallel_task.lo
libstarpu_la-deque_modeling_policy_data_aware.lo libstarpu_la-heft.lo
libstarpu_la-random_policy.lo libstarpu_la-stack_queues.lo
libstarpu_la-deque_queues.lo libstarpu_la-fifo_queues.lo
libstarpu_la-detect_combined_workers.lo libstarpu_la-parallel_heft.lo
libstarpu_la-parallel_greedy.lo libstarpu_la-driver_common.lo
libstarpu_la-memory_nodes.lo libstarpu_la-write_back.lo
libstarpu_la-coherency.lo libstarpu_la-data_request.lo
libstarpu_la-progress.lo libstarpu_la-copy_driver.lo libstarpu_la-filters.lo
libstarpu_la-sort_data_handles.lo libstarpu_la-memalloc.lo
libstarpu_la-footprint.lo libstarpu_la-datastats.lo
libstarpu_la-user_interactions.lo libstarpu_la-reduction.lo
libstarpu_la-data_interface.lo libstarpu_la-bcsr_interface.lo
libstarpu_la-csr_interface.lo libstarpu_la-matrix_filters.lo
libstarpu_la-matrix_interface.lo libstarpu_la-block_filters.lo
libstarpu_la-block_interface.lo libstarpu_la-vector_interface.lo
libstarpu_la-bcsr_filters.lo libstarpu_la-csr_filters.lo
libstarpu_la-vector_filters.lo libstarpu_la-variable_interface.lo
libstarpu_la-void_interface.lo libstarpu_la-malloc.lo
libstarpu_la-execute_on_all.lo libstarpu_la-starpu_create_sync_task.lo
libstarpu_la-starpu_cublas.lo libstarpu_la-file.lo
libstarpu_la-starpu_data_cpy.lo libstarpu_la-starpu_insert_task.lo
libstarpu_la-starpu_insert_task_utils.lo libstarpu_la-starpu_task_list.lo
libstarpu_la-starpu_fxt.lo libstarpu_la-starpu_fxt_mpi.lo
libstarpu_la-starpu_fxt_dag.lo libstarpu_la-starpu_paje.lo
libstarpu_la-latency.lo libstarpu_la-structures_size.lo
libstarpu_la-profiling.lo libstarpu_la-bound.lo
libstarpu_la-profiling_helpers.lo libstarpu_la-starpu_top.lo
libstarpu_la-starputop_task.lo libstarpu_la-starputop_message_queue.lo
libstarpu_la-starputop_connection.lo libstarpu_la-driver_cpu.lo
libstarpu_la-driver_cuda.lo libstarpu_la-driver_opencl.lo
libstarpu_la-driver_opencl_utils.lo -L/usr/local/cuda/lib64 -lcudart
-lcublas -lcuda -lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim
-lrt -lpthread /usr/lib/libOpenCL.so.1.0.0
libtool: link: gcc -shared .libs/libstarpu_la-barrier.o
.libs/libstarpu_la-hash.o .libs/libstarpu_la-htable32.o
.libs/libstarpu_la-rwlock.o .libs/libstarpu_la-starpu_spinlock.o
.libs/libstarpu_la-timing.o .libs/libstarpu_la-fxt.o
.libs/libstarpu_la-utils.o .libs/libstarpu_la-jobs.o
.libs/libstarpu_la-task.o .libs/libstarpu_la-task_bundle.o
.libs/libstarpu_la-workers.o .libs/libstarpu_la-combined_workers.o
.libs/libstarpu_la-topology.o .libs/libstarpu_la-debug.o
.libs/libstarpu_la-errorcheck.o .libs/libstarpu_la-progress_hook.o
.libs/libstarpu_la-cg.o .libs/libstarpu_la-dependencies.o
.libs/libstarpu_la-implicit_data_deps.o .libs/libstarpu_la-tags.o
.libs/libstarpu_la-task_deps.o .libs/libstarpu_la-htable.o
.libs/libstarpu_la-data_concurrency.o .libs/libstarpu_la-perfmodel_history.o
.libs/libstarpu_la-perfmodel_bus.o .libs/libstarpu_la-perfmodel.o
.libs/libstarpu_la-regression.o .libs/libstarpu_la-sched_policy.o
.libs/libstarpu_la-priorities.o .libs/libstarpu_la-parallel_task.o
.libs/libstarpu_la-heft.o .libs/libstarpu_la-random_policy.o
.libs/libstarpu_la-stack_queues.o .libs/libstarpu_la-deque_queues.o
.libs/libstarpu_la-fifo_queues.o .libs/libstarpu_la-detect_combined_workers.o
.libs/libstarpu_la-parallel_heft.o .libs/libstarpu_la-parallel_greedy.o
.libs/libstarpu_la-driver_common.o .libs/libstarpu_la-memory_nodes.o
.libs/libstarpu_la-write_back.o .libs/libstarpu_la-coherency.o
.libs/libstarpu_la-data_request.o .libs/libstarpu_la-progress.o
.libs/libstarpu_la-copy_driver.o .libs/libstarpu_la-filters.o
.libs/libstarpu_la-sort_data_handles.o .libs/libstarpu_la-memalloc.o
.libs/libstarpu_la-footprint.o .libs/libstarpu_la-datastats.o
.libs/libstarpu_la-user_interactions.o .libs/libstarpu_la-reduction.o
.libs/libstarpu_la-data_interface.o .libs/libstarpu_la-bcsr_interface.o
.libs/libstarpu_la-csr_interface.o .libs/libstarpu_la-matrix_filters.o
.libs/libstarpu_la-matrix_interface.o .libs/libstarpu_la-block_filters.o
.libs/libstarpu_la-block_interface.o .libs/libstarpu_la-vector_interface.o
.libs/libstarpu_la-bcsr_filters.o .libs/libstarpu_la-csr_filters.o
.libs/libstarpu_la-vector_filters.o .libs/libstarpu_la-variable_interface.o
.libs/libstarpu_la-void_interface.o .libs/libstarpu_la-malloc.o
.libs/libstarpu_la-starpu_cublas.o .libs/libstarpu_la-file.o
.libs/libstarpu_la-starpu_data_cpy.o .libs/libstarpu_la-starpu_insert_task.o
.libs/libstarpu_la-starpu_task_list.o .libs/libstarpu_la-starpu_fxt.o
.libs/libstarpu_la-starpu_fxt_mpi.o .libs/libstarpu_la-starpu_fxt_dag.o
.libs/libstarpu_la-starpu_paje.o .libs/libstarpu_la-latency.o
.libs/libstarpu_la-structures_size.o .libs/libstarpu_la-profiling.o
.libs/libstarpu_la-bound.o .libs/libstarpu_la-profiling_helpers.o
.libs/libstarpu_la-starpu_top.o .libs/libstarpu_la-starputop_task.o
.libs/libstarpu_la-starputop_connection.o .libs/libstarpu_la-driver_cpu.o
.libs/libstarpu_la-driver_cuda.o .libs/libstarpu_la-driver_opencl.o
-l:/usr/local/cuda/lib64/libcublas.so -L/usr/local/cuda/lib64 -lcudart
-lcublas -lcuda -lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim -lrt
-lpthread -Wl,-soname -Wl,libstarpu.so.0 -o .libs/libstarpu.so.0.0.0
libtool: link: (cd ".libs" && rm -f "libstarpu.so.0" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so.0")
libtool: link: (cd ".libs" && rm -f "libstarpu.so" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so")
libtool: link: ar cru .libs/libstarpu.a libstarpu_la-barrier.o
libstarpu_la-hash.o libstarpu_la-htable32.o libstarpu_la-rwlock.o
libstarpu_la-starpu_spinlock.o libstarpu_la-timing.o libstarpu_la-fxt.o
libstarpu_la-utils.o libstarpu_la-jobs.o libstarpu_la-task.o
libstarpu_la-task_bundle.o libstarpu_la-workers.o
libstarpu_la-combined_workers.o libstarpu_la-topology.o libstarpu_la-debug.o
libstarpu_la-errorcheck.o libstarpu_la-progress_hook.o libstarpu_la-cg.o
libstarpu_la-dependencies.o libstarpu_la-implicit_data_deps.o
libstarpu_la-tags.o libstarpu_la-task_deps.o libstarpu_la-htable.o
libstarpu_la-data_concurrency.o libstarpu_la-perfmodel_history.o
libstarpu_la-perfmodel_bus.o libstarpu_la-perfmodel.o
libstarpu_la-regression.o libstarpu_la-sched_policy.o
libstarpu_la-priorities.o libstarpu_la-parallel_task.o
libstarpu_la-deque_modeling_policy_data_aware.o libstarpu_la-heft.o
libstarpu_la-random_policy.o libstarpu_la-stack_queues.o
libstarpu_la-deque_queues.o libstarpu_la-fifo_queues.o
libstarpu_la-detect_combined_workers.o libstarpu_la-parallel_heft.o
libstarpu_la-parallel_greedy.o libstarpu_la-driver_common.o
libstarpu_la-memory_nodes.o libstarpu_la-write_back.o
libstarpu_la-coherency.o libstarpu_la-data_request.o libstarpu_la-progress.o
libstarpu_la-copy_driver.o libstarpu_la-filters.o
libstarpu_la-sort_data_handles.o libstarpu_la-memalloc.o
libstarpu_la-footprint.o libstarpu_la-datastats.o
libstarpu_la-user_interactions.o libstarpu_la-reduction.o
libstarpu_la-data_interface.o libstarpu_la-bcsr_interface.o
libstarpu_la-csr_interface.o libstarpu_la-matrix_filters.o
libstarpu_la-matrix_interface.o libstarpu_la-block_filters.o
libstarpu_la-block_interface.o libstarpu_la-vector_interface.o
libstarpu_la-bcsr_filters.o libstarpu_la-csr_filters.o
libstarpu_la-vector_filters.o libstarpu_la-variable_interface.o
libstarpu_la-void_interface.o libstarpu_la-malloc.o
libstarpu_la-execute_on_all.o libstarpu_la-starpu_create_sync_task.o
libstarpu_la-starpu_cublas.o libstarpu_la-file.o
libstarpu_la-starpu_data_cpy.o libstarpu_la-starpu_insert_task.o
libstarpu_la-starpu_insert_task_utils.o libstarpu_la-starpu_task_list.o
libstarpu_la-starpu_fxt.o libstarpu_la-starpu_fxt_mpi.o
libstarpu_la-starpu_fxt_dag.o libstarpu_la-starpu_paje.o
libstarpu_la-latency.o libstarpu_la-structures_size.o
libstarpu_la-profiling.o libstarpu_la-bound.o
libstarpu_la-profiling_helpers.o libstarpu_la-starpu_top.o
libstarpu_la-starputop_task.o libstarpu_la-starputop_message_queue.o
libstarpu_la-starputop_connection.o libstarpu_la-driver_cpu.o
libstarpu_la-driver_cuda.o libstarpu_la-driver_opencl.o
libtool: link: ranlib .libs/libstarpu.a
libtool: link: ( cd ".libs" && rm -f "libstarpu.la" && ln -s
"../libstarpu.la" "libstarpu.la" )
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/src'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/src'
Making all in tools
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tools'
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tools'
gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include -I../gcc-plugin/src
-I../include/ -I../tools/ -I../mpi/ -I../src -I../src -D_GNU_SOURCE
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_calibrate_bus.o
-MD -MP -MF .deps/starpu_calibrate_bus.Tpo -c -o starpu_calibrate_bus.o
starpu_calibrate_bus.c
mv -f .deps/starpu_calibrate_bus.Tpo .deps/starpu_calibrate_bus.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -I/usr/local/cuda/include
-I/usr/include/CL/ -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_calibrate_bus
starpu_calibrate_bus.o ../src/libstarpu.la -lrt -lpthread
libtool: link: gcc -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o
.libs/starpu_calibrate_bus starpu_calibrate_bus.o /usr/lib/libOpenCL.so.1.0.0
-l:/usr/local/cuda/lib64/libcublas.so ../src/.libs/libstarpu.so -lrt
-lpthread
starpu_perfmodel_display.o -MD -MP -MF .deps/starpu_perfmodel_display.Tpo -c
-o starpu_perfmodel_display.o starpu_perfmodel_display.c
mv -f .deps/starpu_perfmodel_display.Tpo .deps/starpu_perfmodel_display.Po
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_perfmodel_display
starpu_perfmodel_display.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_perfmodel_display starpu_perfmodel_display.o
/usr/lib/libOpenCL.so.1.0.0 -l:/usr/local/cuda/lib64/libcublas.so
../src/.libs/libstarpu.so -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_perfmodel_plot.o
-MD -MP -MF .deps/starpu_perfmodel_plot.Tpo -c -o starpu_perfmodel_plot.o
starpu_perfmodel_plot.c
mv -f .deps/starpu_perfmodel_plot.Tpo .deps/starpu_perfmodel_plot.Po
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_perfmodel_plot
starpu_perfmodel_plot.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_perfmodel_plot starpu_perfmodel_plot.o
starpu_machine_display.o -MD -MP -MF .deps/starpu_machine_display.Tpo -c -o
starpu_machine_display.o starpu_machine_display.c
mv -f .deps/starpu_machine_display.Tpo .deps/starpu_machine_display.Po
-I/home/deshpandea/lpng155/
-I/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_machine_display
starpu_machine_display.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_machine_display starpu_machine_display.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT cbc2paje.o -MD -MP -MF
.deps/cbc2paje.Tpo -c -o cbc2paje.o cbc2paje.c
mv -f .deps/cbc2paje.Tpo .deps/cbc2paje.Po
-l:/usr/local/cuda/lib64/libcublas.so -o cbc2paje cbc2paje.o
../src/libstarpu.la -lrt -lpthread /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/cbc2paje cbc2paje.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT lp2paje.o -MD -MP -MF
.deps/lp2paje.Tpo -c -o lp2paje.o lp2paje.c
mv -f .deps/lp2paje.Tpo .deps/lp2paje.Po
-l:/usr/local/cuda/lib64/libcublas.so -o lp2paje lp2paje.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/lp2paje lp2paje.o
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tools'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tools'
Making all in tests
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make all-recursive
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[3]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
-I../include/ -I../src -I../src/ -D_GNU_SOURCE -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT restart.o -MD -MP -MF
.deps/restart.Tpo -c -o restart.o `test -f 'core/restart.c' || echo
'./'`core/restart.c
mv -f .deps/restart.Tpo .deps/restart.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -L/usr/local/cuda/lib64
-lcudart -lcublas -lcuda -lstdc++
-l:/usr/local/cuda/lib64/libcublas.so -o core/restart restart.o
libtool: link: gcc -Wall -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/restart
restart.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-l:/usr/local/cuda/lib64/libcublas.so ../src/.libs/libstarpu.so -lrt -lpthread
execute_on_a_specific_worker.o -MD -MP -MF
.deps/execute_on_a_specific_worker.Tpo -c -o execute_on_a_specific_worker.o
`test -f 'core/execute_on_a_specific_worker.c' || echo
'./'`core/execute_on_a_specific_worker.c
mv -f .deps/execute_on_a_specific_worker.Tpo
.deps/execute_on_a_specific_worker.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/execute_on_a_specific_worker
execute_on_a_specific_worker.o ../src/libstarpu.la -lrt -lpthread
core/.libs/execute_on_a_specific_worker execute_on_a_specific_worker.o
/usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT insert_task.o -MD -MP
-MF .deps/insert_task.Tpo -c -o insert_task.o `test -f 'core/insert_task.c'
|| echo './'`core/insert_task.c
mv -f .deps/insert_task.Tpo .deps/insert_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/insert_task insert_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/insert_task
insert_task.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT multithreaded.o -MD -MP
-MF .deps/multithreaded.Tpo -c -o multithreaded.o `test -f
'core/multithreaded.c' || echo './'`core/multithreaded.c
mv -f .deps/multithreaded.Tpo .deps/multithreaded.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/multithreaded multithreaded.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/multithreaded
multithreaded.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT multithreaded_init.o
-MD -MP -MF .deps/multithreaded_init.Tpo -c -o multithreaded_init.o `test -f
'core/multithreaded_init.c' || echo './'`core/multithreaded_init.c
mv -f .deps/multithreaded_init.Tpo .deps/multithreaded_init.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/multithreaded_init
multithreaded_init.o ../src/libstarpu.la -lrt -lpthread
core/.libs/multithreaded_init multithreaded_init.o
starpu_task_wait_for_all.o -MD -MP -MF .deps/starpu_task_wait_for_all.Tpo -c
-o starpu_task_wait_for_all.o `test -f 'core/starpu_task_wait_for_all.c' ||
echo './'`core/starpu_task_wait_for_all.c
mv -f .deps/starpu_task_wait_for_all.Tpo .deps/starpu_task_wait_for_all.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/starpu_task_wait_for_all
starpu_task_wait_for_all.o ../src/libstarpu.la -lrt -lpthread
core/.libs/starpu_task_wait_for_all starpu_task_wait_for_all.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_task_wait.o -MD
-MP -MF .deps/starpu_task_wait.Tpo -c -o starpu_task_wait.o `test -f
'core/starpu_task_wait.c' || echo './'`core/starpu_task_wait.c
mv -f .deps/starpu_task_wait.Tpo .deps/starpu_task_wait.Po
starpu_task_wait.o ../src/libstarpu.la -lrt -lpthread
core/.libs/starpu_task_wait starpu_task_wait.o /usr/lib/libOpenCL.so.1.0.0
-L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda -lstdc++
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT static_restartable.o
-MD -MP -MF .deps/static_restartable.Tpo -c -o static_restartable.o `test -f
'core/static_restartable.c' || echo './'`core/static_restartable.c
mv -f .deps/static_restartable.Tpo .deps/static_restartable.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/static_restartable
static_restartable.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable static_restartable.o
static_restartable_using_initializer.o -MD -MP -MF
.deps/static_restartable_using_initializer.Tpo -c -o
static_restartable_using_initializer.o `test -f
'core/static_restartable_using_initializer.c' || echo
'./'`core/static_restartable_using_initializer.c
mv -f .deps/static_restartable_using_initializer.Tpo
.deps/static_restartable_using_initializer.Po
static_restartable_using_initializer.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable_using_initializer
static_restartable_using_initializer.o /usr/lib/libOpenCL.so.1.0.0
static_restartable_tag.o -MD -MP -MF .deps/static_restartable_tag.Tpo -c -o
static_restartable_tag.o `test -f 'core/static_restartable_tag.c' || echo
'./'`core/static_restartable_tag.c
mv -f .deps/static_restartable_tag.Tpo .deps/static_restartable_tag.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/static_restartable_tag
static_restartable_tag.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable_tag static_restartable_tag.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT regenerate.o -MD -MP
-MF .deps/regenerate.Tpo -c -o regenerate.o `test -f 'core/regenerate.c' ||
echo './'`core/regenerate.c
mv -f .deps/regenerate.Tpo .deps/regenerate.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/regenerate regenerate.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/regenerate
regenerate.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
wait_all_regenerable_tasks.o -MD -MP -MF .deps/wait_all_regenerable_tasks.Tpo
-c -o wait_all_regenerable_tasks.o `test -f
'core/wait_all_regenerable_tasks.c' || echo
'./'`core/wait_all_regenerable_tasks.c
mv -f .deps/wait_all_regenerable_tasks.Tpo .deps/wait_all_regenerable_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/wait_all_regenerable_tasks
wait_all_regenerable_tasks.o ../src/libstarpu.la -lrt -lpthread
core/.libs/wait_all_regenerable_tasks wait_all_regenerable_tasks.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT subgraph_repeat.o -MD
-MP -MF .deps/subgraph_repeat.Tpo -c -o subgraph_repeat.o `test -f
'core/subgraph_repeat.c' || echo './'`core/subgraph_repeat.c
core/subgraph_repeat.c: In function ‘dummy_func’:
core/subgraph_repeat.c:50: warning: value computed is not used
mv -f .deps/subgraph_repeat.Tpo .deps/subgraph_repeat.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/subgraph_repeat
subgraph_repeat.o ../src/libstarpu.la -lrt -lpthread
core/.libs/subgraph_repeat subgraph_repeat.o /usr/lib/libOpenCL.so.1.0.0
subgraph_repeat_regenerate.o -MD -MP -MF .deps/subgraph_repeat_regenerate.Tpo
-c -o subgraph_repeat_regenerate.o `test -f
'core/subgraph_repeat_regenerate.c' || echo
'./'`core/subgraph_repeat_regenerate.c
core/subgraph_repeat_regenerate.c: In function ‘dummy_func’:
core/subgraph_repeat_regenerate.c:50: warning: value computed is not used
mv -f .deps/subgraph_repeat_regenerate.Tpo .deps/subgraph_repeat_regenerate.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/subgraph_repeat_regenerate
subgraph_repeat_regenerate.o ../src/libstarpu.la -lrt -lpthread
core/.libs/subgraph_repeat_regenerate subgraph_repeat_regenerate.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task.o -MD -MP
-MF .deps/empty_task.Tpo -c -o empty_task.o `test -f 'core/empty_task.c' ||
echo './'`core/empty_task.c
mv -f .deps/empty_task.Tpo .deps/empty_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task empty_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/empty_task
empty_task.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task_sync_point.o
-MD -MP -MF .deps/empty_task_sync_point.Tpo -c -o empty_task_sync_point.o
`test -f 'core/empty_task_sync_point.c' || echo
'./'`core/empty_task_sync_point.c
mv -f .deps/empty_task_sync_point.Tpo .deps/empty_task_sync_point.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_sync_point
empty_task_sync_point.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_sync_point empty_task_sync_point.o
empty_task_sync_point_tasks.o -MD -MP -MF
.deps/empty_task_sync_point_tasks.Tpo -c -o empty_task_sync_point_tasks.o
`test -f 'core/empty_task_sync_point_tasks.c' || echo
'./'`core/empty_task_sync_point_tasks.c
mv -f .deps/empty_task_sync_point_tasks.Tpo
.deps/empty_task_sync_point_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_sync_point_tasks
empty_task_sync_point_tasks.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_sync_point_tasks empty_task_sync_point_tasks.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task_chain.o -MD
-MP -MF .deps/empty_task_chain.Tpo -c -o empty_task_chain.o `test -f
'core/empty_task_chain.c' || echo './'`core/empty_task_chain.c
mv -f .deps/empty_task_chain.Tpo .deps/empty_task_chain.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_chain
empty_task_chain.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_chain empty_task_chain.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_wait_api.o -MD -MP
-MF .deps/tag_wait_api.Tpo -c -o tag_wait_api.o `test -f
'core/tag_wait_api.c' || echo './'`core/tag_wait_api.c
mv -f .deps/tag_wait_api.Tpo .deps/tag_wait_api.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/tag_wait_api tag_wait_api.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/tag_wait_api
tag_wait_api.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT task_wait_api.o -MD -MP
-MF .deps/task_wait_api.Tpo -c -o task_wait_api.o `test -f
'core/task_wait_api.c' || echo './'`core/task_wait_api.c
mv -f .deps/task_wait_api.Tpo .deps/task_wait_api.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/task_wait_api task_wait_api.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/task_wait_api
task_wait_api.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
declare_deps_in_callback.o -MD -MP -MF .deps/declare_deps_in_callback.Tpo -c
-o declare_deps_in_callback.o `test -f 'core/declare_deps_in_callback.c' ||
echo './'`core/declare_deps_in_callback.c
mv -f .deps/declare_deps_in_callback.Tpo .deps/declare_deps_in_callback.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/declare_deps_in_callback
declare_deps_in_callback.o ../src/libstarpu.la -lrt -lpthread
core/.libs/declare_deps_in_callback declare_deps_in_callback.o
declare_deps_after_submission.o -MD -MP -MF
.deps/declare_deps_after_submission.Tpo -c -o declare_deps_after_submission.o
`test -f 'core/declare_deps_after_submission.c' || echo
'./'`core/declare_deps_after_submission.c
mv -f .deps/declare_deps_after_submission.Tpo
.deps/declare_deps_after_submission.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/declare_deps_after_submission
declare_deps_after_submission.o ../src/libstarpu.la -lrt -lpthread
core/.libs/declare_deps_after_submission declare_deps_after_submission.o
declare_deps_after_submission_synchronous.o -MD -MP -MF
.deps/declare_deps_after_submission_synchronous.Tpo -c -o
declare_deps_after_submission_synchronous.o `test -f
'core/declare_deps_after_submission_synchronous.c' || echo
'./'`core/declare_deps_after_submission_synchronous.c
mv -f .deps/declare_deps_after_submission_synchronous.Tpo
.deps/declare_deps_after_submission_synchronous.Po
declare_deps_after_submission_synchronous.o ../src/libstarpu.la -lrt
core/.libs/declare_deps_after_submission_synchronous
declare_deps_after_submission_synchronous.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT get_current_task.o -MD
-MP -MF .deps/get_current_task.Tpo -c -o get_current_task.o `test -f
'core/get_current_task.c' || echo './'`core/get_current_task.c
mv -f .deps/get_current_task.Tpo .deps/get_current_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/get_current_task
get_current_task.o ../src/libstarpu.la -lrt -lpthread
core/.libs/get_current_task get_current_task.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_cb.o -MD -MP
-MF .deps/acquire_cb.Tpo -c -o acquire_cb.o `test -f
'datawizard/acquire_cb.c' || echo './'`datawizard/acquire_cb.c
mv -f .deps/acquire_cb.Tpo .deps/acquire_cb.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_cb acquire_cb.o
datawizard/.libs/acquire_cb acquire_cb.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_cb_insert.o -MD
-MP -MF .deps/acquire_cb_insert.Tpo -c -o acquire_cb_insert.o `test -f
'datawizard/acquire_cb_insert.c' || echo './'`datawizard/acquire_cb_insert.c
mv -f .deps/acquire_cb_insert.Tpo .deps/acquire_cb_insert.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_cb_insert
acquire_cb_insert.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/acquire_cb_insert acquire_cb_insert.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_release.o -MD
-MP -MF .deps/acquire_release.Tpo -c -o acquire_release.o `test -f
'datawizard/acquire_release.c' || echo './'`datawizard/acquire_release.c
mv -f .deps/acquire_release.Tpo .deps/acquire_release.Po
/bin/mkdir -p `dirname datawizard/acquire_release_cuda.o`
/usr/local/cuda/bin/nvcc datawizard/acquire_release_cuda.cu -c -o
datawizard/acquire_release_cuda.o --compiler-options -fno-strict-aliasing
-I/usr/local/cuda/include -m64 -I../include/ -I../include
-I/usr/local/include
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_release
acquire_release.o datawizard/acquire_release_cuda.o ../src/libstarpu.la
datawizard/.libs/acquire_release acquire_release.o
datawizard/acquire_release_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_release2.o -MD
-MP -MF .deps/acquire_release2.Tpo -c -o acquire_release2.o `test -f
'datawizard/acquire_release2.c' || echo './'`datawizard/acquire_release2.c
datawizard/acquire_release2.c:59: warning: #warning TODO add threads
mv -f .deps/acquire_release2.Tpo .deps/acquire_release2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_release2
acquire_release2.o datawizard/acquire_release_cuda.o ../src/libstarpu.la
datawizard/.libs/acquire_release2 acquire_release2.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT copy.o -MD -MP -MF
.deps/copy.Tpo -c -o copy.o `test -f 'datawizard/copy.c' || echo
'./'`datawizard/copy.c
mv -f .deps/copy.Tpo .deps/copy.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/copy copy.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/copy
copy.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_implicit_deps.o
-MD -MP -MF .deps/data_implicit_deps.Tpo -c -o data_implicit_deps.o `test -f
'datawizard/data_implicit_deps.c' || echo './'`datawizard/data_implicit_deps.c
mv -f .deps/data_implicit_deps.Tpo .deps/data_implicit_deps.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_implicit_deps
data_implicit_deps.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/data_implicit_deps data_implicit_deps.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_lookup.o -MD -MP
-MF .deps/data_lookup.Tpo -c -o data_lookup.o `test -f
'datawizard/data_lookup.c' || echo './'`datawizard/data_lookup.c
mv -f .deps/data_lookup.Tpo .deps/data_lookup.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_lookup data_lookup.o
datawizard/.libs/data_lookup data_lookup.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT scratch.o -MD -MP -MF
.deps/scratch.Tpo -c -o scratch.o `test -f 'datawizard/scratch.c' || echo
'./'`datawizard/scratch.c
mv -f .deps/scratch.Tpo .deps/scratch.Po
/bin/mkdir -p `dirname datawizard/scratch_cuda.o`
/usr/local/cuda/bin/nvcc datawizard/scratch_cuda.cu -c -o
datawizard/scratch_cuda.o --compiler-options -fno-strict-aliasing
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/scratch scratch.o
datawizard/scratch_cuda.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/scratch
scratch.o datawizard/scratch_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT sync_and_notify_data.o
-MD -MP -MF .deps/sync_and_notify_data.Tpo -c -o sync_and_notify_data.o `test
-f 'datawizard/sync_and_notify_data.c' || echo
'./'`datawizard/sync_and_notify_data.c
mv -f .deps/sync_and_notify_data.Tpo .deps/sync_and_notify_data.Po
/bin/mkdir -p `dirname datawizard/sync_and_notify_data_kernels.o`
/usr/local/cuda/bin/nvcc datawizard/sync_and_notify_data_kernels.cu -c -o
datawizard/sync_and_notify_data_kernels.o --compiler-options
-fno-strict-aliasing -I/usr/local/cuda/include -m64 -I../include/
-I../include -I/usr/local/include
sync_and_notify_data_opencl.o -MD -MP -MF
.deps/sync_and_notify_data_opencl.Tpo -c -o sync_and_notify_data_opencl.o
`test -f 'datawizard/sync_and_notify_data_opencl.c' || echo
'./'`datawizard/sync_and_notify_data_opencl.c
mv -f .deps/sync_and_notify_data_opencl.Tpo
.deps/sync_and_notify_data_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/sync_and_notify_data
sync_and_notify_data.o datawizard/sync_and_notify_data_kernels.o
sync_and_notify_data_opencl.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_and_notify_data sync_and_notify_data.o
datawizard/sync_and_notify_data_kernels.o sync_and_notify_data_opencl.o
sync_and_notify_data_implicit.o -MD -MP -MF
.deps/sync_and_notify_data_implicit.Tpo -c -o sync_and_notify_data_implicit.o
`test -f 'datawizard/sync_and_notify_data_implicit.c' || echo
'./'`datawizard/sync_and_notify_data_implicit.c
mv -f .deps/sync_and_notify_data_implicit.Tpo
.deps/sync_and_notify_data_implicit.Po
datawizard/sync_and_notify_data_implicit sync_and_notify_data_implicit.o
datawizard/.libs/sync_and_notify_data_implicit
sync_and_notify_data_implicit.o datawizard/sync_and_notify_data_kernels.o
sync_and_notify_data_opencl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dsm_stress.o -MD -MP
-MF .deps/dsm_stress.Tpo -c -o dsm_stress.o `test -f
'datawizard/dsm_stress.c' || echo './'`datawizard/dsm_stress.c
mv -f .deps/dsm_stress.Tpo .deps/dsm_stress.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/dsm_stress dsm_stress.o
datawizard/.libs/dsm_stress dsm_stress.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT write_only_tmp_buffer.o
-MD -MP -MF .deps/write_only_tmp_buffer.Tpo -c -o write_only_tmp_buffer.o
`test -f 'datawizard/write_only_tmp_buffer.c' || echo
'./'`datawizard/write_only_tmp_buffer.c
mv -f .deps/write_only_tmp_buffer.Tpo .deps/write_only_tmp_buffer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/write_only_tmp_buffer
write_only_tmp_buffer.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/write_only_tmp_buffer write_only_tmp_buffer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_invalidation.o -MD
-MP -MF .deps/data_invalidation.Tpo -c -o data_invalidation.o `test -f
'datawizard/data_invalidation.c' || echo './'`datawizard/data_invalidation.c
mv -f .deps/data_invalidation.Tpo .deps/data_invalidation.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_invalidation
data_invalidation.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/data_invalidation data_invalidation.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dining_philosophers.o
-MD -MP -MF .deps/dining_philosophers.Tpo -c -o dining_philosophers.o `test
-f 'datawizard/dining_philosophers.c' || echo
'./'`datawizard/dining_philosophers.c
mv -f .deps/dining_philosophers.Tpo .deps/dining_philosophers.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/dining_philosophers
dining_philosophers.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/dining_philosophers dining_philosophers.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT manual_reduction.o -MD
-MP -MF .deps/manual_reduction.Tpo -c -o manual_reduction.o `test -f
'datawizard/manual_reduction.c' || echo './'`datawizard/manual_reduction.c
mv -f .deps/manual_reduction.Tpo .deps/manual_reduction.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/manual_reduction
manual_reduction.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/manual_reduction manual_reduction.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT readers_and_writers.o
-MD -MP -MF .deps/readers_and_writers.Tpo -c -o readers_and_writers.o `test
-f 'datawizard/readers_and_writers.c' || echo
'./'`datawizard/readers_and_writers.c
mv -f .deps/readers_and_writers.Tpo .deps/readers_and_writers.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/readers_and_writers
readers_and_writers.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/readers_and_writers readers_and_writers.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT unpartition.o -MD -MP
-MF .deps/unpartition.Tpo -c -o unpartition.o `test -f
'datawizard/unpartition.c' || echo './'`datawizard/unpartition.c
mv -f .deps/unpartition.Tpo .deps/unpartition.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/unpartition unpartition.o
datawizard/.libs/unpartition unpartition.o /usr/lib/libOpenCL.so.1.0.0
user_interaction_implicit.o -MD -MP -MF .deps/user_interaction_implicit.Tpo
-c -o user_interaction_implicit.o `test -f
'datawizard/user_interaction_implicit.c' || echo
'./'`datawizard/user_interaction_implicit.c
mv -f .deps/user_interaction_implicit.Tpo .deps/user_interaction_implicit.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/user_interaction_implicit
user_interaction_implicit.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/user_interaction_implicit user_interaction_implicit.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT reclaim.o -MD -MP -MF
.deps/reclaim.Tpo -c -o reclaim.o `test -f 'datawizard/reclaim.c' || echo
'./'`datawizard/reclaim.c
mv -f .deps/reclaim.Tpo .deps/reclaim.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/reclaim reclaim.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/reclaim
reclaim.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
sync_with_data_with_mem.o -MD -MP -MF .deps/sync_with_data_with_mem.Tpo -c -o
sync_with_data_with_mem.o `test -f 'datawizard/sync_with_data_with_mem.c' ||
echo './'`datawizard/sync_with_data_with_mem.c
mv -f .deps/sync_with_data_with_mem.Tpo .deps/sync_with_data_with_mem.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/sync_with_data_with_mem
sync_with_data_with_mem.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_with_data_with_mem sync_with_data_with_mem.o
sync_with_data_with_mem_non_blocking.o -MD -MP -MF
.deps/sync_with_data_with_mem_non_blocking.Tpo -c -o
sync_with_data_with_mem_non_blocking.o `test -f
'datawizard/sync_with_data_with_mem_non_blocking.c' || echo
'./'`datawizard/sync_with_data_with_mem_non_blocking.c
mv -f .deps/sync_with_data_with_mem_non_blocking.Tpo
.deps/sync_with_data_with_mem_non_blocking.Po
sync_with_data_with_mem_non_blocking.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_with_data_with_mem_non_blocking
sync_with_data_with_mem_non_blocking.o /usr/lib/libOpenCL.so.1.0.0
sync_with_data_with_mem_non_blocking_implicit.o -MD -MP -MF
.deps/sync_with_data_with_mem_non_blocking_implicit.Tpo -c -o
sync_with_data_with_mem_non_blocking_implicit.o `test -f
'datawizard/sync_with_data_with_mem_non_blocking_implicit.c' || echo
'./'`datawizard/sync_with_data_with_mem_non_blocking_implicit.c
mv -f .deps/sync_with_data_with_mem_non_blocking_implicit.Tpo
.deps/sync_with_data_with_mem_non_blocking_implicit.Po
sync_with_data_with_mem_non_blocking_implicit.o ../src/libstarpu.la -lrt
datawizard/.libs/sync_with_data_with_mem_non_blocking_implicit
sync_with_data_with_mem_non_blocking_implicit.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mpi_like.o -MD -MP -MF
.deps/mpi_like.Tpo -c -o mpi_like.o `test -f 'datawizard/mpi_like.c' || echo
'./'`datawizard/mpi_like.c
mv -f .deps/mpi_like.Tpo .deps/mpi_like.Po
/bin/mkdir -p `dirname datawizard/cuda_codelet_unsigned_inc.o`
/usr/local/cuda/bin/nvcc datawizard/cuda_codelet_unsigned_inc.cu -c -o
datawizard/cuda_codelet_unsigned_inc.o --compiler-options
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/mpi_like mpi_like.o
datawizard/cuda_codelet_unsigned_inc.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/mpi_like
mpi_like.o datawizard/cuda_codelet_unsigned_inc.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mpi_like_async.o -MD
-MP -MF .deps/mpi_like_async.Tpo -c -o mpi_like_async.o `test -f
'datawizard/mpi_like_async.c' || echo './'`datawizard/mpi_like_async.c
mv -f .deps/mpi_like_async.Tpo .deps/mpi_like_async.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/mpi_like_async
mpi_like_async.o datawizard/cuda_codelet_unsigned_inc.o ../src/libstarpu.la
datawizard/.libs/mpi_like_async mpi_like_async.o
critical_section_with_void_interface.o -MD -MP -MF
.deps/critical_section_with_void_interface.Tpo -c -o
critical_section_with_void_interface.o `test -f
'datawizard/critical_section_with_void_interface.c' || echo
'./'`datawizard/critical_section_with_void_interface.c
mv -f .deps/critical_section_with_void_interface.Tpo
.deps/critical_section_with_void_interface.Po
critical_section_with_void_interface.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/critical_section_with_void_interface
critical_section_with_void_interface.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT increment_redux.o -MD
-MP -MF .deps/increment_redux.Tpo -c -o increment_redux.o `test -f
'datawizard/increment_redux.c' || echo './'`datawizard/increment_redux.c
mv -f .deps/increment_redux.Tpo .deps/increment_redux.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/increment_redux
increment_redux.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/increment_redux increment_redux.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT increment_redux_v2.o
-MD -MP -MF .deps/increment_redux_v2.Tpo -c -o increment_redux_v2.o `test -f
'datawizard/increment_redux_v2.c' || echo './'`datawizard/increment_redux_v2.c
mv -f .deps/increment_redux_v2.Tpo .deps/increment_redux_v2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/increment_redux_v2
increment_redux_v2.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/increment_redux_v2 increment_redux_v2.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT handle_to_pointer.o -MD
-MP -MF .deps/handle_to_pointer.Tpo -c -o handle_to_pointer.o `test -f
'datawizard/handle_to_pointer.c' || echo './'`datawizard/handle_to_pointer.c
mv -f .deps/handle_to_pointer.Tpo .deps/handle_to_pointer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/handle_to_pointer
handle_to_pointer.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/handle_to_pointer handle_to_pointer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT lazy_allocation.o -MD
-MP -MF .deps/lazy_allocation.Tpo -c -o lazy_allocation.o `test -f
'datawizard/lazy_allocation.c' || echo './'`datawizard/lazy_allocation.c
mv -f .deps/lazy_allocation.Tpo .deps/lazy_allocation.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/lazy_allocation
lazy_allocation.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/lazy_allocation lazy_allocation.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_init_noworker.o
-MD -MP -MF .deps/starpu_init_noworker.Tpo -c -o starpu_init_noworker.o `test
-f 'errorcheck/starpu_init_noworker.c' || echo
'./'`errorcheck/starpu_init_noworker.c
mv -f .deps/starpu_init_noworker.Tpo .deps/starpu_init_noworker.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/starpu_init_noworker
starpu_init_noworker.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/starpu_init_noworker starpu_init_noworker.o
invalid_blocking_calls.o -MD -MP -MF .deps/invalid_blocking_calls.Tpo -c -o
invalid_blocking_calls.o `test -f 'errorcheck/invalid_blocking_calls.c' ||
echo './'`errorcheck/invalid_blocking_calls.c
mv -f .deps/invalid_blocking_calls.Tpo .deps/invalid_blocking_calls.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/invalid_blocking_calls
invalid_blocking_calls.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/invalid_blocking_calls invalid_blocking_calls.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT invalid_tasks.o -MD -MP
-MF .deps/invalid_tasks.Tpo -c -o invalid_tasks.o `test -f
'errorcheck/invalid_tasks.c' || echo './'`errorcheck/invalid_tasks.c
mv -f .deps/invalid_tasks.Tpo .deps/invalid_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/invalid_tasks
invalid_tasks.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/invalid_tasks invalid_tasks.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT cublas_init.o -MD -MP
-MF .deps/cublas_init.Tpo -c -o cublas_init.o `test -f 'helper/cublas_init.c'
|| echo './'`helper/cublas_init.c
mv -f .deps/cublas_init.Tpo .deps/cublas_init.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/cublas_init cublas_init.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o helper/.libs/cublas_init
cublas_init.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_data_cpy.o -MD
-MP -MF .deps/starpu_data_cpy.Tpo -c -o starpu_data_cpy.o `test -f
'helper/starpu_data_cpy.c' || echo './'`helper/starpu_data_cpy.c
mv -f .deps/starpu_data_cpy.Tpo .deps/starpu_data_cpy.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/starpu_data_cpy
starpu_data_cpy.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/starpu_data_cpy starpu_data_cpy.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT pinned_memory.o -MD -MP
-MF .deps/pinned_memory.Tpo -c -o pinned_memory.o `test -f
'helper/pinned_memory.c' || echo './'`helper/pinned_memory.c
mv -f .deps/pinned_memory.Tpo .deps/pinned_memory.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/pinned_memory pinned_memory.o
helper/.libs/pinned_memory pinned_memory.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT execute_on_all.o -MD
-MP -MF .deps/execute_on_all.Tpo -c -o execute_on_all.o `test -f
'helper/execute_on_all.c' || echo './'`helper/execute_on_all.c
mv -f .deps/execute_on_all.Tpo .deps/execute_on_all.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/execute_on_all
execute_on_all.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/execute_on_all execute_on_all.o /usr/lib/libOpenCL.so.1.0.0
starpu_create_sync_task.o -MD -MP -MF .deps/starpu_create_sync_task.Tpo -c -o
starpu_create_sync_task.o `test -f 'helper/starpu_create_sync_task.c' || echo
'./'`helper/starpu_create_sync_task.c
mv -f .deps/starpu_create_sync_task.Tpo .deps/starpu_create_sync_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/starpu_create_sync_task
starpu_create_sync_task.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/starpu_create_sync_task starpu_create_sync_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT async_tasks_overhead.o
-MD -MP -MF .deps/async_tasks_overhead.Tpo -c -o async_tasks_overhead.o `test
-f 'microbenchs/async_tasks_overhead.c' || echo
'./'`microbenchs/async_tasks_overhead.c
mv -f .deps/async_tasks_overhead.Tpo .deps/async_tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/async_tasks_overhead
async_tasks_overhead.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/async_tasks_overhead async_tasks_overhead.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT sync_tasks_overhead.o
-MD -MP -MF .deps/sync_tasks_overhead.Tpo -c -o sync_tasks_overhead.o `test
-f 'microbenchs/sync_tasks_overhead.c' || echo
'./'`microbenchs/sync_tasks_overhead.c
mv -f .deps/sync_tasks_overhead.Tpo .deps/sync_tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/sync_tasks_overhead
microbenchs/.libs/sync_tasks_overhead sync_tasks_overhead.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tasks_overhead.o -MD
-MP -MF .deps/tasks_overhead.Tpo -c -o tasks_overhead.o `test -f
'microbenchs/tasks_overhead.c' || echo './'`microbenchs/tasks_overhead.c
mv -f .deps/tasks_overhead.Tpo .deps/tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/tasks_overhead
microbenchs/.libs/tasks_overhead tasks_overhead.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT prefetch_data_on_node.o
-MD -MP -MF .deps/prefetch_data_on_node.Tpo -c -o prefetch_data_on_node.o
`test -f 'microbenchs/prefetch_data_on_node.c' || echo
'./'`microbenchs/prefetch_data_on_node.c
mv -f .deps/prefetch_data_on_node.Tpo .deps/prefetch_data_on_node.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/prefetch_data_on_node
prefetch_data_on_node.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/prefetch_data_on_node prefetch_data_on_node.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT redundant_buffer.o -MD
-MP -MF .deps/redundant_buffer.Tpo -c -o redundant_buffer.o `test -f
'microbenchs/redundant_buffer.c' || echo './'`microbenchs/redundant_buffer.c
mv -f .deps/redundant_buffer.Tpo .deps/redundant_buffer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/redundant_buffer
redundant_buffer.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/redundant_buffer redundant_buffer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT local_pingpong.o -MD
-MP -MF .deps/local_pingpong.Tpo -c -o local_pingpong.o `test -f
'microbenchs/local_pingpong.c' || echo './'`microbenchs/local_pingpong.c
mv -f .deps/local_pingpong.Tpo .deps/local_pingpong.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/local_pingpong
local_pingpong.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/local_pingpong local_pingpong.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT overlap.o -MD -MP -MF
.deps/overlap.Tpo -c -o overlap.o `test -f 'overlap/overlap.c' || echo
'./'`overlap/overlap.c
mv -f .deps/overlap.Tpo .deps/overlap.Po
-l:/usr/local/cuda/lib64/libcublas.so -o overlap/overlap overlap.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o overlap/.libs/overlap
overlap.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
explicit_combined_worker.o -MD -MP -MF .deps/explicit_combined_worker.Tpo -c
-o explicit_combined_worker.o `test -f
'parallel_tasks/explicit_combined_worker.c' || echo
'./'`parallel_tasks/explicit_combined_worker.c
mv -f .deps/explicit_combined_worker.Tpo .deps/explicit_combined_worker.Po
parallel_tasks/explicit_combined_worker explicit_combined_worker.o
parallel_tasks/.libs/explicit_combined_worker explicit_combined_worker.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT parallel_kernels.o -MD
-MP -MF .deps/parallel_kernels.Tpo -c -o parallel_kernels.o `test -f
'parallel_tasks/parallel_kernels.c' || echo
'./'`parallel_tasks/parallel_kernels.c
mv -f .deps/parallel_kernels.Tpo .deps/parallel_kernels.Po
-l:/usr/local/cuda/lib64/libcublas.so -o parallel_tasks/parallel_kernels
parallel_kernels.o ../src/libstarpu.la -lrt -lpthread
parallel_tasks/.libs/parallel_kernels parallel_kernels.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT parallel_kernels_spmd.o
-MD -MP -MF .deps/parallel_kernels_spmd.Tpo -c -o parallel_kernels_spmd.o
`test -f 'parallel_tasks/parallel_kernels_spmd.c' || echo
'./'`parallel_tasks/parallel_kernels_spmd.c
mv -f .deps/parallel_kernels_spmd.Tpo .deps/parallel_kernels_spmd.Po
-l:/usr/local/cuda/lib64/libcublas.so -o parallel_tasks/parallel_kernels_spmd
parallel_kernels_spmd.o ../src/libstarpu.la -lrt -lpthread
parallel_tasks/.libs/parallel_kernels_spmd parallel_kernels_spmd.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT regression_based.o -MD
-MP -MF .deps/regression_based.Tpo -c -o regression_based.o `test -f
'perfmodels/regression_based.c' || echo './'`perfmodels/regression_based.c
mv -f .deps/regression_based.Tpo .deps/regression_based.Po
-l:/usr/local/cuda/lib64/libcublas.so -o perfmodels/regression_based
regression_based.o ../src/libstarpu.la -lrt -lpthread
perfmodels/.libs/regression_based regression_based.o
non_linear_regression_based.o -MD -MP -MF
.deps/non_linear_regression_based.Tpo -c -o non_linear_regression_based.o
`test -f 'perfmodels/non_linear_regression_based.c' || echo
'./'`perfmodels/non_linear_regression_based.c
mv -f .deps/non_linear_regression_based.Tpo
.deps/non_linear_regression_based.Po
perfmodels/non_linear_regression_based non_linear_regression_based.o
perfmodels/.libs/non_linear_regression_based non_linear_regression_based.o
make[3]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
Making all in doc
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/doc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/doc'
Making all in examples
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make all-recursive
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
Making all in stencil
`/home/deshpandea/moviSimStarPU/trunk/examples/stencil'
gcc -DHAVE_CONFIG_H -I. -I../../src/common -I../../include
-I../../gcc-plugin/src -I../../include/ -I../../examples/ -I../../include
-D_GNU_SOURCE -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT life.o -MD -MP -MF
.deps/life.Tpo -c -o life.o life.c
mv -f .deps/life.Tpo .deps/life.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-kernels.o -MD
-MP -MF .deps/stencil-kernels.Tpo -c -o stencil-kernels.o stencil-kernels.c
mv -f .deps/stencil-kernels.Tpo .deps/stencil-kernels.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-tasks.o -MD -MP
-MF .deps/stencil-tasks.Tpo -c -o stencil-tasks.o stencil-tasks.c
mv -f .deps/stencil-tasks.Tpo .deps/stencil-tasks.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-blocks.o -MD
-MP -MF .deps/stencil-blocks.Tpo -c -o stencil-blocks.o stencil-blocks.c
mv -f .deps/stencil-blocks.Tpo .deps/stencil-blocks.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil.o -MD -MP -MF
.deps/stencil.Tpo -c -o stencil.o stencil.c
mv -f .deps/stencil.Tpo .deps/stencil.Po
/bin/mkdir -p `dirname life_cuda.o`
/usr/local/cuda/bin/nvcc life_cuda.cu -c -o life_cuda.o --compiler-options
-fno-strict-aliasing -I/usr/local/cuda/include -m64 -I../../include/
-I../../include/
/bin/mkdir -p `dirname shadow.o`
/usr/local/cuda/bin/nvcc shadow.cu -c -o shadow.o --compiler-options
-I../../include/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT life_opencl.o -MD -MP
-MF .deps/life_opencl.Tpo -c -o life_opencl.o life_opencl.c
mv -f .deps/life_opencl.Tpo .deps/life_opencl.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT shadow_opencl.o -MD -MP
-MF .deps/shadow_opencl.Tpo -c -o shadow_opencl.o shadow_opencl.c
mv -f .deps/shadow_opencl.Tpo .deps/shadow_opencl.Po
/bin/bash ../../libtool --tag=CC --mode=link gcc
-l:/usr/local/cuda/lib64/libcublas.so -o stencil life.o stencil-kernels.o
stencil-tasks.o stencil-blocks.o stencil.o life_cuda.o shadow.o life_opencl.o
shadow_opencl.o ../../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/stencil life.o
stencil-kernels.o stencil-tasks.o stencil-blocks.o stencil.o life_cuda.o
shadow.o life_opencl.o shadow_opencl.o /usr/lib/libOpenCL.so.1.0.0
-l:/usr/local/cuda/lib64/libcublas.so ../../src/.libs/libstarpu.so -lrt
-lpthread
make[3]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
-I../include/ -I../examples/ -I../include -D_GNU_SOURCE -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT hello_world.o -MD -MP
-MF .deps/hello_world.Tpo -c -o hello_world.o `test -f
'basic_examples/hello_world.c' || echo './'`basic_examples/hello_world.c
mv -f .deps/hello_world.Tpo .deps/hello_world.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/hello_world
hello_world.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/hello_world hello_world.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal.o -MD -MP
-MF .deps/vector_scal.Tpo -c -o vector_scal.o `test -f
'basic_examples/vector_scal.c' || echo './'`basic_examples/vector_scal.c
mv -f .deps/vector_scal.Tpo .deps/vector_scal.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal_cpu.o -MD
-MP -MF .deps/vector_scal_cpu.Tpo -c -o vector_scal_cpu.o `test -f
'basic_examples/vector_scal_cpu.c' || echo
'./'`basic_examples/vector_scal_cpu.c
mv -f .deps/vector_scal_cpu.Tpo .deps/vector_scal_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/vector_scal_cuda.cu -c -o
basic_examples/vector_scal_cuda.o -I/usr/local/cuda/include -m64
--compiler-options -fno-strict-aliasing -I../include/ -I../include/
-I../examples/ -arch sm_13
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal_opencl.o
-MD -MP -MF .deps/vector_scal_opencl.Tpo -c -o vector_scal_opencl.o `test -f
'basic_examples/vector_scal_opencl.c' || echo
'./'`basic_examples/vector_scal_opencl.c
mv -f .deps/vector_scal_opencl.Tpo .deps/vector_scal_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/vector_scal
vector_scal.o vector_scal_cpu.o basic_examples/vector_scal_cuda.o
vector_scal_opencl.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/vector_scal vector_scal.o vector_scal_cpu.o
basic_examples/vector_scal_cuda.o vector_scal_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mult.o -MD -MP -MF
.deps/mult.Tpo -c -o mult.o `test -f 'basic_examples/mult.c' || echo
'./'`basic_examples/mult.c
mv -f .deps/mult.Tpo .deps/mult.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/mult mult.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o basic_examples/.libs/mult
mult.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block.o -MD -MP -MF
.deps/block.Tpo -c -o block.o `test -f 'basic_examples/block.c' || echo
'./'`basic_examples/block.c
mv -f .deps/block.Tpo .deps/block.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block_cpu.o -MD -MP -MF
.deps/block_cpu.Tpo -c -o block_cpu.o `test -f 'basic_examples/block_cpu.c'
|| echo './'`basic_examples/block_cpu.c
mv -f .deps/block_cpu.Tpo .deps/block_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/block_cuda.cu -c -o
basic_examples/block_cuda.o -I/usr/local/cuda/include -m64 --compiler-options
-fno-strict-aliasing -I../include/ -I../include/ -I../examples/ -arch sm_13
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block_opencl.o -MD -MP
-MF .deps/block_opencl.Tpo -c -o block_opencl.o `test -f
'basic_examples/block_opencl.c' || echo './'`basic_examples/block_opencl.c
mv -f .deps/block_opencl.Tpo .deps/block_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/block block.o
block_cpu.o basic_examples/block_cuda.o block_opencl.o ../src/libstarpu.la
basic_examples/.libs/block block.o block_cpu.o basic_examples/block_cuda.o
block_opencl.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT variable.o -MD -MP -MF
.deps/variable.Tpo -c -o variable.o `test -f 'basic_examples/variable.c' ||
echo './'`basic_examples/variable.c
mv -f .deps/variable.Tpo .deps/variable.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT variable_kernels_cpu.o
-MD -MP -MF .deps/variable_kernels_cpu.Tpo -c -o variable_kernels_cpu.o `test
-f 'basic_examples/variable_kernels_cpu.c' || echo
'./'`basic_examples/variable_kernels_cpu.c
mv -f .deps/variable_kernels_cpu.Tpo .deps/variable_kernels_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/variable_kernels.cu -c -o
basic_examples/variable_kernels.o -I/usr/local/cuda/include -m64
variable_kernels_opencl.o -MD -MP -MF .deps/variable_kernels_opencl.Tpo -c -o
variable_kernels_opencl.o `test -f 'basic_examples/variable_kernels_opencl.c'
|| echo './'`basic_examples/variable_kernels_opencl.c
mv -f .deps/variable_kernels_opencl.Tpo .deps/variable_kernels_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/variable variable.o
variable_kernels_cpu.o basic_examples/variable_kernels.o
variable_kernels_opencl.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/variable variable.o variable_kernels_cpu.o
basic_examples/variable_kernels.o variable_kernels_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mult_impl.o -MD -MP -MF
.deps/mult_impl.Tpo -c -o mult_impl.o `test -f 'basic_examples/mult_impl.c'
|| echo './'`basic_examples/mult_impl.c
mv -f .deps/mult_impl.Tpo .deps/mult_impl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/mult_impl mult_impl.o
basic_examples/.libs/mult_impl mult_impl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fvector.o -MD -MP -MF
.deps/fvector.Tpo -c -o fvector.o `test -f 'filters/fvector.c' || echo
'./'`filters/fvector.c
mv -f .deps/fvector.Tpo .deps/fvector.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fvector fvector.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fvector
fvector.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock.o -MD -MP -MF
.deps/fblock.Tpo -c -o fblock.o `test -f 'filters/fblock.c' || echo
'./'`filters/fblock.c
mv -f .deps/fblock.Tpo .deps/fblock.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock_cpu.o -MD -MP
-MF .deps/fblock_cpu.Tpo -c -o fblock_cpu.o `test -f 'filters/fblock_cpu.c'
|| echo './'`filters/fblock_cpu.c
mv -f .deps/fblock_cpu.Tpo .deps/fblock_cpu.Po
/usr/local/cuda/bin/nvcc filters/fblock_cuda.cu -c -o filters/fblock_cuda.o
-I/usr/local/cuda/include -m64 --compiler-options -fno-strict-aliasing
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock_opencl.o -MD -MP
-MF .deps/fblock_opencl.Tpo -c -o fblock_opencl.o `test -f
'filters/fblock_opencl.c' || echo './'`filters/fblock_opencl.c
mv -f .deps/fblock_opencl.Tpo .deps/fblock_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fblock fblock.o fblock_cpu.o
filters/fblock_cuda.o fblock_opencl.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fblock
fblock.o fblock_cpu.o filters/fblock_cuda.o fblock_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fmatrix.o -MD -MP -MF
.deps/fmatrix.Tpo -c -o fmatrix.o `test -f 'filters/fmatrix.c' || echo
'./'`filters/fmatrix.c
mv -f .deps/fmatrix.Tpo .deps/fmatrix.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fmatrix fmatrix.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fmatrix
fmatrix.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example.o -MD -MP
-MF .deps/tag_example.Tpo -c -o tag_example.o `test -f
'tag_example/tag_example.c' || echo './'`tag_example/tag_example.c
mv -f .deps/tag_example.Tpo .deps/tag_example.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example
tag_example.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example tag_example.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example3.o -MD -MP
-MF .deps/tag_example3.Tpo -c -o tag_example3.o `test -f
'tag_example/tag_example3.c' || echo './'`tag_example/tag_example3.c
mv -f .deps/tag_example3.Tpo .deps/tag_example3.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example3
tag_example3.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example3 tag_example3.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example2.o -MD -MP
-MF .deps/tag_example2.Tpo -c -o tag_example2.o `test -f
'tag_example/tag_example2.c' || echo './'`tag_example/tag_example2.c
mv -f .deps/tag_example2.Tpo .deps/tag_example2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example2
tag_example2.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example2 tag_example2.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_restartable.o -MD
-MP -MF .deps/tag_restartable.Tpo -c -o tag_restartable.o `test -f
'tag_example/tag_restartable.c' || echo './'`tag_example/tag_restartable.c
mv -f .deps/tag_restartable.Tpo .deps/tag_restartable.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_restartable
tag_restartable.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_restartable tag_restartable.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT spmv.o -MD -MP -MF
.deps/spmv.Tpo -c -o spmv.o `test -f 'spmv/spmv.c' || echo './'`spmv/spmv.c
mv -f .deps/spmv.Tpo .deps/spmv.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT spmv_kernels.o -MD -MP
-MF .deps/spmv_kernels.Tpo -c -o spmv_kernels.o `test -f
'spmv/spmv_kernels.c' || echo './'`spmv/spmv_kernels.c
mv -f .deps/spmv_kernels.Tpo .deps/spmv_kernels.Po
/usr/local/cuda/bin/nvcc spmv/spmv_cuda.cu -c -o spmv/spmv_cuda.o
-l:/usr/local/cuda/lib64/libcublas.so -o spmv/spmv spmv.o spmv_kernels.o
spmv/spmv_cuda.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o spmv/.libs/spmv spmv.o
spmv_kernels.o spmv/spmv_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT callback.o -MD -MP -MF
.deps/callback.Tpo -c -o callback.o `test -f 'callback/callback.c' || echo
'./'`callback/callback.c
mv -f .deps/callback.Tpo .deps/callback.Po
-l:/usr/local/cuda/lib64/libcublas.so -o callback/callback callback.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o callback/.libs/callback
callback.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT incrementer.o -MD -MP
-MF .deps/incrementer.Tpo -c -o incrementer.o `test -f
'incrementer/incrementer.c' || echo './'`incrementer/incrementer.c
mv -f .deps/incrementer.Tpo .deps/incrementer.Po
/usr/local/cuda/bin/nvcc incrementer/incrementer_kernels.cu -c -o
incrementer/incrementer_kernels.o -I/usr/local/cuda/include -m64
incrementer_kernels_opencl.o -MD -MP -MF .deps/incrementer_kernels_opencl.Tpo
-c -o incrementer_kernels_opencl.o `test -f
'incrementer/incrementer_kernels_opencl.c' || echo
'./'`incrementer/incrementer_kernels_opencl.c
mv -f .deps/incrementer_kernels_opencl.Tpo .deps/incrementer_kernels_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o incrementer/incrementer
incrementer.o incrementer/incrementer_kernels.o incrementer_kernels_opencl.o
incrementer/.libs/incrementer incrementer.o incrementer/incrementer_kernels.o
incrementer_kernels_opencl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT matvecmult.o -MD -MP
-MF .deps/matvecmult.Tpo -c -o matvecmult.o `test -f
'matvecmult/matvecmult.c' || echo './'`matvecmult/matvecmult.c
mv -f .deps/matvecmult.Tpo .deps/matvecmult.Po
-l:/usr/local/cuda/lib64/libcublas.so -o matvecmult/matvecmult matvecmult.o
matvecmult/.libs/matvecmult matvecmult.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT profiling.o -MD -MP -MF
.deps/profiling.Tpo -c -o profiling.o `test -f 'profiling/profiling.c' ||
echo './'`profiling/profiling.c
mv -f .deps/profiling.Tpo .deps/profiling.Po
-l:/usr/local/cuda/lib64/libcublas.so -o profiling/profiling profiling.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o profiling/.libs/profiling
profiling.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dummy_sched.o -MD -MP
-MF .deps/dummy_sched.Tpo -c -o dummy_sched.o `test -f
'scheduler/dummy_sched.c' || echo './'`scheduler/dummy_sched.c
mv -f .deps/dummy_sched.Tpo .deps/dummy_sched.Po
-l:/usr/local/cuda/lib64/libcublas.so -o scheduler/dummy_sched dummy_sched.o
scheduler/.libs/dummy_sched dummy_sched.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dot_product.o -MD -MP
-MF .deps/dot_product.Tpo -c -o dot_product.o `test -f
'reductions/dot_product.c' || echo './'`reductions/dot_product.c
mv -f .deps/dot_product.Tpo .deps/dot_product.Po
/usr/local/cuda/bin/nvcc reductions/dot_product_kernels.cu -c -o
reductions/dot_product_kernels.o -I/usr/local/cuda/include -m64
-l:/usr/local/cuda/lib64/libcublas.so -o reductions/dot_product dot_product.o
reductions/dot_product_kernels.o ../src/libstarpu.la -lrt -lpthread
reductions/.libs/dot_product dot_product.o reductions/dot_product_kernels.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT minmax_reduction.o -MD
-MP -MF .deps/minmax_reduction.Tpo -c -o minmax_reduction.o `test -f
'reductions/minmax_reduction.c' || echo './'`reductions/minmax_reduction.c
mv -f .deps/minmax_reduction.Tpo .deps/minmax_reduction.Po
-l:/usr/local/cuda/lib64/libcublas.so -o reductions/minmax_reduction
minmax_reduction.o ../src/libstarpu.la -lrt -lpthread
reductions/.libs/minmax_reduction minmax_reduction.o
-DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -I../include/
mandelbrot_mandelbrot-mandelbrot.o -MD -MP -MF
.deps/mandelbrot_mandelbrot-mandelbrot.Tpo -c -o
mandelbrot_mandelbrot-mandelbrot.o `test -f 'mandelbrot/mandelbrot.c' || echo
'./'`mandelbrot/mandelbrot.c
mv -f .deps/mandelbrot_mandelbrot-mandelbrot.Tpo
.deps/mandelbrot_mandelbrot-mandelbrot.Po
-L/home/deshpandea/moviSimStarPU/trunk/moviSim
-l:/usr/local/cuda/lib64/libcublas.so -o mandelbrot/mandelbrot
mandelbrot_mandelbrot-mandelbrot.o ../src/libstarpu.la -lrt -lpthread
mandelbrot/.libs/mandelbrot mandelbrot_mandelbrot-mandelbrot.o
-lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT ppm_downscaler.o -MD
-MP -MF .deps/ppm_downscaler.Tpo -c -o ppm_downscaler.o `test -f
'ppm_downscaler/ppm_downscaler.c' || echo './'`ppm_downscaler/ppm_downscaler.c
mv -f .deps/ppm_downscaler.Tpo .deps/ppm_downscaler.Po
-l:/usr/local/cuda/lib64/libcublas.so -o ppm_downscaler/ppm_downscaler
ppm_downscaler.o ../src/libstarpu.la -lrt -lpthread
ppm_downscaler/.libs/ppm_downscaler ppm_downscaler.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT yuv_downscaler.o -MD
-MP -MF .deps/yuv_downscaler.Tpo -c -o yuv_downscaler.o `test -f
'ppm_downscaler/yuv_downscaler.c' || echo './'`ppm_downscaler/yuv_downscaler.c
mv -f .deps/yuv_downscaler.Tpo .deps/yuv_downscaler.Po
-l:/usr/local/cuda/lib64/libcublas.so -o ppm_downscaler/yuv_downscaler
yuv_downscaler.o ../src/libstarpu.la -lrt -lpthread
ppm_downscaler/.libs/yuv_downscaler yuv_downscaler.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT main.o -MD -MP -MF
.deps/main.Tpo -c -o main.o `test -f 'basic_examples/main.c' || echo
'./'`basic_examples/main.c
basic_examples/main.c: In function ‘main’:
basic_examples/main.c:40: warning: implicit declaration of function
‘simInitLibrary’
basic_examples/main.c:77: warning: pointer targets in passing argument 2 of
‘read_png_file’ differ in signedness
basic_examples/pngutils.h:16: note: expected ‘unsigned int *’ but argument is
of type ‘int *’
basic_examples/main.c:77: warning: pointer targets in passing argument 3 of
of type ‘int *’
basic_examples/main.c:77: warning: pointer targets in passing argument 4 of
of type ‘int *’
basic_examples/main.c:77: warning: pointer targets in passing argument 5 of
of type ‘int *’
basic_examples/main.c:105: warning: implicit declaration of function
‘closeThreads’
basic_examples/main.c:106: warning: control reaches end of non-void function
mv -f .deps/main.Tpo .deps/main.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT pngutils.o -MD -MP -MF
.deps/pngutils.Tpo -c -o pngutils.o `test -f 'basic_examples/pngutils.c' ||
echo './'`basic_examples/pngutils.c
basic_examples/pngutils.c: In function ‘write_png_file_norm’:
basic_examples/pngutils.c:292: warning: suggest parentheses around arithmetic
in operand of ‘^’
mv -f .deps/pngutils.Tpo .deps/pngutils.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT refocusing_cpu.o -MD
-MP -MF .deps/refocusing_cpu.Tpo -c -o refocusing_cpu.o `test -f
'basic_examples/refocusing_cpu.c' || echo './'`basic_examples/refocusing_cpu.c
mv -f .deps/refocusing_cpu.Tpo .deps/refocusing_cpu.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT refocusing_starpu.o -MD
-MP -MF .deps/refocusing_starpu.Tpo -c -o refocusing_starpu.o `test -f
'basic_examples/refocusing_starpu.c' || echo
'./'`basic_examples/refocusing_starpu.c
basic_examples/refocusing_starpu.c: In function ‘refocusing_opencl_codelet’:
basic_examples/refocusing_starpu.c:116: warning: passing argument 2 of
‘starpu_opencl_get_queue’ from incompatible pointer type
../include/starpu_opencl.h:55: note: expected ‘struct _cl_command_queue **’
but argument is of type ‘cl_command_queue’
basic_examples/refocusing_starpu.c:118: warning: format ‘%X’ expects type
‘unsigned int’, but argument 2 has type ‘cl_context’
basic_examples/refocusing_starpu.c:87: warning: unused variable ‘platform’
basic_examples/refocusing_starpu.c: In function ‘refocusing_starpu’:
basic_examples/refocusing_starpu.c:218: warning: unused variable ‘err’
mv -f .deps/refocusing_starpu.Tpo .deps/refocusing_starpu.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/refocusing main.o
pngutils.o refocusing_cpu.o refocusing_starpu.o ../src/libstarpu.la -lrt
basic_examples/.libs/refocusing main.o pngutils.o refocusing_cpu.o
refocusing_starpu.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64
main.o: In function `main':
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/main.c:40:
undefined reference to `simInitLibrary'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/main.c:105:
undefined reference to `closeThreads'
pngutils.o: In function `read_png_file':
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:57:
undefined reference to `png_sig_cmp'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:63:
undefined reference to `png_create_read_struct'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:69:
undefined reference to `png_create_info_struct'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:72:
undefined reference to `png_destroy_read_struct'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:77:
undefined reference to `png_init_io'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:78:
undefined reference to `png_set_sig_bytes'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:79:
undefined reference to `png_read_info'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:81:
undefined reference to `png_get_image_width'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:82:
undefined reference to `png_get_image_height'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:85:
undefined reference to `png_get_channels'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:86:
undefined reference to `png_get_bit_depth'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:93:
undefined reference to `png_get_color_type'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:95:
undefined reference to `png_read_update_info'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:97:
undefined reference to `png_get_rowbytes'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:129:
undefined reference to `png_set_filter'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:131:
undefined reference to `png_read_rows'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:154:
pngutils.o: In function `write_png_file':
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:189:
undefined reference to `png_create_write_struct'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:195:
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:201:
undefined reference to `png_set_longjmp_fn'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:206:
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:208:
undefined reference to `png_set_IHDR'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:213:
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:218:
undefined reference to `png_set_compression_level'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:222:
undefined reference to `png_write_info'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:225:
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:227:
undefined reference to `png_destroy_write_struct'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:231:
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:255:
undefined reference to `png_save_uint_16'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:271:
undefined reference to `png_write_rows'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:272:
undefined reference to `png_write_end'
/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/pngutils.c:274:
collect2: ld returned 1 exit status
make[3]: *** [basic_examples/refocusing] Error 1
make[3]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make: *** [all-recursive] Error 1
config.log
Description: Binary data
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/src'
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/src'
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I.
-I../src/common -I../include -I../gcc-plugin/src -I../include/ -D_GNU_SOURCE
-W -Wall -Wextra -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/lpng155/
-I/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-barrier.lo
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c -o libstarpu_la-barrier.lo
`test -f 'common/barrier.c' || echo './'`common/barrier.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include
-I../gcc-plugin/src -I../include/ -D_GNU_SOURCE -W -Wall -Wextra
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c common/barrier.c -fPIC -DPIC
-o .libs/libstarpu_la-barrier.o
-MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c common/barrier.c -o
libstarpu_la-barrier.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-barrier.Tpo .deps/libstarpu_la-barrier.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-hash.lo
-MD -MP -MF .deps/libstarpu_la-hash.Tpo -c -o libstarpu_la-hash.lo `test -f
'common/hash.c' || echo './'`common/hash.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-hash.lo -MD
-MP -MF .deps/libstarpu_la-hash.Tpo -c common/hash.c -fPIC -DPIC -o
.libs/libstarpu_la-hash.o
-MP -MF .deps/libstarpu_la-hash.Tpo -c common/hash.c -o libstarpu_la-hash.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-hash.Tpo .deps/libstarpu_la-hash.Plo
libstarpu_la-htable32.lo -MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c -o
libstarpu_la-htable32.lo `test -f 'common/htable32.c' || echo
'./'`common/htable32.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-htable32.lo
-MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c common/htable32.c -fPIC -DPIC
-o .libs/libstarpu_la-htable32.o
-MD -MP -MF .deps/libstarpu_la-htable32.Tpo -c common/htable32.c -o
libstarpu_la-htable32.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable32.Tpo .deps/libstarpu_la-htable32.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-rwlock.lo
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c -o libstarpu_la-rwlock.lo `test
-f 'common/rwlock.c' || echo './'`common/rwlock.c
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c common/rwlock.c -fPIC -DPIC -o
.libs/libstarpu_la-rwlock.o
-MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c common/rwlock.c -o
libstarpu_la-rwlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-rwlock.Tpo .deps/libstarpu_la-rwlock.Plo
libstarpu_la-starpu_spinlock.lo -MD -MP -MF
.deps/libstarpu_la-starpu_spinlock.Tpo -c -o libstarpu_la-starpu_spinlock.lo
`test -f 'common/starpu_spinlock.c' || echo './'`common/starpu_spinlock.c
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_spinlock.o
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -o
libstarpu_la-starpu_spinlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_spinlock.Tpo
.deps/libstarpu_la-starpu_spinlock.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-timing.lo
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c -o libstarpu_la-timing.lo `test
-f 'common/timing.c' || echo './'`common/timing.c
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c common/timing.c -fPIC -DPIC -o
.libs/libstarpu_la-timing.o
-MD -MP -MF .deps/libstarpu_la-timing.Tpo -c common/timing.c -o
libstarpu_la-timing.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-timing.Tpo .deps/libstarpu_la-timing.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-fxt.lo -MD
-MP -MF .deps/libstarpu_la-fxt.Tpo -c -o libstarpu_la-fxt.lo `test -f
'common/fxt.c' || echo './'`common/fxt.c
-MP -MF .deps/libstarpu_la-fxt.Tpo -c common/fxt.c -fPIC -DPIC -o
.libs/libstarpu_la-fxt.o
-MP -MF .deps/libstarpu_la-fxt.Tpo -c common/fxt.c -o libstarpu_la-fxt.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-fxt.Tpo .deps/libstarpu_la-fxt.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-utils.lo
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c -o libstarpu_la-utils.lo `test -f
'common/utils.c' || echo './'`common/utils.c
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c common/utils.c -fPIC -DPIC -o
.libs/libstarpu_la-utils.o
-MD -MP -MF .deps/libstarpu_la-utils.Tpo -c common/utils.c -o
libstarpu_la-utils.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-utils.Tpo .deps/libstarpu_la-utils.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-jobs.lo
-MD -MP -MF .deps/libstarpu_la-jobs.Tpo -c -o libstarpu_la-jobs.lo `test -f
'core/jobs.c' || echo './'`core/jobs.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-jobs.lo -MD
-MP -MF .deps/libstarpu_la-jobs.Tpo -c core/jobs.c -fPIC -DPIC -o
.libs/libstarpu_la-jobs.o
-MP -MF .deps/libstarpu_la-jobs.Tpo -c core/jobs.c -o libstarpu_la-jobs.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-jobs.Tpo .deps/libstarpu_la-jobs.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-task.lo
-MD -MP -MF .deps/libstarpu_la-task.Tpo -c -o libstarpu_la-task.lo `test -f
'core/task.c' || echo './'`core/task.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-task.lo -MD
-MP -MF .deps/libstarpu_la-task.Tpo -c core/task.c -fPIC -DPIC -o
.libs/libstarpu_la-task.o
-MP -MF .deps/libstarpu_la-task.Tpo -c core/task.c -o libstarpu_la-task.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-task.Tpo .deps/libstarpu_la-task.Plo
libstarpu_la-task_bundle.lo -MD -MP -MF .deps/libstarpu_la-task_bundle.Tpo -c
-o libstarpu_la-task_bundle.lo `test -f 'core/task_bundle.c' || echo
'./'`core/task_bundle.c
core/task_bundle.c -fPIC -DPIC -o .libs/libstarpu_la-task_bundle.o
core/task_bundle.c -o libstarpu_la-task_bundle.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_bundle.Tpo .deps/libstarpu_la-task_bundle.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-workers.lo
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c -o libstarpu_la-workers.lo
`test -f 'core/workers.c' || echo './'`core/workers.c
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c core/workers.c -fPIC -DPIC -o
.libs/libstarpu_la-workers.o
-MD -MP -MF .deps/libstarpu_la-workers.Tpo -c core/workers.c -o
libstarpu_la-workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-workers.Tpo .deps/libstarpu_la-workers.Plo
libstarpu_la-combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-combined_workers.Tpo -c -o
libstarpu_la-combined_workers.lo `test -f 'core/combined_workers.c' || echo
'./'`core/combined_workers.c
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -fPIC
-DPIC -o .libs/libstarpu_la-combined_workers.o
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -o
libstarpu_la-combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-combined_workers.Tpo
.deps/libstarpu_la-combined_workers.Plo
libstarpu_la-topology.lo -MD -MP -MF .deps/libstarpu_la-topology.Tpo -c -o
libstarpu_la-topology.lo `test -f 'core/topology.c' || echo
'./'`core/topology.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-topology.lo
-MD -MP -MF .deps/libstarpu_la-topology.Tpo -c core/topology.c -fPIC -DPIC
-o .libs/libstarpu_la-topology.o
-MD -MP -MF .deps/libstarpu_la-topology.Tpo -c core/topology.c -o
libstarpu_la-topology.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-topology.Tpo .deps/libstarpu_la-topology.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-debug.lo
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c -o libstarpu_la-debug.lo `test -f
'core/debug.c' || echo './'`core/debug.c
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c core/debug.c -fPIC -DPIC -o
.libs/libstarpu_la-debug.o
-MD -MP -MF .deps/libstarpu_la-debug.Tpo -c core/debug.c -o
libstarpu_la-debug.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-debug.Tpo .deps/libstarpu_la-debug.Plo
libstarpu_la-errorcheck.lo -MD -MP -MF .deps/libstarpu_la-errorcheck.Tpo -c
-o libstarpu_la-errorcheck.lo `test -f 'core/errorcheck.c' || echo
'./'`core/errorcheck.c
core/errorcheck.c -fPIC -DPIC -o .libs/libstarpu_la-errorcheck.o
core/errorcheck.c -o libstarpu_la-errorcheck.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-errorcheck.Tpo .deps/libstarpu_la-errorcheck.Plo
libstarpu_la-progress_hook.lo -MD -MP -MF
.deps/libstarpu_la-progress_hook.Tpo -c -o libstarpu_la-progress_hook.lo
`test -f 'core/progress_hook.c' || echo './'`core/progress_hook.c
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -fPIC -DPIC -o
.libs/libstarpu_la-progress_hook.o
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -o
libstarpu_la-progress_hook.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress_hook.Tpo
.deps/libstarpu_la-progress_hook.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-cg.lo -MD
-MP -MF .deps/libstarpu_la-cg.Tpo -c -o libstarpu_la-cg.lo `test -f
'core/dependencies/cg.c' || echo './'`core/dependencies/cg.c
-MP -MF .deps/libstarpu_la-cg.Tpo -c core/dependencies/cg.c -fPIC -DPIC -o
.libs/libstarpu_la-cg.o
-MP -MF .deps/libstarpu_la-cg.Tpo -c core/dependencies/cg.c -o
libstarpu_la-cg.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-cg.Tpo .deps/libstarpu_la-cg.Plo
libstarpu_la-dependencies.lo -MD -MP -MF .deps/libstarpu_la-dependencies.Tpo
-c -o libstarpu_la-dependencies.lo `test -f
'core/dependencies/dependencies.c' || echo
'./'`core/dependencies/dependencies.c
-c core/dependencies/dependencies.c -fPIC -DPIC -o
.libs/libstarpu_la-dependencies.o
-c core/dependencies/dependencies.c -o libstarpu_la-dependencies.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-dependencies.Tpo .deps/libstarpu_la-dependencies.Plo
libstarpu_la-implicit_data_deps.lo -MD -MP -MF
.deps/libstarpu_la-implicit_data_deps.Tpo -c -o
libstarpu_la-implicit_data_deps.lo `test -f
'core/dependencies/implicit_data_deps.c' || echo
'./'`core/dependencies/implicit_data_deps.c
core/dependencies/implicit_data_deps.c -fPIC -DPIC -o
.libs/libstarpu_la-implicit_data_deps.o
core/dependencies/implicit_data_deps.c -o libstarpu_la-implicit_data_deps.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-implicit_data_deps.Tpo
.deps/libstarpu_la-implicit_data_deps.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-tags.lo
-MD -MP -MF .deps/libstarpu_la-tags.Tpo -c -o libstarpu_la-tags.lo `test -f
'core/dependencies/tags.c' || echo './'`core/dependencies/tags.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-tags.lo -MD
-MP -MF .deps/libstarpu_la-tags.Tpo -c core/dependencies/tags.c -fPIC -DPIC
-o .libs/libstarpu_la-tags.o
-MP -MF .deps/libstarpu_la-tags.Tpo -c core/dependencies/tags.c -o
libstarpu_la-tags.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-tags.Tpo .deps/libstarpu_la-tags.Plo
libstarpu_la-task_deps.lo -MD -MP -MF .deps/libstarpu_la-task_deps.Tpo -c -o
libstarpu_la-task_deps.lo `test -f 'core/dependencies/task_deps.c' || echo
'./'`core/dependencies/task_deps.c
core/dependencies/task_deps.c -fPIC -DPIC -o .libs/libstarpu_la-task_deps.o
core/dependencies/task_deps.c -o libstarpu_la-task_deps.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_deps.Tpo .deps/libstarpu_la-task_deps.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-htable.lo
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c -o libstarpu_la-htable.lo `test
-f 'core/dependencies/htable.c' || echo './'`core/dependencies/htable.c
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c core/dependencies/htable.c
-fPIC -DPIC -o .libs/libstarpu_la-htable.o
-MD -MP -MF .deps/libstarpu_la-htable.Tpo -c core/dependencies/htable.c -o
libstarpu_la-htable.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable.Tpo .deps/libstarpu_la-htable.Plo
libstarpu_la-data_concurrency.lo -MD -MP -MF
.deps/libstarpu_la-data_concurrency.Tpo -c -o
libstarpu_la-data_concurrency.lo `test -f
'core/dependencies/data_concurrency.c' || echo
'./'`core/dependencies/data_concurrency.c
core/dependencies/data_concurrency.c -fPIC -DPIC -o
.libs/libstarpu_la-data_concurrency.o
core/dependencies/data_concurrency.c -o libstarpu_la-data_concurrency.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_concurrency.Tpo
.deps/libstarpu_la-data_concurrency.Plo
libstarpu_la-perfmodel_history.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_history.Tpo -c -o
libstarpu_la-perfmodel_history.lo `test -f
'core/perfmodel/perfmodel_history.c' || echo
'./'`core/perfmodel/perfmodel_history.c
core/perfmodel/perfmodel_history.c -fPIC -DPIC -o
.libs/libstarpu_la-perfmodel_history.o
core/perfmodel/perfmodel_history.c -o libstarpu_la-perfmodel_history.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_history.Tpo
.deps/libstarpu_la-perfmodel_history.Plo
libstarpu_la-perfmodel_bus.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_bus.Tpo -c -o libstarpu_la-perfmodel_bus.lo
`test -f 'core/perfmodel/perfmodel_bus.c' || echo
'./'`core/perfmodel/perfmodel_bus.c
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -fPIC
-DPIC -o .libs/libstarpu_la-perfmodel_bus.o
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -o
libstarpu_la-perfmodel_bus.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_bus.Tpo
.deps/libstarpu_la-perfmodel_bus.Plo
libstarpu_la-perfmodel.lo -MD -MP -MF .deps/libstarpu_la-perfmodel.Tpo -c -o
libstarpu_la-perfmodel.lo `test -f 'core/perfmodel/perfmodel.c' || echo
'./'`core/perfmodel/perfmodel.c
core/perfmodel/perfmodel.c -fPIC -DPIC -o .libs/libstarpu_la-perfmodel.o
core/perfmodel/perfmodel.c -o libstarpu_la-perfmodel.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel.Tpo .deps/libstarpu_la-perfmodel.Plo
libstarpu_la-regression.lo -MD -MP -MF .deps/libstarpu_la-regression.Tpo -c
-o libstarpu_la-regression.lo `test -f 'core/perfmodel/regression.c' || echo
'./'`core/perfmodel/regression.c
core/perfmodel/regression.c -fPIC -DPIC -o .libs/libstarpu_la-regression.o
core/perfmodel/regression.c -o libstarpu_la-regression.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-regression.Tpo .deps/libstarpu_la-regression.Plo
libstarpu_la-sched_policy.lo -MD -MP -MF .deps/libstarpu_la-sched_policy.Tpo
-c -o libstarpu_la-sched_policy.lo `test -f 'core/sched_policy.c' || echo
'./'`core/sched_policy.c
-c core/sched_policy.c -fPIC -DPIC -o .libs/libstarpu_la-sched_policy.o
-c core/sched_policy.c -o libstarpu_la-sched_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sched_policy.Tpo .deps/libstarpu_la-sched_policy.Plo
libstarpu_la-priorities.lo -MD -MP -MF .deps/libstarpu_la-priorities.Tpo -c
-o libstarpu_la-priorities.lo `test -f 'core/priorities.c' || echo
'./'`core/priorities.c
core/priorities.c -fPIC -DPIC -o .libs/libstarpu_la-priorities.o
core/priorities.c -o libstarpu_la-priorities.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-priorities.Tpo .deps/libstarpu_la-priorities.Plo
libstarpu_la-parallel_task.lo -MD -MP -MF
.deps/libstarpu_la-parallel_task.Tpo -c -o libstarpu_la-parallel_task.lo
`test -f 'core/parallel_task.c' || echo './'`core/parallel_task.c
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -fPIC -DPIC -o
.libs/libstarpu_la-parallel_task.o
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -o
libstarpu_la-parallel_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_task.Tpo
.deps/libstarpu_la-parallel_task.Plo
libstarpu_la-eager_central_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_policy.Tpo -c -o
libstarpu_la-eager_central_policy.lo `test -f
'sched_policies/eager_central_policy.c' || echo
'./'`sched_policies/eager_central_policy.c
sched_policies/eager_central_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_policy.o
sched_policies/eager_central_policy.c -o libstarpu_la-eager_central_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_policy.Tpo
.deps/libstarpu_la-eager_central_policy.Plo
libstarpu_la-eager_central_priority_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_priority_policy.Tpo -c -o
libstarpu_la-eager_central_priority_policy.lo `test -f
'sched_policies/eager_central_priority_policy.c' || echo
'./'`sched_policies/eager_central_priority_policy.c
sched_policies/eager_central_priority_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_priority_policy.o
sched_policies/eager_central_priority_policy.c -o
libstarpu_la-eager_central_priority_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_priority_policy.Tpo
.deps/libstarpu_la-eager_central_priority_policy.Plo
libstarpu_la-work_stealing_policy.lo -MD -MP -MF
.deps/libstarpu_la-work_stealing_policy.Tpo -c -o
libstarpu_la-work_stealing_policy.lo `test -f
'sched_policies/work_stealing_policy.c' || echo
'./'`sched_policies/work_stealing_policy.c
sched_policies/work_stealing_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-work_stealing_policy.o
sched_policies/work_stealing_policy.c -o libstarpu_la-work_stealing_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-work_stealing_policy.Tpo
.deps/libstarpu_la-work_stealing_policy.Plo
libstarpu_la-deque_modeling_policy_data_aware.lo -MD -MP -MF
.deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo -c -o
libstarpu_la-deque_modeling_policy_data_aware.lo `test -f
'sched_policies/deque_modeling_policy_data_aware.c' || echo
'./'`sched_policies/deque_modeling_policy_data_aware.c
sched_policies/deque_modeling_policy_data_aware.c -fPIC -DPIC -o
.libs/libstarpu_la-deque_modeling_policy_data_aware.o
sched_policies/deque_modeling_policy_data_aware.c -o
libstarpu_la-deque_modeling_policy_data_aware.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo
.deps/libstarpu_la-deque_modeling_policy_data_aware.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-heft.lo
-MD -MP -MF .deps/libstarpu_la-heft.Tpo -c -o libstarpu_la-heft.lo `test -f
'sched_policies/heft.c' || echo './'`sched_policies/heft.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-heft.lo -MD
-MP -MF .deps/libstarpu_la-heft.Tpo -c sched_policies/heft.c -fPIC -DPIC -o
.libs/libstarpu_la-heft.o
-MP -MF .deps/libstarpu_la-heft.Tpo -c sched_policies/heft.c -o
libstarpu_la-heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-heft.Tpo .deps/libstarpu_la-heft.Plo
libstarpu_la-random_policy.lo -MD -MP -MF
.deps/libstarpu_la-random_policy.Tpo -c -o libstarpu_la-random_policy.lo
`test -f 'sched_policies/random_policy.c' || echo
'./'`sched_policies/random_policy.c
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -fPIC
-DPIC -o .libs/libstarpu_la-random_policy.o
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -o
libstarpu_la-random_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-random_policy.Tpo
.deps/libstarpu_la-random_policy.Plo
libstarpu_la-stack_queues.lo -MD -MP -MF .deps/libstarpu_la-stack_queues.Tpo
-c -o libstarpu_la-stack_queues.lo `test -f 'sched_policies/stack_queues.c'
|| echo './'`sched_policies/stack_queues.c
-c sched_policies/stack_queues.c -fPIC -DPIC -o
.libs/libstarpu_la-stack_queues.o
-c sched_policies/stack_queues.c -o libstarpu_la-stack_queues.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-stack_queues.Tpo .deps/libstarpu_la-stack_queues.Plo
libstarpu_la-deque_queues.lo -MD -MP -MF .deps/libstarpu_la-deque_queues.Tpo
-c -o libstarpu_la-deque_queues.lo `test -f 'sched_policies/deque_queues.c'
|| echo './'`sched_policies/deque_queues.c
-c sched_policies/deque_queues.c -fPIC -DPIC -o
.libs/libstarpu_la-deque_queues.o
-c sched_policies/deque_queues.c -o libstarpu_la-deque_queues.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-deque_queues.Tpo .deps/libstarpu_la-deque_queues.Plo
libstarpu_la-fifo_queues.lo -MD -MP -MF .deps/libstarpu_la-fifo_queues.Tpo -c
-o libstarpu_la-fifo_queues.lo `test -f 'sched_policies/fifo_queues.c' ||
echo './'`sched_policies/fifo_queues.c
sched_policies/fifo_queues.c -fPIC -DPIC -o .libs/libstarpu_la-fifo_queues.o
sched_policies/fifo_queues.c -o libstarpu_la-fifo_queues.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-fifo_queues.Tpo .deps/libstarpu_la-fifo_queues.Plo
libstarpu_la-detect_combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-detect_combined_workers.Tpo -c -o
libstarpu_la-detect_combined_workers.lo `test -f
'sched_policies/detect_combined_workers.c' || echo
'./'`sched_policies/detect_combined_workers.c
sched_policies/detect_combined_workers.c -fPIC -DPIC -o
.libs/libstarpu_la-detect_combined_workers.o
sched_policies/detect_combined_workers.c -o
libstarpu_la-detect_combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-detect_combined_workers.Tpo
.deps/libstarpu_la-detect_combined_workers.Plo
libstarpu_la-parallel_heft.lo -MD -MP -MF
.deps/libstarpu_la-parallel_heft.Tpo -c -o libstarpu_la-parallel_heft.lo
`test -f 'sched_policies/parallel_heft.c' || echo
'./'`sched_policies/parallel_heft.c
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -fPIC
-DPIC -o .libs/libstarpu_la-parallel_heft.o
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -o
libstarpu_la-parallel_heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_heft.Tpo
.deps/libstarpu_la-parallel_heft.Plo
libstarpu_la-parallel_greedy.lo -MD -MP -MF
.deps/libstarpu_la-parallel_greedy.Tpo -c -o libstarpu_la-parallel_greedy.lo
`test -f 'sched_policies/parallel_greedy.c' || echo
'./'`sched_policies/parallel_greedy.c
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c
-fPIC -DPIC -o .libs/libstarpu_la-parallel_greedy.o
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c -o
libstarpu_la-parallel_greedy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_greedy.Tpo
.deps/libstarpu_la-parallel_greedy.Plo
libstarpu_la-driver_common.lo -MD -MP -MF
.deps/libstarpu_la-driver_common.Tpo -c -o libstarpu_la-driver_common.lo
`test -f 'drivers/driver_common/driver_common.c' || echo
'./'`drivers/driver_common/driver_common.c
.deps/libstarpu_la-driver_common.Tpo -c drivers/driver_common/driver_common.c
-fPIC -DPIC -o .libs/libstarpu_la-driver_common.o
-o libstarpu_la-driver_common.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_common.Tpo
.deps/libstarpu_la-driver_common.Plo
libstarpu_la-memory_nodes.lo -MD -MP -MF .deps/libstarpu_la-memory_nodes.Tpo
-c -o libstarpu_la-memory_nodes.lo `test -f 'datawizard/memory_nodes.c' ||
echo './'`datawizard/memory_nodes.c
-c datawizard/memory_nodes.c -fPIC -DPIC -o .libs/libstarpu_la-memory_nodes.o
-c datawizard/memory_nodes.c -o libstarpu_la-memory_nodes.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memory_nodes.Tpo .deps/libstarpu_la-memory_nodes.Plo
libstarpu_la-write_back.lo -MD -MP -MF .deps/libstarpu_la-write_back.Tpo -c
-o libstarpu_la-write_back.lo `test -f 'datawizard/write_back.c' || echo
'./'`datawizard/write_back.c
datawizard/write_back.c -fPIC -DPIC -o .libs/libstarpu_la-write_back.o
datawizard/write_back.c -o libstarpu_la-write_back.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-write_back.Tpo .deps/libstarpu_la-write_back.Plo
libstarpu_la-coherency.lo -MD -MP -MF .deps/libstarpu_la-coherency.Tpo -c -o
libstarpu_la-coherency.lo `test -f 'datawizard/coherency.c' || echo
'./'`datawizard/coherency.c
datawizard/coherency.c -fPIC -DPIC -o .libs/libstarpu_la-coherency.o
datawizard/coherency.c -o libstarpu_la-coherency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-coherency.Tpo .deps/libstarpu_la-coherency.Plo
libstarpu_la-data_request.lo -MD -MP -MF .deps/libstarpu_la-data_request.Tpo
-c -o libstarpu_la-data_request.lo `test -f 'datawizard/data_request.c' ||
echo './'`datawizard/data_request.c
-c datawizard/data_request.c -fPIC -DPIC -o .libs/libstarpu_la-data_request.o
-c datawizard/data_request.c -o libstarpu_la-data_request.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-data_request.Tpo .deps/libstarpu_la-data_request.Plo
libstarpu_la-progress.lo -MD -MP -MF .deps/libstarpu_la-progress.Tpo -c -o
libstarpu_la-progress.lo `test -f 'datawizard/progress.c' || echo
'./'`datawizard/progress.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-progress.lo
-MD -MP -MF .deps/libstarpu_la-progress.Tpo -c datawizard/progress.c -fPIC
-DPIC -o .libs/libstarpu_la-progress.o
-MD -MP -MF .deps/libstarpu_la-progress.Tpo -c datawizard/progress.c -o
libstarpu_la-progress.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress.Tpo .deps/libstarpu_la-progress.Plo
libstarpu_la-copy_driver.lo -MD -MP -MF .deps/libstarpu_la-copy_driver.Tpo -c
-o libstarpu_la-copy_driver.lo `test -f 'datawizard/copy_driver.c' || echo
'./'`datawizard/copy_driver.c
datawizard/copy_driver.c -fPIC -DPIC -o .libs/libstarpu_la-copy_driver.o
datawizard/copy_driver.c -o libstarpu_la-copy_driver.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-copy_driver.Tpo .deps/libstarpu_la-copy_driver.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-filters.lo
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c -o libstarpu_la-filters.lo
`test -f 'datawizard/filters.c' || echo './'`datawizard/filters.c
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c datawizard/filters.c -fPIC
-DPIC -o .libs/libstarpu_la-filters.o
-MD -MP -MF .deps/libstarpu_la-filters.Tpo -c datawizard/filters.c -o
libstarpu_la-filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-filters.Tpo .deps/libstarpu_la-filters.Plo
libstarpu_la-sort_data_handles.lo -MD -MP -MF
.deps/libstarpu_la-sort_data_handles.Tpo -c -o
libstarpu_la-sort_data_handles.lo `test -f 'datawizard/sort_data_handles.c'
|| echo './'`datawizard/sort_data_handles.c
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c
-fPIC -DPIC -o .libs/libstarpu_la-sort_data_handles.o
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c -o
libstarpu_la-sort_data_handles.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sort_data_handles.Tpo
.deps/libstarpu_la-sort_data_handles.Plo
libstarpu_la-memalloc.lo -MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c -o
libstarpu_la-memalloc.lo `test -f 'datawizard/memalloc.c' || echo
'./'`datawizard/memalloc.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-memalloc.lo
-MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c datawizard/memalloc.c -fPIC
-DPIC -o .libs/libstarpu_la-memalloc.o
-MD -MP -MF .deps/libstarpu_la-memalloc.Tpo -c datawizard/memalloc.c -o
libstarpu_la-memalloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memalloc.Tpo .deps/libstarpu_la-memalloc.Plo
libstarpu_la-footprint.lo -MD -MP -MF .deps/libstarpu_la-footprint.Tpo -c -o
libstarpu_la-footprint.lo `test -f 'datawizard/footprint.c' || echo
'./'`datawizard/footprint.c
datawizard/footprint.c -fPIC -DPIC -o .libs/libstarpu_la-footprint.o
datawizard/footprint.c -o libstarpu_la-footprint.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-footprint.Tpo .deps/libstarpu_la-footprint.Plo
libstarpu_la-datastats.lo -MD -MP -MF .deps/libstarpu_la-datastats.Tpo -c -o
libstarpu_la-datastats.lo `test -f 'datawizard/datastats.c' || echo
'./'`datawizard/datastats.c
datawizard/datastats.c -fPIC -DPIC -o .libs/libstarpu_la-datastats.o
datawizard/datastats.c -o libstarpu_la-datastats.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-datastats.Tpo .deps/libstarpu_la-datastats.Plo
libstarpu_la-user_interactions.lo -MD -MP -MF
.deps/libstarpu_la-user_interactions.Tpo -c -o
libstarpu_la-user_interactions.lo `test -f 'datawizard/user_interactions.c'
|| echo './'`datawizard/user_interactions.c
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c
-fPIC -DPIC -o .libs/libstarpu_la-user_interactions.o
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c -o
libstarpu_la-user_interactions.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-user_interactions.Tpo
.deps/libstarpu_la-user_interactions.Plo
libstarpu_la-reduction.lo -MD -MP -MF .deps/libstarpu_la-reduction.Tpo -c -o
libstarpu_la-reduction.lo `test -f 'datawizard/reduction.c' || echo
'./'`datawizard/reduction.c
datawizard/reduction.c -fPIC -DPIC -o .libs/libstarpu_la-reduction.o
datawizard/reduction.c -o libstarpu_la-reduction.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-reduction.Tpo .deps/libstarpu_la-reduction.Plo
libstarpu_la-data_interface.lo -MD -MP -MF
.deps/libstarpu_la-data_interface.Tpo -c -o libstarpu_la-data_interface.lo
`test -f 'datawizard/interfaces/data_interface.c' || echo
'./'`datawizard/interfaces/data_interface.c
datawizard/interfaces/data_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-data_interface.o
datawizard/interfaces/data_interface.c -o libstarpu_la-data_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_interface.Tpo
.deps/libstarpu_la-data_interface.Plo
libstarpu_la-bcsr_interface.lo -MD -MP -MF
.deps/libstarpu_la-bcsr_interface.Tpo -c -o libstarpu_la-bcsr_interface.lo
`test -f 'datawizard/interfaces/bcsr_interface.c' || echo
'./'`datawizard/interfaces/bcsr_interface.c
datawizard/interfaces/bcsr_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-bcsr_interface.o
datawizard/interfaces/bcsr_interface.c -o libstarpu_la-bcsr_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_interface.Tpo
.deps/libstarpu_la-bcsr_interface.Plo
libstarpu_la-csr_interface.lo -MD -MP -MF
.deps/libstarpu_la-csr_interface.Tpo -c -o libstarpu_la-csr_interface.lo
`test -f 'datawizard/interfaces/csr_interface.c' || echo
'./'`datawizard/interfaces/csr_interface.c
.deps/libstarpu_la-csr_interface.Tpo -c datawizard/interfaces/csr_interface.c
-fPIC -DPIC -o .libs/libstarpu_la-csr_interface.o
-o libstarpu_la-csr_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-csr_interface.Tpo
.deps/libstarpu_la-csr_interface.Plo
libstarpu_la-matrix_filters.lo -MD -MP -MF
.deps/libstarpu_la-matrix_filters.Tpo -c -o libstarpu_la-matrix_filters.lo
`test -f 'datawizard/interfaces/matrix_filters.c' || echo
'./'`datawizard/interfaces/matrix_filters.c
datawizard/interfaces/matrix_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_filters.o
datawizard/interfaces/matrix_filters.c -o libstarpu_la-matrix_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_filters.Tpo
.deps/libstarpu_la-matrix_filters.Plo
libstarpu_la-matrix_interface.lo -MD -MP -MF
.deps/libstarpu_la-matrix_interface.Tpo -c -o
libstarpu_la-matrix_interface.lo `test -f
'datawizard/interfaces/matrix_interface.c' || echo
'./'`datawizard/interfaces/matrix_interface.c
datawizard/interfaces/matrix_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_interface.o
datawizard/interfaces/matrix_interface.c -o libstarpu_la-matrix_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_interface.Tpo
.deps/libstarpu_la-matrix_interface.Plo
libstarpu_la-block_filters.lo -MD -MP -MF
.deps/libstarpu_la-block_filters.Tpo -c -o libstarpu_la-block_filters.lo
`test -f 'datawizard/interfaces/block_filters.c' || echo
'./'`datawizard/interfaces/block_filters.c
.deps/libstarpu_la-block_filters.Tpo -c datawizard/interfaces/block_filters.c
-fPIC -DPIC -o .libs/libstarpu_la-block_filters.o
-o libstarpu_la-block_filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-block_filters.Tpo
.deps/libstarpu_la-block_filters.Plo
libstarpu_la-block_interface.lo -MD -MP -MF
.deps/libstarpu_la-block_interface.Tpo -c -o libstarpu_la-block_interface.lo
`test -f 'datawizard/interfaces/block_interface.c' || echo
'./'`datawizard/interfaces/block_interface.c
datawizard/interfaces/block_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-block_interface.o
datawizard/interfaces/block_interface.c -o libstarpu_la-block_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-block_interface.Tpo
.deps/libstarpu_la-block_interface.Plo
libstarpu_la-vector_interface.lo -MD -MP -MF
.deps/libstarpu_la-vector_interface.Tpo -c -o
libstarpu_la-vector_interface.lo `test -f
'datawizard/interfaces/vector_interface.c' || echo
'./'`datawizard/interfaces/vector_interface.c
datawizard/interfaces/vector_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_interface.o
datawizard/interfaces/vector_interface.c -o libstarpu_la-vector_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_interface.Tpo
.deps/libstarpu_la-vector_interface.Plo
libstarpu_la-bcsr_filters.lo -MD -MP -MF .deps/libstarpu_la-bcsr_filters.Tpo
-c -o libstarpu_la-bcsr_filters.lo `test -f
'datawizard/interfaces/bcsr_filters.c' || echo
'./'`datawizard/interfaces/bcsr_filters.c
-c datawizard/interfaces/bcsr_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-bcsr_filters.o
-c datawizard/interfaces/bcsr_filters.c -o libstarpu_la-bcsr_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_filters.Tpo .deps/libstarpu_la-bcsr_filters.Plo
libstarpu_la-csr_filters.lo -MD -MP -MF .deps/libstarpu_la-csr_filters.Tpo -c
-o libstarpu_la-csr_filters.lo `test -f 'datawizard/interfaces/csr_filters.c'
|| echo './'`datawizard/interfaces/csr_filters.c
datawizard/interfaces/csr_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-csr_filters.o
datawizard/interfaces/csr_filters.c -o libstarpu_la-csr_filters.o >/dev/null
2>&1
mv -f .deps/libstarpu_la-csr_filters.Tpo .deps/libstarpu_la-csr_filters.Plo
libstarpu_la-vector_filters.lo -MD -MP -MF
.deps/libstarpu_la-vector_filters.Tpo -c -o libstarpu_la-vector_filters.lo
`test -f 'datawizard/interfaces/vector_filters.c' || echo
'./'`datawizard/interfaces/vector_filters.c
datawizard/interfaces/vector_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_filters.o
datawizard/interfaces/vector_filters.c -o libstarpu_la-vector_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_filters.Tpo
.deps/libstarpu_la-vector_filters.Plo
libstarpu_la-variable_interface.lo -MD -MP -MF
.deps/libstarpu_la-variable_interface.Tpo -c -o
libstarpu_la-variable_interface.lo `test -f
'datawizard/interfaces/variable_interface.c' || echo
'./'`datawizard/interfaces/variable_interface.c
datawizard/interfaces/variable_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-variable_interface.o
datawizard/interfaces/variable_interface.c -o
libstarpu_la-variable_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-variable_interface.Tpo
.deps/libstarpu_la-variable_interface.Plo
libstarpu_la-void_interface.lo -MD -MP -MF
.deps/libstarpu_la-void_interface.Tpo -c -o libstarpu_la-void_interface.lo
`test -f 'datawizard/interfaces/void_interface.c' || echo
'./'`datawizard/interfaces/void_interface.c
datawizard/interfaces/void_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-void_interface.o
datawizard/interfaces/void_interface.c -o libstarpu_la-void_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-void_interface.Tpo
.deps/libstarpu_la-void_interface.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-malloc.lo
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c -o libstarpu_la-malloc.lo `test
-f 'util/malloc.c' || echo './'`util/malloc.c
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c util/malloc.c -fPIC -DPIC -o
.libs/libstarpu_la-malloc.o
-MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c util/malloc.c -o
libstarpu_la-malloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-malloc.Tpo .deps/libstarpu_la-malloc.Plo
libstarpu_la-execute_on_all.lo -MD -MP -MF
.deps/libstarpu_la-execute_on_all.Tpo -c -o libstarpu_la-execute_on_all.lo
`test -f 'util/execute_on_all.c' || echo './'`util/execute_on_all.c
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -fPIC -DPIC
-o .libs/libstarpu_la-execute_on_all.o
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -o
libstarpu_la-execute_on_all.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-execute_on_all.Tpo
.deps/libstarpu_la-execute_on_all.Plo
libstarpu_la-starpu_create_sync_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_create_sync_task.Tpo -c -o
libstarpu_la-starpu_create_sync_task.lo `test -f
'util/starpu_create_sync_task.c' || echo './'`util/starpu_create_sync_task.c
util/starpu_create_sync_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_create_sync_task.o
util/starpu_create_sync_task.c -o libstarpu_la-starpu_create_sync_task.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_create_sync_task.Tpo
.deps/libstarpu_la-starpu_create_sync_task.Plo
libstarpu_la-starpu_cublas.lo -MD -MP -MF
.deps/libstarpu_la-starpu_cublas.Tpo -c -o libstarpu_la-starpu_cublas.lo
`test -f 'util/starpu_cublas.c' || echo './'`util/starpu_cublas.c
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_cublas.o
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -o
libstarpu_la-starpu_cublas.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_cublas.Tpo
.deps/libstarpu_la-starpu_cublas.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-file.lo
-MD -MP -MF .deps/libstarpu_la-file.Tpo -c -o libstarpu_la-file.lo `test -f
'util/file.c' || echo './'`util/file.c
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-file.lo -MD
-MP -MF .deps/libstarpu_la-file.Tpo -c util/file.c -fPIC -DPIC -o
.libs/libstarpu_la-file.o
-MP -MF .deps/libstarpu_la-file.Tpo -c util/file.c -o libstarpu_la-file.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-file.Tpo .deps/libstarpu_la-file.Plo
libstarpu_la-starpu_data_cpy.lo -MD -MP -MF
.deps/libstarpu_la-starpu_data_cpy.Tpo -c -o libstarpu_la-starpu_data_cpy.lo
`test -f 'util/starpu_data_cpy.c' || echo './'`util/starpu_data_cpy.c
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -fPIC -DPIC
-o .libs/libstarpu_la-starpu_data_cpy.o
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -o
libstarpu_la-starpu_data_cpy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_data_cpy.Tpo
.deps/libstarpu_la-starpu_data_cpy.Plo
libstarpu_la-starpu_insert_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task.Tpo -c -o
libstarpu_la-starpu_insert_task.lo `test -f 'util/starpu_insert_task.c' ||
echo './'`util/starpu_insert_task.c
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_insert_task.o
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -o
libstarpu_la-starpu_insert_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task.Tpo
.deps/libstarpu_la-starpu_insert_task.Plo
libstarpu_la-starpu_insert_task_utils.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task_utils.Tpo -c -o
libstarpu_la-starpu_insert_task_utils.lo `test -f
'util/starpu_insert_task_utils.c' || echo './'`util/starpu_insert_task_utils.c
util/starpu_insert_task_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_insert_task_utils.o
util/starpu_insert_task_utils.c -o libstarpu_la-starpu_insert_task_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task_utils.Tpo
.deps/libstarpu_la-starpu_insert_task_utils.Plo
libstarpu_la-starpu_task_list.lo -MD -MP -MF
.deps/libstarpu_la-starpu_task_list.Tpo -c -o
libstarpu_la-starpu_task_list.lo `test -f 'util/starpu_task_list.c' || echo
'./'`util/starpu_task_list.c
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_task_list.o
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -o
libstarpu_la-starpu_task_list.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_task_list.Tpo
.deps/libstarpu_la-starpu_task_list.Plo
libstarpu_la-starpu_fxt.lo -MD -MP -MF .deps/libstarpu_la-starpu_fxt.Tpo -c
-o libstarpu_la-starpu_fxt.lo `test -f 'debug/traces/starpu_fxt.c' || echo
'./'`debug/traces/starpu_fxt.c
debug/traces/starpu_fxt.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_fxt.o
debug/traces/starpu_fxt.c -o libstarpu_la-starpu_fxt.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt.Tpo .deps/libstarpu_la-starpu_fxt.Plo
libstarpu_la-starpu_fxt_mpi.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c -o libstarpu_la-starpu_fxt_mpi.lo
`test -f 'debug/traces/starpu_fxt_mpi.c' || echo
'./'`debug/traces/starpu_fxt_mpi.c
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_mpi.o
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -o
libstarpu_la-starpu_fxt_mpi.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_mpi.Tpo
.deps/libstarpu_la-starpu_fxt_mpi.Plo
libstarpu_la-starpu_fxt_dag.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c -o libstarpu_la-starpu_fxt_dag.lo
`test -f 'debug/traces/starpu_fxt_dag.c' || echo
'./'`debug/traces/starpu_fxt_dag.c
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_dag.o
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -o
libstarpu_la-starpu_fxt_dag.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_dag.Tpo
.deps/libstarpu_la-starpu_fxt_dag.Plo
libstarpu_la-starpu_paje.lo -MD -MP -MF .deps/libstarpu_la-starpu_paje.Tpo -c
-o libstarpu_la-starpu_paje.lo `test -f 'debug/traces/starpu_paje.c' || echo
'./'`debug/traces/starpu_paje.c
debug/traces/starpu_paje.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_paje.o
debug/traces/starpu_paje.c -o libstarpu_la-starpu_paje.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_paje.Tpo .deps/libstarpu_la-starpu_paje.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-latency.lo
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c -o libstarpu_la-latency.lo
`test -f 'debug/latency.c' || echo './'`debug/latency.c
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c debug/latency.c -fPIC -DPIC -o
.libs/libstarpu_la-latency.o
-MD -MP -MF .deps/libstarpu_la-latency.Tpo -c debug/latency.c -o
libstarpu_la-latency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-latency.Tpo .deps/libstarpu_la-latency.Plo
libstarpu_la-structures_size.lo -MD -MP -MF
.deps/libstarpu_la-structures_size.Tpo -c -o libstarpu_la-structures_size.lo
`test -f 'debug/structures_size.c' || echo './'`debug/structures_size.c
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -fPIC
-DPIC -o .libs/libstarpu_la-structures_size.o
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -o
libstarpu_la-structures_size.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-structures_size.Tpo
.deps/libstarpu_la-structures_size.Plo
libstarpu_la-profiling.lo -MD -MP -MF .deps/libstarpu_la-profiling.Tpo -c -o
libstarpu_la-profiling.lo `test -f 'profiling/profiling.c' || echo
profiling/profiling.c -fPIC -DPIC -o .libs/libstarpu_la-profiling.o
profiling/profiling.c -o libstarpu_la-profiling.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling.Tpo .deps/libstarpu_la-profiling.Plo
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT libstarpu_la-bound.lo
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c -o libstarpu_la-bound.lo `test -f
'profiling/bound.c' || echo './'`profiling/bound.c
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c profiling/bound.c -fPIC -DPIC -o
.libs/libstarpu_la-bound.o
-MD -MP -MF .deps/libstarpu_la-bound.Tpo -c profiling/bound.c -o
libstarpu_la-bound.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-bound.Tpo .deps/libstarpu_la-bound.Plo
libstarpu_la-profiling_helpers.lo -MD -MP -MF
.deps/libstarpu_la-profiling_helpers.Tpo -c -o
libstarpu_la-profiling_helpers.lo `test -f 'profiling/profiling_helpers.c' ||
echo './'`profiling/profiling_helpers.c
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c
-fPIC -DPIC -o .libs/libstarpu_la-profiling_helpers.o
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c -o
libstarpu_la-profiling_helpers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling_helpers.Tpo
.deps/libstarpu_la-profiling_helpers.Plo
libstarpu_la-starpu_top.lo -MD -MP -MF .deps/libstarpu_la-starpu_top.Tpo -c
-o libstarpu_la-starpu_top.lo `test -f 'top/starpu_top.c' || echo
'./'`top/starpu_top.c
top/starpu_top.c -fPIC -DPIC -o .libs/libstarpu_la-starpu_top.o
top/starpu_top.c -o libstarpu_la-starpu_top.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_top.Tpo .deps/libstarpu_la-starpu_top.Plo
libstarpu_la-starputop_task.lo -MD -MP -MF
.deps/libstarpu_la-starputop_task.Tpo -c -o libstarpu_la-starputop_task.lo
`test -f 'top/starputop_task.c' || echo './'`top/starputop_task.c
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_task.o
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -o
libstarpu_la-starputop_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_task.Tpo
.deps/libstarpu_la-starputop_task.Plo
libstarpu_la-starputop_message_queue.lo -MD -MP -MF
.deps/libstarpu_la-starputop_message_queue.Tpo -c -o
libstarpu_la-starputop_message_queue.lo `test -f
'top/starputop_message_queue.c' || echo './'`top/starputop_message_queue.c
top/starputop_message_queue.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_message_queue.o
top/starputop_message_queue.c -o libstarpu_la-starputop_message_queue.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_message_queue.Tpo
.deps/libstarpu_la-starputop_message_queue.Plo
libstarpu_la-starputop_connection.lo -MD -MP -MF
.deps/libstarpu_la-starputop_connection.Tpo -c -o
libstarpu_la-starputop_connection.lo `test -f 'top/starputop_connection.c' ||
echo './'`top/starputop_connection.c
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c
-fPIC -DPIC -o .libs/libstarpu_la-starputop_connection.o
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c -o
libstarpu_la-starputop_connection.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_connection.Tpo
.deps/libstarpu_la-starputop_connection.Plo
libstarpu_la-driver_cpu.lo -MD -MP -MF .deps/libstarpu_la-driver_cpu.Tpo -c
-o libstarpu_la-driver_cpu.lo `test -f 'drivers/cpu/driver_cpu.c' || echo
'./'`drivers/cpu/driver_cpu.c
drivers/cpu/driver_cpu.c -fPIC -DPIC -o .libs/libstarpu_la-driver_cpu.o
drivers/cpu/driver_cpu.c -o libstarpu_la-driver_cpu.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_cpu.Tpo .deps/libstarpu_la-driver_cpu.Plo
libstarpu_la-driver_cuda.lo -MD -MP -MF .deps/libstarpu_la-driver_cuda.Tpo -c
-o libstarpu_la-driver_cuda.lo `test -f 'drivers/cuda/driver_cuda.c' || echo
'./'`drivers/cuda/driver_cuda.c
drivers/cuda/driver_cuda.c -fPIC -DPIC -o .libs/libstarpu_la-driver_cuda.o
drivers/cuda/driver_cuda.c -o libstarpu_la-driver_cuda.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_cuda.Tpo .deps/libstarpu_la-driver_cuda.Plo
libstarpu_la-driver_opencl.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl.Tpo -c -o libstarpu_la-driver_opencl.lo
`test -f 'drivers/opencl/driver_opencl.c' || echo
'./'`drivers/opencl/driver_opencl.c
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -fPIC
-DPIC -o .libs/libstarpu_la-driver_opencl.o
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -o
libstarpu_la-driver_opencl.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl.Tpo
.deps/libstarpu_la-driver_opencl.Plo
libstarpu_la-driver_opencl_utils.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl_utils.Tpo -c -o
libstarpu_la-driver_opencl_utils.lo `test -f
'drivers/opencl/driver_opencl_utils.c' || echo
'./'`drivers/opencl/driver_opencl_utils.c
drivers/opencl/driver_opencl_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-driver_opencl_utils.o
drivers/opencl/driver_opencl_utils.c -o libstarpu_la-driver_opencl_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl_utils.Tpo
.deps/libstarpu_la-driver_opencl_utils.Plo
/bin/bash ../libtool --tag=CC --mode=link gcc -W -Wall -Wextra
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -version-number 0:0:0
-no-undefined -l:/usr/local/cuda/lib64/libcublas.so -o libstarpu.la -rpath
/usr/local/lib libstarpu_la-barrier.lo libstarpu_la-hash.lo
libstarpu_la-htable32.lo libstarpu_la-rwlock.lo
libstarpu_la-starpu_spinlock.lo libstarpu_la-timing.lo libstarpu_la-fxt.lo
libstarpu_la-utils.lo libstarpu_la-jobs.lo libstarpu_la-task.lo
libstarpu_la-task_bundle.lo libstarpu_la-workers.lo
libstarpu_la-combined_workers.lo libstarpu_la-topology.lo
libstarpu_la-debug.lo libstarpu_la-errorcheck.lo
libstarpu_la-progress_hook.lo libstarpu_la-cg.lo libstarpu_la-dependencies.lo
libstarpu_la-implicit_data_deps.lo libstarpu_la-tags.lo
libstarpu_la-task_deps.lo libstarpu_la-htable.lo
libstarpu_la-data_concurrency.lo libstarpu_la-perfmodel_history.lo
libstarpu_la-perfmodel_bus.lo libstarpu_la-perfmodel.lo
libstarpu_la-regression.lo libstarpu_la-sched_policy.lo
libstarpu_la-priorities.lo libstarpu_la-parallel_task.lo
libstarpu_la-deque_modeling_policy_data_aware.lo libstarpu_la-heft.lo
libstarpu_la-random_policy.lo libstarpu_la-stack_queues.lo
libstarpu_la-deque_queues.lo libstarpu_la-fifo_queues.lo
libstarpu_la-detect_combined_workers.lo libstarpu_la-parallel_heft.lo
libstarpu_la-parallel_greedy.lo libstarpu_la-driver_common.lo
libstarpu_la-memory_nodes.lo libstarpu_la-write_back.lo
libstarpu_la-coherency.lo libstarpu_la-data_request.lo
libstarpu_la-progress.lo libstarpu_la-copy_driver.lo libstarpu_la-filters.lo
libstarpu_la-sort_data_handles.lo libstarpu_la-memalloc.lo
libstarpu_la-footprint.lo libstarpu_la-datastats.lo
libstarpu_la-user_interactions.lo libstarpu_la-reduction.lo
libstarpu_la-data_interface.lo libstarpu_la-bcsr_interface.lo
libstarpu_la-csr_interface.lo libstarpu_la-matrix_filters.lo
libstarpu_la-matrix_interface.lo libstarpu_la-block_filters.lo
libstarpu_la-block_interface.lo libstarpu_la-vector_interface.lo
libstarpu_la-bcsr_filters.lo libstarpu_la-csr_filters.lo
libstarpu_la-vector_filters.lo libstarpu_la-variable_interface.lo
libstarpu_la-void_interface.lo libstarpu_la-malloc.lo
libstarpu_la-execute_on_all.lo libstarpu_la-starpu_create_sync_task.lo
libstarpu_la-starpu_cublas.lo libstarpu_la-file.lo
libstarpu_la-starpu_data_cpy.lo libstarpu_la-starpu_insert_task.lo
libstarpu_la-starpu_insert_task_utils.lo libstarpu_la-starpu_task_list.lo
libstarpu_la-starpu_fxt.lo libstarpu_la-starpu_fxt_mpi.lo
libstarpu_la-starpu_fxt_dag.lo libstarpu_la-starpu_paje.lo
libstarpu_la-latency.lo libstarpu_la-structures_size.lo
libstarpu_la-profiling.lo libstarpu_la-bound.lo
libstarpu_la-profiling_helpers.lo libstarpu_la-starpu_top.lo
libstarpu_la-starputop_task.lo libstarpu_la-starputop_message_queue.lo
libstarpu_la-starputop_connection.lo libstarpu_la-driver_cpu.lo
libstarpu_la-driver_cuda.lo libstarpu_la-driver_opencl.lo
libstarpu_la-driver_opencl_utils.lo -L/usr/local/cuda/lib64 -lcudart
-lcublas -lcuda -lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim
-lrt -lpthread /usr/lib/libOpenCL.so.1.0.0
libtool: link: gcc -shared .libs/libstarpu_la-barrier.o
.libs/libstarpu_la-hash.o .libs/libstarpu_la-htable32.o
.libs/libstarpu_la-rwlock.o .libs/libstarpu_la-starpu_spinlock.o
.libs/libstarpu_la-timing.o .libs/libstarpu_la-fxt.o
.libs/libstarpu_la-utils.o .libs/libstarpu_la-jobs.o
.libs/libstarpu_la-task.o .libs/libstarpu_la-task_bundle.o
.libs/libstarpu_la-workers.o .libs/libstarpu_la-combined_workers.o
.libs/libstarpu_la-topology.o .libs/libstarpu_la-debug.o
.libs/libstarpu_la-errorcheck.o .libs/libstarpu_la-progress_hook.o
.libs/libstarpu_la-cg.o .libs/libstarpu_la-dependencies.o
.libs/libstarpu_la-implicit_data_deps.o .libs/libstarpu_la-tags.o
.libs/libstarpu_la-task_deps.o .libs/libstarpu_la-htable.o
.libs/libstarpu_la-data_concurrency.o .libs/libstarpu_la-perfmodel_history.o
.libs/libstarpu_la-perfmodel_bus.o .libs/libstarpu_la-perfmodel.o
.libs/libstarpu_la-regression.o .libs/libstarpu_la-sched_policy.o
.libs/libstarpu_la-priorities.o .libs/libstarpu_la-parallel_task.o
.libs/libstarpu_la-heft.o .libs/libstarpu_la-random_policy.o
.libs/libstarpu_la-stack_queues.o .libs/libstarpu_la-deque_queues.o
.libs/libstarpu_la-fifo_queues.o .libs/libstarpu_la-detect_combined_workers.o
.libs/libstarpu_la-parallel_heft.o .libs/libstarpu_la-parallel_greedy.o
.libs/libstarpu_la-driver_common.o .libs/libstarpu_la-memory_nodes.o
.libs/libstarpu_la-write_back.o .libs/libstarpu_la-coherency.o
.libs/libstarpu_la-data_request.o .libs/libstarpu_la-progress.o
.libs/libstarpu_la-copy_driver.o .libs/libstarpu_la-filters.o
.libs/libstarpu_la-sort_data_handles.o .libs/libstarpu_la-memalloc.o
.libs/libstarpu_la-footprint.o .libs/libstarpu_la-datastats.o
.libs/libstarpu_la-user_interactions.o .libs/libstarpu_la-reduction.o
.libs/libstarpu_la-data_interface.o .libs/libstarpu_la-bcsr_interface.o
.libs/libstarpu_la-csr_interface.o .libs/libstarpu_la-matrix_filters.o
.libs/libstarpu_la-matrix_interface.o .libs/libstarpu_la-block_filters.o
.libs/libstarpu_la-block_interface.o .libs/libstarpu_la-vector_interface.o
.libs/libstarpu_la-bcsr_filters.o .libs/libstarpu_la-csr_filters.o
.libs/libstarpu_la-vector_filters.o .libs/libstarpu_la-variable_interface.o
.libs/libstarpu_la-void_interface.o .libs/libstarpu_la-malloc.o
.libs/libstarpu_la-starpu_cublas.o .libs/libstarpu_la-file.o
.libs/libstarpu_la-starpu_data_cpy.o .libs/libstarpu_la-starpu_insert_task.o
.libs/libstarpu_la-starpu_task_list.o .libs/libstarpu_la-starpu_fxt.o
.libs/libstarpu_la-starpu_fxt_mpi.o .libs/libstarpu_la-starpu_fxt_dag.o
.libs/libstarpu_la-starpu_paje.o .libs/libstarpu_la-latency.o
.libs/libstarpu_la-structures_size.o .libs/libstarpu_la-profiling.o
.libs/libstarpu_la-bound.o .libs/libstarpu_la-profiling_helpers.o
.libs/libstarpu_la-starpu_top.o .libs/libstarpu_la-starputop_task.o
.libs/libstarpu_la-starputop_connection.o .libs/libstarpu_la-driver_cpu.o
.libs/libstarpu_la-driver_cuda.o .libs/libstarpu_la-driver_opencl.o
-l:/usr/local/cuda/lib64/libcublas.so -L/usr/local/cuda/lib64 -lcudart
-lcublas -lcuda -lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim -lrt
-lpthread -Wl,-soname -Wl,libstarpu.so.0 -o .libs/libstarpu.so.0.0.0
libtool: link: (cd ".libs" && rm -f "libstarpu.so.0" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so.0")
libtool: link: (cd ".libs" && rm -f "libstarpu.so" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so")
libtool: link: ar cru .libs/libstarpu.a libstarpu_la-barrier.o
libstarpu_la-hash.o libstarpu_la-htable32.o libstarpu_la-rwlock.o
libstarpu_la-starpu_spinlock.o libstarpu_la-timing.o libstarpu_la-fxt.o
libstarpu_la-utils.o libstarpu_la-jobs.o libstarpu_la-task.o
libstarpu_la-task_bundle.o libstarpu_la-workers.o
libstarpu_la-combined_workers.o libstarpu_la-topology.o libstarpu_la-debug.o
libstarpu_la-errorcheck.o libstarpu_la-progress_hook.o libstarpu_la-cg.o
libstarpu_la-dependencies.o libstarpu_la-implicit_data_deps.o
libstarpu_la-tags.o libstarpu_la-task_deps.o libstarpu_la-htable.o
libstarpu_la-data_concurrency.o libstarpu_la-perfmodel_history.o
libstarpu_la-perfmodel_bus.o libstarpu_la-perfmodel.o
libstarpu_la-regression.o libstarpu_la-sched_policy.o
libstarpu_la-priorities.o libstarpu_la-parallel_task.o
libstarpu_la-deque_modeling_policy_data_aware.o libstarpu_la-heft.o
libstarpu_la-random_policy.o libstarpu_la-stack_queues.o
libstarpu_la-deque_queues.o libstarpu_la-fifo_queues.o
libstarpu_la-detect_combined_workers.o libstarpu_la-parallel_heft.o
libstarpu_la-parallel_greedy.o libstarpu_la-driver_common.o
libstarpu_la-memory_nodes.o libstarpu_la-write_back.o
libstarpu_la-coherency.o libstarpu_la-data_request.o libstarpu_la-progress.o
libstarpu_la-copy_driver.o libstarpu_la-filters.o
libstarpu_la-sort_data_handles.o libstarpu_la-memalloc.o
libstarpu_la-footprint.o libstarpu_la-datastats.o
libstarpu_la-user_interactions.o libstarpu_la-reduction.o
libstarpu_la-data_interface.o libstarpu_la-bcsr_interface.o
libstarpu_la-csr_interface.o libstarpu_la-matrix_filters.o
libstarpu_la-matrix_interface.o libstarpu_la-block_filters.o
libstarpu_la-block_interface.o libstarpu_la-vector_interface.o
libstarpu_la-bcsr_filters.o libstarpu_la-csr_filters.o
libstarpu_la-vector_filters.o libstarpu_la-variable_interface.o
libstarpu_la-void_interface.o libstarpu_la-malloc.o
libstarpu_la-execute_on_all.o libstarpu_la-starpu_create_sync_task.o
libstarpu_la-starpu_cublas.o libstarpu_la-file.o
libstarpu_la-starpu_data_cpy.o libstarpu_la-starpu_insert_task.o
libstarpu_la-starpu_insert_task_utils.o libstarpu_la-starpu_task_list.o
libstarpu_la-starpu_fxt.o libstarpu_la-starpu_fxt_mpi.o
libstarpu_la-starpu_fxt_dag.o libstarpu_la-starpu_paje.o
libstarpu_la-latency.o libstarpu_la-structures_size.o
libstarpu_la-profiling.o libstarpu_la-bound.o
libstarpu_la-profiling_helpers.o libstarpu_la-starpu_top.o
libstarpu_la-starputop_task.o libstarpu_la-starputop_message_queue.o
libstarpu_la-starputop_connection.o libstarpu_la-driver_cpu.o
libstarpu_la-driver_cuda.o libstarpu_la-driver_opencl.o
libtool: link: ranlib .libs/libstarpu.a
libtool: link: ( cd ".libs" && rm -f "libstarpu.la" && ln -s
"../libstarpu.la" "libstarpu.la" )
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/src'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/src'
Making all in tools
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tools'
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tools'
gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include -I../gcc-plugin/src
-I../include/ -I../tools/ -I../mpi/ -I../src -I../src -D_GNU_SOURCE
-DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_calibrate_bus.o
-MD -MP -MF .deps/starpu_calibrate_bus.Tpo -c -o starpu_calibrate_bus.o
starpu_calibrate_bus.c
mv -f .deps/starpu_calibrate_bus.Tpo .deps/starpu_calibrate_bus.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -I/usr/local/cuda/include
-I/usr/include/CL/ -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_calibrate_bus
starpu_calibrate_bus.o ../src/libstarpu.la -lrt -lpthread
libtool: link: gcc -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o
.libs/starpu_calibrate_bus starpu_calibrate_bus.o /usr/lib/libOpenCL.so.1.0.0
-l:/usr/local/cuda/lib64/libcublas.so ../src/.libs/libstarpu.so -lrt
-lpthread
starpu_perfmodel_display.o -MD -MP -MF .deps/starpu_perfmodel_display.Tpo -c
-o starpu_perfmodel_display.o starpu_perfmodel_display.c
mv -f .deps/starpu_perfmodel_display.Tpo .deps/starpu_perfmodel_display.Po
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_perfmodel_display
starpu_perfmodel_display.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_perfmodel_display starpu_perfmodel_display.o
/usr/lib/libOpenCL.so.1.0.0 -l:/usr/local/cuda/lib64/libcublas.so
../src/.libs/libstarpu.so -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_perfmodel_plot.o
-MD -MP -MF .deps/starpu_perfmodel_plot.Tpo -c -o starpu_perfmodel_plot.o
starpu_perfmodel_plot.c
mv -f .deps/starpu_perfmodel_plot.Tpo .deps/starpu_perfmodel_plot.Po
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_perfmodel_plot
starpu_perfmodel_plot.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_perfmodel_plot starpu_perfmodel_plot.o
starpu_machine_display.o -MD -MP -MF .deps/starpu_machine_display.Tpo -c -o
starpu_machine_display.o starpu_machine_display.c
mv -f .deps/starpu_machine_display.Tpo .deps/starpu_machine_display.Po
-l:/usr/local/cuda/lib64/libcublas.so -o starpu_machine_display
starpu_machine_display.o ../src/libstarpu.la -lrt -lpthread
.libs/starpu_machine_display starpu_machine_display.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT cbc2paje.o -MD -MP -MF
.deps/cbc2paje.Tpo -c -o cbc2paje.o cbc2paje.c
mv -f .deps/cbc2paje.Tpo .deps/cbc2paje.Po
-l:/usr/local/cuda/lib64/libcublas.so -o cbc2paje cbc2paje.o
../src/libstarpu.la -lrt -lpthread /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/cbc2paje cbc2paje.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT lp2paje.o -MD -MP -MF
.deps/lp2paje.Tpo -c -o lp2paje.o lp2paje.c
mv -f .deps/lp2paje.Tpo .deps/lp2paje.Po
-l:/usr/local/cuda/lib64/libcublas.so -o lp2paje lp2paje.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/lp2paje lp2paje.o
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tools'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tools'
Making all in tests
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make all-recursive
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[3]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/tests'
-I../include/ -I../src -I../src/ -D_GNU_SOURCE -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT restart.o -MD -MP -MF
.deps/restart.Tpo -c -o restart.o `test -f 'core/restart.c' || echo
'./'`core/restart.c
mv -f .deps/restart.Tpo .deps/restart.Po
/bin/bash ../libtool --tag=CC --mode=link gcc -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -L/usr/local/cuda/lib64
-lcudart -lcublas -lcuda -lstdc++
-l:/usr/local/cuda/lib64/libcublas.so -o core/restart restart.o
libtool: link: gcc -Wall -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/restart
restart.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-l:/usr/local/cuda/lib64/libcublas.so ../src/.libs/libstarpu.so -lrt -lpthread
execute_on_a_specific_worker.o -MD -MP -MF
.deps/execute_on_a_specific_worker.Tpo -c -o execute_on_a_specific_worker.o
`test -f 'core/execute_on_a_specific_worker.c' || echo
'./'`core/execute_on_a_specific_worker.c
mv -f .deps/execute_on_a_specific_worker.Tpo
.deps/execute_on_a_specific_worker.Po
-I/home/deshpandea/lpng155/
-I/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/
-l:/usr/local/cuda/lib64/libcublas.so -o core/execute_on_a_specific_worker
execute_on_a_specific_worker.o ../src/libstarpu.la -lrt -lpthread
core/.libs/execute_on_a_specific_worker execute_on_a_specific_worker.o
/usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT insert_task.o -MD -MP
-MF .deps/insert_task.Tpo -c -o insert_task.o `test -f 'core/insert_task.c'
|| echo './'`core/insert_task.c
mv -f .deps/insert_task.Tpo .deps/insert_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/insert_task insert_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/insert_task
insert_task.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT multithreaded.o -MD -MP
-MF .deps/multithreaded.Tpo -c -o multithreaded.o `test -f
'core/multithreaded.c' || echo './'`core/multithreaded.c
mv -f .deps/multithreaded.Tpo .deps/multithreaded.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/multithreaded multithreaded.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/multithreaded
multithreaded.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT multithreaded_init.o
-MD -MP -MF .deps/multithreaded_init.Tpo -c -o multithreaded_init.o `test -f
'core/multithreaded_init.c' || echo './'`core/multithreaded_init.c
mv -f .deps/multithreaded_init.Tpo .deps/multithreaded_init.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/multithreaded_init
multithreaded_init.o ../src/libstarpu.la -lrt -lpthread
core/.libs/multithreaded_init multithreaded_init.o
starpu_task_wait_for_all.o -MD -MP -MF .deps/starpu_task_wait_for_all.Tpo -c
-o starpu_task_wait_for_all.o `test -f 'core/starpu_task_wait_for_all.c' ||
echo './'`core/starpu_task_wait_for_all.c
mv -f .deps/starpu_task_wait_for_all.Tpo .deps/starpu_task_wait_for_all.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/starpu_task_wait_for_all
starpu_task_wait_for_all.o ../src/libstarpu.la -lrt -lpthread
core/.libs/starpu_task_wait_for_all starpu_task_wait_for_all.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_task_wait.o -MD
-MP -MF .deps/starpu_task_wait.Tpo -c -o starpu_task_wait.o `test -f
'core/starpu_task_wait.c' || echo './'`core/starpu_task_wait.c
mv -f .deps/starpu_task_wait.Tpo .deps/starpu_task_wait.Po
starpu_task_wait.o ../src/libstarpu.la -lrt -lpthread
core/.libs/starpu_task_wait starpu_task_wait.o /usr/lib/libOpenCL.so.1.0.0
-L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda -lstdc++
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT static_restartable.o
-MD -MP -MF .deps/static_restartable.Tpo -c -o static_restartable.o `test -f
'core/static_restartable.c' || echo './'`core/static_restartable.c
mv -f .deps/static_restartable.Tpo .deps/static_restartable.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/static_restartable
static_restartable.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable static_restartable.o
static_restartable_using_initializer.o -MD -MP -MF
.deps/static_restartable_using_initializer.Tpo -c -o
static_restartable_using_initializer.o `test -f
'core/static_restartable_using_initializer.c' || echo
'./'`core/static_restartable_using_initializer.c
mv -f .deps/static_restartable_using_initializer.Tpo
.deps/static_restartable_using_initializer.Po
static_restartable_using_initializer.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable_using_initializer
static_restartable_using_initializer.o /usr/lib/libOpenCL.so.1.0.0
static_restartable_tag.o -MD -MP -MF .deps/static_restartable_tag.Tpo -c -o
static_restartable_tag.o `test -f 'core/static_restartable_tag.c' || echo
'./'`core/static_restartable_tag.c
mv -f .deps/static_restartable_tag.Tpo .deps/static_restartable_tag.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/static_restartable_tag
static_restartable_tag.o ../src/libstarpu.la -lrt -lpthread
core/.libs/static_restartable_tag static_restartable_tag.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT regenerate.o -MD -MP
-MF .deps/regenerate.Tpo -c -o regenerate.o `test -f 'core/regenerate.c' ||
echo './'`core/regenerate.c
mv -f .deps/regenerate.Tpo .deps/regenerate.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/regenerate regenerate.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/regenerate
regenerate.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
wait_all_regenerable_tasks.o -MD -MP -MF .deps/wait_all_regenerable_tasks.Tpo
-c -o wait_all_regenerable_tasks.o `test -f
'core/wait_all_regenerable_tasks.c' || echo
'./'`core/wait_all_regenerable_tasks.c
mv -f .deps/wait_all_regenerable_tasks.Tpo .deps/wait_all_regenerable_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/wait_all_regenerable_tasks
wait_all_regenerable_tasks.o ../src/libstarpu.la -lrt -lpthread
core/.libs/wait_all_regenerable_tasks wait_all_regenerable_tasks.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT subgraph_repeat.o -MD
-MP -MF .deps/subgraph_repeat.Tpo -c -o subgraph_repeat.o `test -f
'core/subgraph_repeat.c' || echo './'`core/subgraph_repeat.c
mv -f .deps/subgraph_repeat.Tpo .deps/subgraph_repeat.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/subgraph_repeat
subgraph_repeat.o ../src/libstarpu.la -lrt -lpthread
core/.libs/subgraph_repeat subgraph_repeat.o /usr/lib/libOpenCL.so.1.0.0
subgraph_repeat_regenerate.o -MD -MP -MF .deps/subgraph_repeat_regenerate.Tpo
-c -o subgraph_repeat_regenerate.o `test -f
'core/subgraph_repeat_regenerate.c' || echo
'./'`core/subgraph_repeat_regenerate.c
mv -f .deps/subgraph_repeat_regenerate.Tpo .deps/subgraph_repeat_regenerate.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/subgraph_repeat_regenerate
subgraph_repeat_regenerate.o ../src/libstarpu.la -lrt -lpthread
core/.libs/subgraph_repeat_regenerate subgraph_repeat_regenerate.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task.o -MD -MP
-MF .deps/empty_task.Tpo -c -o empty_task.o `test -f 'core/empty_task.c' ||
echo './'`core/empty_task.c
mv -f .deps/empty_task.Tpo .deps/empty_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task empty_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/empty_task
empty_task.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task_sync_point.o
-MD -MP -MF .deps/empty_task_sync_point.Tpo -c -o empty_task_sync_point.o
`test -f 'core/empty_task_sync_point.c' || echo
'./'`core/empty_task_sync_point.c
mv -f .deps/empty_task_sync_point.Tpo .deps/empty_task_sync_point.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_sync_point
empty_task_sync_point.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_sync_point empty_task_sync_point.o
empty_task_sync_point_tasks.o -MD -MP -MF
.deps/empty_task_sync_point_tasks.Tpo -c -o empty_task_sync_point_tasks.o
`test -f 'core/empty_task_sync_point_tasks.c' || echo
'./'`core/empty_task_sync_point_tasks.c
mv -f .deps/empty_task_sync_point_tasks.Tpo
.deps/empty_task_sync_point_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_sync_point_tasks
empty_task_sync_point_tasks.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_sync_point_tasks empty_task_sync_point_tasks.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT empty_task_chain.o -MD
-MP -MF .deps/empty_task_chain.Tpo -c -o empty_task_chain.o `test -f
'core/empty_task_chain.c' || echo './'`core/empty_task_chain.c
mv -f .deps/empty_task_chain.Tpo .deps/empty_task_chain.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/empty_task_chain
empty_task_chain.o ../src/libstarpu.la -lrt -lpthread
core/.libs/empty_task_chain empty_task_chain.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_wait_api.o -MD -MP
-MF .deps/tag_wait_api.Tpo -c -o tag_wait_api.o `test -f
'core/tag_wait_api.c' || echo './'`core/tag_wait_api.c
mv -f .deps/tag_wait_api.Tpo .deps/tag_wait_api.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/tag_wait_api tag_wait_api.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/tag_wait_api
tag_wait_api.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT task_wait_api.o -MD -MP
-MF .deps/task_wait_api.Tpo -c -o task_wait_api.o `test -f
'core/task_wait_api.c' || echo './'`core/task_wait_api.c
mv -f .deps/task_wait_api.Tpo .deps/task_wait_api.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/task_wait_api task_wait_api.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o core/.libs/task_wait_api
task_wait_api.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
declare_deps_in_callback.o -MD -MP -MF .deps/declare_deps_in_callback.Tpo -c
-o declare_deps_in_callback.o `test -f 'core/declare_deps_in_callback.c' ||
echo './'`core/declare_deps_in_callback.c
mv -f .deps/declare_deps_in_callback.Tpo .deps/declare_deps_in_callback.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/declare_deps_in_callback
declare_deps_in_callback.o ../src/libstarpu.la -lrt -lpthread
core/.libs/declare_deps_in_callback declare_deps_in_callback.o
declare_deps_after_submission.o -MD -MP -MF
.deps/declare_deps_after_submission.Tpo -c -o declare_deps_after_submission.o
`test -f 'core/declare_deps_after_submission.c' || echo
'./'`core/declare_deps_after_submission.c
mv -f .deps/declare_deps_after_submission.Tpo
.deps/declare_deps_after_submission.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/declare_deps_after_submission
declare_deps_after_submission.o ../src/libstarpu.la -lrt -lpthread
core/.libs/declare_deps_after_submission declare_deps_after_submission.o
declare_deps_after_submission_synchronous.o -MD -MP -MF
.deps/declare_deps_after_submission_synchronous.Tpo -c -o
declare_deps_after_submission_synchronous.o `test -f
'core/declare_deps_after_submission_synchronous.c' || echo
'./'`core/declare_deps_after_submission_synchronous.c
mv -f .deps/declare_deps_after_submission_synchronous.Tpo
.deps/declare_deps_after_submission_synchronous.Po
declare_deps_after_submission_synchronous.o ../src/libstarpu.la -lrt
core/.libs/declare_deps_after_submission_synchronous
declare_deps_after_submission_synchronous.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT get_current_task.o -MD
-MP -MF .deps/get_current_task.Tpo -c -o get_current_task.o `test -f
'core/get_current_task.c' || echo './'`core/get_current_task.c
mv -f .deps/get_current_task.Tpo .deps/get_current_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o core/get_current_task
get_current_task.o ../src/libstarpu.la -lrt -lpthread
core/.libs/get_current_task get_current_task.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_cb.o -MD -MP
-MF .deps/acquire_cb.Tpo -c -o acquire_cb.o `test -f
'datawizard/acquire_cb.c' || echo './'`datawizard/acquire_cb.c
mv -f .deps/acquire_cb.Tpo .deps/acquire_cb.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_cb acquire_cb.o
datawizard/.libs/acquire_cb acquire_cb.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_cb_insert.o -MD
-MP -MF .deps/acquire_cb_insert.Tpo -c -o acquire_cb_insert.o `test -f
'datawizard/acquire_cb_insert.c' || echo './'`datawizard/acquire_cb_insert.c
mv -f .deps/acquire_cb_insert.Tpo .deps/acquire_cb_insert.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_cb_insert
acquire_cb_insert.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/acquire_cb_insert acquire_cb_insert.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_release.o -MD
-MP -MF .deps/acquire_release.Tpo -c -o acquire_release.o `test -f
'datawizard/acquire_release.c' || echo './'`datawizard/acquire_release.c
mv -f .deps/acquire_release.Tpo .deps/acquire_release.Po
/bin/mkdir -p `dirname datawizard/acquire_release_cuda.o`
/usr/local/cuda/bin/nvcc datawizard/acquire_release_cuda.cu -c -o
datawizard/acquire_release_cuda.o --compiler-options -fno-strict-aliasing
-I/usr/local/cuda/include -m64 -I../include/ -I../include
-I/usr/local/include
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_release
acquire_release.o datawizard/acquire_release_cuda.o ../src/libstarpu.la
datawizard/.libs/acquire_release acquire_release.o
datawizard/acquire_release_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT acquire_release2.o -MD
-MP -MF .deps/acquire_release2.Tpo -c -o acquire_release2.o `test -f
'datawizard/acquire_release2.c' || echo './'`datawizard/acquire_release2.c
mv -f .deps/acquire_release2.Tpo .deps/acquire_release2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/acquire_release2
acquire_release2.o datawizard/acquire_release_cuda.o ../src/libstarpu.la
datawizard/.libs/acquire_release2 acquire_release2.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT copy.o -MD -MP -MF
.deps/copy.Tpo -c -o copy.o `test -f 'datawizard/copy.c' || echo
'./'`datawizard/copy.c
mv -f .deps/copy.Tpo .deps/copy.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/copy copy.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/copy
copy.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_implicit_deps.o
-MD -MP -MF .deps/data_implicit_deps.Tpo -c -o data_implicit_deps.o `test -f
'datawizard/data_implicit_deps.c' || echo './'`datawizard/data_implicit_deps.c
mv -f .deps/data_implicit_deps.Tpo .deps/data_implicit_deps.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_implicit_deps
data_implicit_deps.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/data_implicit_deps data_implicit_deps.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_lookup.o -MD -MP
-MF .deps/data_lookup.Tpo -c -o data_lookup.o `test -f
'datawizard/data_lookup.c' || echo './'`datawizard/data_lookup.c
mv -f .deps/data_lookup.Tpo .deps/data_lookup.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_lookup data_lookup.o
datawizard/.libs/data_lookup data_lookup.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT scratch.o -MD -MP -MF
.deps/scratch.Tpo -c -o scratch.o `test -f 'datawizard/scratch.c' || echo
'./'`datawizard/scratch.c
mv -f .deps/scratch.Tpo .deps/scratch.Po
/bin/mkdir -p `dirname datawizard/scratch_cuda.o`
/usr/local/cuda/bin/nvcc datawizard/scratch_cuda.cu -c -o
datawizard/scratch_cuda.o --compiler-options -fno-strict-aliasing
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/scratch scratch.o
datawizard/scratch_cuda.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/scratch
scratch.o datawizard/scratch_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT sync_and_notify_data.o
-MD -MP -MF .deps/sync_and_notify_data.Tpo -c -o sync_and_notify_data.o `test
-f 'datawizard/sync_and_notify_data.c' || echo
'./'`datawizard/sync_and_notify_data.c
mv -f .deps/sync_and_notify_data.Tpo .deps/sync_and_notify_data.Po
/bin/mkdir -p `dirname datawizard/sync_and_notify_data_kernels.o`
/usr/local/cuda/bin/nvcc datawizard/sync_and_notify_data_kernels.cu -c -o
datawizard/sync_and_notify_data_kernels.o --compiler-options
-fno-strict-aliasing -I/usr/local/cuda/include -m64 -I../include/
-I../include -I/usr/local/include
sync_and_notify_data_opencl.o -MD -MP -MF
.deps/sync_and_notify_data_opencl.Tpo -c -o sync_and_notify_data_opencl.o
`test -f 'datawizard/sync_and_notify_data_opencl.c' || echo
'./'`datawizard/sync_and_notify_data_opencl.c
mv -f .deps/sync_and_notify_data_opencl.Tpo
.deps/sync_and_notify_data_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/sync_and_notify_data
sync_and_notify_data.o datawizard/sync_and_notify_data_kernels.o
sync_and_notify_data_opencl.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_and_notify_data sync_and_notify_data.o
datawizard/sync_and_notify_data_kernels.o sync_and_notify_data_opencl.o
sync_and_notify_data_implicit.o -MD -MP -MF
.deps/sync_and_notify_data_implicit.Tpo -c -o sync_and_notify_data_implicit.o
`test -f 'datawizard/sync_and_notify_data_implicit.c' || echo
'./'`datawizard/sync_and_notify_data_implicit.c
mv -f .deps/sync_and_notify_data_implicit.Tpo
.deps/sync_and_notify_data_implicit.Po
datawizard/sync_and_notify_data_implicit sync_and_notify_data_implicit.o
datawizard/.libs/sync_and_notify_data_implicit
sync_and_notify_data_implicit.o datawizard/sync_and_notify_data_kernels.o
sync_and_notify_data_opencl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dsm_stress.o -MD -MP
-MF .deps/dsm_stress.Tpo -c -o dsm_stress.o `test -f
'datawizard/dsm_stress.c' || echo './'`datawizard/dsm_stress.c
mv -f .deps/dsm_stress.Tpo .deps/dsm_stress.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/dsm_stress dsm_stress.o
datawizard/.libs/dsm_stress dsm_stress.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT write_only_tmp_buffer.o
-MD -MP -MF .deps/write_only_tmp_buffer.Tpo -c -o write_only_tmp_buffer.o
`test -f 'datawizard/write_only_tmp_buffer.c' || echo
'./'`datawizard/write_only_tmp_buffer.c
mv -f .deps/write_only_tmp_buffer.Tpo .deps/write_only_tmp_buffer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/write_only_tmp_buffer
write_only_tmp_buffer.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/write_only_tmp_buffer write_only_tmp_buffer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT data_invalidation.o -MD
-MP -MF .deps/data_invalidation.Tpo -c -o data_invalidation.o `test -f
'datawizard/data_invalidation.c' || echo './'`datawizard/data_invalidation.c
mv -f .deps/data_invalidation.Tpo .deps/data_invalidation.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/data_invalidation
data_invalidation.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/data_invalidation data_invalidation.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dining_philosophers.o
-MD -MP -MF .deps/dining_philosophers.Tpo -c -o dining_philosophers.o `test
-f 'datawizard/dining_philosophers.c' || echo
'./'`datawizard/dining_philosophers.c
mv -f .deps/dining_philosophers.Tpo .deps/dining_philosophers.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/dining_philosophers
dining_philosophers.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/dining_philosophers dining_philosophers.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT manual_reduction.o -MD
-MP -MF .deps/manual_reduction.Tpo -c -o manual_reduction.o `test -f
'datawizard/manual_reduction.c' || echo './'`datawizard/manual_reduction.c
mv -f .deps/manual_reduction.Tpo .deps/manual_reduction.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/manual_reduction
manual_reduction.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/manual_reduction manual_reduction.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT readers_and_writers.o
-MD -MP -MF .deps/readers_and_writers.Tpo -c -o readers_and_writers.o `test
-f 'datawizard/readers_and_writers.c' || echo
'./'`datawizard/readers_and_writers.c
mv -f .deps/readers_and_writers.Tpo .deps/readers_and_writers.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/readers_and_writers
readers_and_writers.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/readers_and_writers readers_and_writers.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT unpartition.o -MD -MP
-MF .deps/unpartition.Tpo -c -o unpartition.o `test -f
'datawizard/unpartition.c' || echo './'`datawizard/unpartition.c
mv -f .deps/unpartition.Tpo .deps/unpartition.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/unpartition unpartition.o
datawizard/.libs/unpartition unpartition.o /usr/lib/libOpenCL.so.1.0.0
user_interaction_implicit.o -MD -MP -MF .deps/user_interaction_implicit.Tpo
-c -o user_interaction_implicit.o `test -f
'datawizard/user_interaction_implicit.c' || echo
'./'`datawizard/user_interaction_implicit.c
mv -f .deps/user_interaction_implicit.Tpo .deps/user_interaction_implicit.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/user_interaction_implicit
user_interaction_implicit.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/user_interaction_implicit user_interaction_implicit.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT reclaim.o -MD -MP -MF
.deps/reclaim.Tpo -c -o reclaim.o `test -f 'datawizard/reclaim.c' || echo
'./'`datawizard/reclaim.c
mv -f .deps/reclaim.Tpo .deps/reclaim.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/reclaim reclaim.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/reclaim
reclaim.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
sync_with_data_with_mem.o -MD -MP -MF .deps/sync_with_data_with_mem.Tpo -c -o
sync_with_data_with_mem.o `test -f 'datawizard/sync_with_data_with_mem.c' ||
echo './'`datawizard/sync_with_data_with_mem.c
mv -f .deps/sync_with_data_with_mem.Tpo .deps/sync_with_data_with_mem.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/sync_with_data_with_mem
sync_with_data_with_mem.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_with_data_with_mem sync_with_data_with_mem.o
sync_with_data_with_mem_non_blocking.o -MD -MP -MF
.deps/sync_with_data_with_mem_non_blocking.Tpo -c -o
sync_with_data_with_mem_non_blocking.o `test -f
'datawizard/sync_with_data_with_mem_non_blocking.c' || echo
'./'`datawizard/sync_with_data_with_mem_non_blocking.c
mv -f .deps/sync_with_data_with_mem_non_blocking.Tpo
.deps/sync_with_data_with_mem_non_blocking.Po
sync_with_data_with_mem_non_blocking.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/sync_with_data_with_mem_non_blocking
sync_with_data_with_mem_non_blocking.o /usr/lib/libOpenCL.so.1.0.0
sync_with_data_with_mem_non_blocking_implicit.o -MD -MP -MF
.deps/sync_with_data_with_mem_non_blocking_implicit.Tpo -c -o
sync_with_data_with_mem_non_blocking_implicit.o `test -f
'datawizard/sync_with_data_with_mem_non_blocking_implicit.c' || echo
'./'`datawizard/sync_with_data_with_mem_non_blocking_implicit.c
mv -f .deps/sync_with_data_with_mem_non_blocking_implicit.Tpo
.deps/sync_with_data_with_mem_non_blocking_implicit.Po
sync_with_data_with_mem_non_blocking_implicit.o ../src/libstarpu.la -lrt
datawizard/.libs/sync_with_data_with_mem_non_blocking_implicit
sync_with_data_with_mem_non_blocking_implicit.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mpi_like.o -MD -MP -MF
.deps/mpi_like.Tpo -c -o mpi_like.o `test -f 'datawizard/mpi_like.c' || echo
'./'`datawizard/mpi_like.c
mv -f .deps/mpi_like.Tpo .deps/mpi_like.Po
/bin/mkdir -p `dirname datawizard/cuda_codelet_unsigned_inc.o`
/usr/local/cuda/bin/nvcc datawizard/cuda_codelet_unsigned_inc.cu -c -o
datawizard/cuda_codelet_unsigned_inc.o --compiler-options
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/mpi_like mpi_like.o
datawizard/cuda_codelet_unsigned_inc.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o datawizard/.libs/mpi_like
mpi_like.o datawizard/cuda_codelet_unsigned_inc.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mpi_like_async.o -MD
-MP -MF .deps/mpi_like_async.Tpo -c -o mpi_like_async.o `test -f
'datawizard/mpi_like_async.c' || echo './'`datawizard/mpi_like_async.c
mv -f .deps/mpi_like_async.Tpo .deps/mpi_like_async.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/mpi_like_async
mpi_like_async.o datawizard/cuda_codelet_unsigned_inc.o ../src/libstarpu.la
datawizard/.libs/mpi_like_async mpi_like_async.o
critical_section_with_void_interface.o -MD -MP -MF
.deps/critical_section_with_void_interface.Tpo -c -o
critical_section_with_void_interface.o `test -f
'datawizard/critical_section_with_void_interface.c' || echo
'./'`datawizard/critical_section_with_void_interface.c
mv -f .deps/critical_section_with_void_interface.Tpo
.deps/critical_section_with_void_interface.Po
critical_section_with_void_interface.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/critical_section_with_void_interface
critical_section_with_void_interface.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT increment_redux.o -MD
-MP -MF .deps/increment_redux.Tpo -c -o increment_redux.o `test -f
'datawizard/increment_redux.c' || echo './'`datawizard/increment_redux.c
mv -f .deps/increment_redux.Tpo .deps/increment_redux.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/increment_redux
increment_redux.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/increment_redux increment_redux.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT increment_redux_v2.o
-MD -MP -MF .deps/increment_redux_v2.Tpo -c -o increment_redux_v2.o `test -f
'datawizard/increment_redux_v2.c' || echo './'`datawizard/increment_redux_v2.c
mv -f .deps/increment_redux_v2.Tpo .deps/increment_redux_v2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/increment_redux_v2
increment_redux_v2.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/increment_redux_v2 increment_redux_v2.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT handle_to_pointer.o -MD
-MP -MF .deps/handle_to_pointer.Tpo -c -o handle_to_pointer.o `test -f
'datawizard/handle_to_pointer.c' || echo './'`datawizard/handle_to_pointer.c
mv -f .deps/handle_to_pointer.Tpo .deps/handle_to_pointer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/handle_to_pointer
handle_to_pointer.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/handle_to_pointer handle_to_pointer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT lazy_allocation.o -MD
-MP -MF .deps/lazy_allocation.Tpo -c -o lazy_allocation.o `test -f
'datawizard/lazy_allocation.c' || echo './'`datawizard/lazy_allocation.c
mv -f .deps/lazy_allocation.Tpo .deps/lazy_allocation.Po
-l:/usr/local/cuda/lib64/libcublas.so -o datawizard/lazy_allocation
lazy_allocation.o ../src/libstarpu.la -lrt -lpthread
datawizard/.libs/lazy_allocation lazy_allocation.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_init_noworker.o
-MD -MP -MF .deps/starpu_init_noworker.Tpo -c -o starpu_init_noworker.o `test
-f 'errorcheck/starpu_init_noworker.c' || echo
'./'`errorcheck/starpu_init_noworker.c
mv -f .deps/starpu_init_noworker.Tpo .deps/starpu_init_noworker.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/starpu_init_noworker
starpu_init_noworker.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/starpu_init_noworker starpu_init_noworker.o
invalid_blocking_calls.o -MD -MP -MF .deps/invalid_blocking_calls.Tpo -c -o
invalid_blocking_calls.o `test -f 'errorcheck/invalid_blocking_calls.c' ||
echo './'`errorcheck/invalid_blocking_calls.c
mv -f .deps/invalid_blocking_calls.Tpo .deps/invalid_blocking_calls.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/invalid_blocking_calls
invalid_blocking_calls.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/invalid_blocking_calls invalid_blocking_calls.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT invalid_tasks.o -MD -MP
-MF .deps/invalid_tasks.Tpo -c -o invalid_tasks.o `test -f
'errorcheck/invalid_tasks.c' || echo './'`errorcheck/invalid_tasks.c
mv -f .deps/invalid_tasks.Tpo .deps/invalid_tasks.Po
-l:/usr/local/cuda/lib64/libcublas.so -o errorcheck/invalid_tasks
invalid_tasks.o ../src/libstarpu.la -lrt -lpthread
errorcheck/.libs/invalid_tasks invalid_tasks.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT cublas_init.o -MD -MP
-MF .deps/cublas_init.Tpo -c -o cublas_init.o `test -f 'helper/cublas_init.c'
|| echo './'`helper/cublas_init.c
mv -f .deps/cublas_init.Tpo .deps/cublas_init.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/cublas_init cublas_init.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o helper/.libs/cublas_init
cublas_init.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT starpu_data_cpy.o -MD
-MP -MF .deps/starpu_data_cpy.Tpo -c -o starpu_data_cpy.o `test -f
'helper/starpu_data_cpy.c' || echo './'`helper/starpu_data_cpy.c
mv -f .deps/starpu_data_cpy.Tpo .deps/starpu_data_cpy.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/starpu_data_cpy
starpu_data_cpy.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/starpu_data_cpy starpu_data_cpy.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT pinned_memory.o -MD -MP
-MF .deps/pinned_memory.Tpo -c -o pinned_memory.o `test -f
'helper/pinned_memory.c' || echo './'`helper/pinned_memory.c
mv -f .deps/pinned_memory.Tpo .deps/pinned_memory.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/pinned_memory pinned_memory.o
helper/.libs/pinned_memory pinned_memory.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT execute_on_all.o -MD
-MP -MF .deps/execute_on_all.Tpo -c -o execute_on_all.o `test -f
'helper/execute_on_all.c' || echo './'`helper/execute_on_all.c
mv -f .deps/execute_on_all.Tpo .deps/execute_on_all.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/execute_on_all
execute_on_all.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/execute_on_all execute_on_all.o /usr/lib/libOpenCL.so.1.0.0
starpu_create_sync_task.o -MD -MP -MF .deps/starpu_create_sync_task.Tpo -c -o
starpu_create_sync_task.o `test -f 'helper/starpu_create_sync_task.c' || echo
'./'`helper/starpu_create_sync_task.c
mv -f .deps/starpu_create_sync_task.Tpo .deps/starpu_create_sync_task.Po
-l:/usr/local/cuda/lib64/libcublas.so -o helper/starpu_create_sync_task
starpu_create_sync_task.o ../src/libstarpu.la -lrt -lpthread
helper/.libs/starpu_create_sync_task starpu_create_sync_task.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT async_tasks_overhead.o
-MD -MP -MF .deps/async_tasks_overhead.Tpo -c -o async_tasks_overhead.o `test
-f 'microbenchs/async_tasks_overhead.c' || echo
'./'`microbenchs/async_tasks_overhead.c
mv -f .deps/async_tasks_overhead.Tpo .deps/async_tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/async_tasks_overhead
async_tasks_overhead.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/async_tasks_overhead async_tasks_overhead.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT sync_tasks_overhead.o
-MD -MP -MF .deps/sync_tasks_overhead.Tpo -c -o sync_tasks_overhead.o `test
-f 'microbenchs/sync_tasks_overhead.c' || echo
'./'`microbenchs/sync_tasks_overhead.c
mv -f .deps/sync_tasks_overhead.Tpo .deps/sync_tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/sync_tasks_overhead
microbenchs/.libs/sync_tasks_overhead sync_tasks_overhead.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tasks_overhead.o -MD
-MP -MF .deps/tasks_overhead.Tpo -c -o tasks_overhead.o `test -f
'microbenchs/tasks_overhead.c' || echo './'`microbenchs/tasks_overhead.c
mv -f .deps/tasks_overhead.Tpo .deps/tasks_overhead.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/tasks_overhead
microbenchs/.libs/tasks_overhead tasks_overhead.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT prefetch_data_on_node.o
-MD -MP -MF .deps/prefetch_data_on_node.Tpo -c -o prefetch_data_on_node.o
`test -f 'microbenchs/prefetch_data_on_node.c' || echo
'./'`microbenchs/prefetch_data_on_node.c
mv -f .deps/prefetch_data_on_node.Tpo .deps/prefetch_data_on_node.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/prefetch_data_on_node
prefetch_data_on_node.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/prefetch_data_on_node prefetch_data_on_node.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT redundant_buffer.o -MD
-MP -MF .deps/redundant_buffer.Tpo -c -o redundant_buffer.o `test -f
'microbenchs/redundant_buffer.c' || echo './'`microbenchs/redundant_buffer.c
mv -f .deps/redundant_buffer.Tpo .deps/redundant_buffer.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/redundant_buffer
redundant_buffer.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/redundant_buffer redundant_buffer.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT local_pingpong.o -MD
-MP -MF .deps/local_pingpong.Tpo -c -o local_pingpong.o `test -f
'microbenchs/local_pingpong.c' || echo './'`microbenchs/local_pingpong.c
mv -f .deps/local_pingpong.Tpo .deps/local_pingpong.Po
-l:/usr/local/cuda/lib64/libcublas.so -o microbenchs/local_pingpong
local_pingpong.o ../src/libstarpu.la -lrt -lpthread
microbenchs/.libs/local_pingpong local_pingpong.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT overlap.o -MD -MP -MF
.deps/overlap.Tpo -c -o overlap.o `test -f 'overlap/overlap.c' || echo
'./'`overlap/overlap.c
mv -f .deps/overlap.Tpo .deps/overlap.Po
-l:/usr/local/cuda/lib64/libcublas.so -o overlap/overlap overlap.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o overlap/.libs/overlap
overlap.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
explicit_combined_worker.o -MD -MP -MF .deps/explicit_combined_worker.Tpo -c
-o explicit_combined_worker.o `test -f
'parallel_tasks/explicit_combined_worker.c' || echo
'./'`parallel_tasks/explicit_combined_worker.c
mv -f .deps/explicit_combined_worker.Tpo .deps/explicit_combined_worker.Po
parallel_tasks/explicit_combined_worker explicit_combined_worker.o
parallel_tasks/.libs/explicit_combined_worker explicit_combined_worker.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT parallel_kernels.o -MD
-MP -MF .deps/parallel_kernels.Tpo -c -o parallel_kernels.o `test -f
'parallel_tasks/parallel_kernels.c' || echo
'./'`parallel_tasks/parallel_kernels.c
mv -f .deps/parallel_kernels.Tpo .deps/parallel_kernels.Po
-l:/usr/local/cuda/lib64/libcublas.so -o parallel_tasks/parallel_kernels
parallel_kernels.o ../src/libstarpu.la -lrt -lpthread
parallel_tasks/.libs/parallel_kernels parallel_kernels.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT parallel_kernels_spmd.o
-MD -MP -MF .deps/parallel_kernels_spmd.Tpo -c -o parallel_kernels_spmd.o
`test -f 'parallel_tasks/parallel_kernels_spmd.c' || echo
'./'`parallel_tasks/parallel_kernels_spmd.c
mv -f .deps/parallel_kernels_spmd.Tpo .deps/parallel_kernels_spmd.Po
-l:/usr/local/cuda/lib64/libcublas.so -o parallel_tasks/parallel_kernels_spmd
parallel_kernels_spmd.o ../src/libstarpu.la -lrt -lpthread
parallel_tasks/.libs/parallel_kernels_spmd parallel_kernels_spmd.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT regression_based.o -MD
-MP -MF .deps/regression_based.Tpo -c -o regression_based.o `test -f
'perfmodels/regression_based.c' || echo './'`perfmodels/regression_based.c
mv -f .deps/regression_based.Tpo .deps/regression_based.Po
-l:/usr/local/cuda/lib64/libcublas.so -o perfmodels/regression_based
regression_based.o ../src/libstarpu.la -lrt -lpthread
perfmodels/.libs/regression_based regression_based.o
non_linear_regression_based.o -MD -MP -MF
.deps/non_linear_regression_based.Tpo -c -o non_linear_regression_based.o
`test -f 'perfmodels/non_linear_regression_based.c' || echo
'./'`perfmodels/non_linear_regression_based.c
mv -f .deps/non_linear_regression_based.Tpo
.deps/non_linear_regression_based.Po
perfmodels/non_linear_regression_based non_linear_regression_based.o
perfmodels/.libs/non_linear_regression_based non_linear_regression_based.o
make[3]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/tests'
Making all in doc
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/doc'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/doc'
Making all in examples
make[1]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make all-recursive
make[2]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
Making all in stencil
`/home/deshpandea/moviSimStarPU/trunk/examples/stencil'
gcc -DHAVE_CONFIG_H -I. -I../../src/common -I../../include
-I../../gcc-plugin/src -I../../include/ -I../../examples/ -I../../include
-D_GNU_SOURCE -I/usr/local/cuda/include -I/usr/include/CL/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT life.o -MD -MP -MF
.deps/life.Tpo -c -o life.o life.c
mv -f .deps/life.Tpo .deps/life.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-kernels.o -MD
-MP -MF .deps/stencil-kernels.Tpo -c -o stencil-kernels.o stencil-kernels.c
mv -f .deps/stencil-kernels.Tpo .deps/stencil-kernels.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-tasks.o -MD -MP
-MF .deps/stencil-tasks.Tpo -c -o stencil-tasks.o stencil-tasks.c
mv -f .deps/stencil-tasks.Tpo .deps/stencil-tasks.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil-blocks.o -MD
-MP -MF .deps/stencil-blocks.Tpo -c -o stencil-blocks.o stencil-blocks.c
mv -f .deps/stencil-blocks.Tpo .deps/stencil-blocks.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT stencil.o -MD -MP -MF
.deps/stencil.Tpo -c -o stencil.o stencil.c
mv -f .deps/stencil.Tpo .deps/stencil.Po
/bin/mkdir -p `dirname life_cuda.o`
/usr/local/cuda/bin/nvcc life_cuda.cu -c -o life_cuda.o --compiler-options
-fno-strict-aliasing -I/usr/local/cuda/include -m64 -I../../include/
-I../../include/
/bin/mkdir -p `dirname shadow.o`
/usr/local/cuda/bin/nvcc shadow.cu -c -o shadow.o --compiler-options
-I../../include/
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT life_opencl.o -MD -MP
-MF .deps/life_opencl.Tpo -c -o life_opencl.o life_opencl.c
mv -f .deps/life_opencl.Tpo .deps/life_opencl.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT shadow_opencl.o -MD -MP
-MF .deps/shadow_opencl.Tpo -c -o shadow_opencl.o shadow_opencl.c
mv -f .deps/shadow_opencl.Tpo .deps/shadow_opencl.Po
/bin/bash ../../libtool --tag=CC --mode=link gcc
-l:/usr/local/cuda/lib64/libcublas.so -o stencil life.o stencil-kernels.o
stencil-tasks.o stencil-blocks.o stencil.o life_cuda.o shadow.o life_opencl.o
shadow_opencl.o ../../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o .libs/stencil life.o
stencil-kernels.o stencil-tasks.o stencil-blocks.o stencil.o life_cuda.o
shadow.o life_opencl.o shadow_opencl.o /usr/lib/libOpenCL.so.1.0.0
-l:/usr/local/cuda/lib64/libcublas.so ../../src/.libs/libstarpu.so -lrt
-lpthread
make[3]: Entering directory `/home/deshpandea/moviSimStarPU/trunk/examples'
-I../include/ -I../examples/ -I../include -D_GNU_SOURCE -Wall
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT hello_world.o -MD -MP
-MF .deps/hello_world.Tpo -c -o hello_world.o `test -f
'basic_examples/hello_world.c' || echo './'`basic_examples/hello_world.c
mv -f .deps/hello_world.Tpo .deps/hello_world.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/hello_world
hello_world.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/hello_world hello_world.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal.o -MD -MP
-MF .deps/vector_scal.Tpo -c -o vector_scal.o `test -f
'basic_examples/vector_scal.c' || echo './'`basic_examples/vector_scal.c
mv -f .deps/vector_scal.Tpo .deps/vector_scal.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal_cpu.o -MD
-MP -MF .deps/vector_scal_cpu.Tpo -c -o vector_scal_cpu.o `test -f
'basic_examples/vector_scal_cpu.c' || echo
'./'`basic_examples/vector_scal_cpu.c
mv -f .deps/vector_scal_cpu.Tpo .deps/vector_scal_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/vector_scal_cuda.cu -c -o
basic_examples/vector_scal_cuda.o -I/usr/local/cuda/include -m64
--compiler-options -fno-strict-aliasing -I../include/ -I../include/
-I../examples/ -arch sm_13
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT vector_scal_opencl.o
-MD -MP -MF .deps/vector_scal_opencl.Tpo -c -o vector_scal_opencl.o `test -f
'basic_examples/vector_scal_opencl.c' || echo
'./'`basic_examples/vector_scal_opencl.c
mv -f .deps/vector_scal_opencl.Tpo .deps/vector_scal_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/vector_scal
vector_scal.o vector_scal_cpu.o basic_examples/vector_scal_cuda.o
vector_scal_opencl.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/vector_scal vector_scal.o vector_scal_cpu.o
basic_examples/vector_scal_cuda.o vector_scal_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mult.o -MD -MP -MF
.deps/mult.Tpo -c -o mult.o `test -f 'basic_examples/mult.c' || echo
'./'`basic_examples/mult.c
mv -f .deps/mult.Tpo .deps/mult.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/mult mult.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o basic_examples/.libs/mult
mult.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart -lcublas
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block.o -MD -MP -MF
.deps/block.Tpo -c -o block.o `test -f 'basic_examples/block.c' || echo
'./'`basic_examples/block.c
mv -f .deps/block.Tpo .deps/block.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block_cpu.o -MD -MP -MF
.deps/block_cpu.Tpo -c -o block_cpu.o `test -f 'basic_examples/block_cpu.c'
|| echo './'`basic_examples/block_cpu.c
mv -f .deps/block_cpu.Tpo .deps/block_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/block_cuda.cu -c -o
basic_examples/block_cuda.o -I/usr/local/cuda/include -m64 --compiler-options
-fno-strict-aliasing -I../include/ -I../include/ -I../examples/ -arch sm_13
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT block_opencl.o -MD -MP
-MF .deps/block_opencl.Tpo -c -o block_opencl.o `test -f
'basic_examples/block_opencl.c' || echo './'`basic_examples/block_opencl.c
mv -f .deps/block_opencl.Tpo .deps/block_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/block block.o
block_cpu.o basic_examples/block_cuda.o block_opencl.o ../src/libstarpu.la
basic_examples/.libs/block block.o block_cpu.o basic_examples/block_cuda.o
block_opencl.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT variable.o -MD -MP -MF
.deps/variable.Tpo -c -o variable.o `test -f 'basic_examples/variable.c' ||
echo './'`basic_examples/variable.c
mv -f .deps/variable.Tpo .deps/variable.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT variable_kernels_cpu.o
-MD -MP -MF .deps/variable_kernels_cpu.Tpo -c -o variable_kernels_cpu.o `test
-f 'basic_examples/variable_kernels_cpu.c' || echo
'./'`basic_examples/variable_kernels_cpu.c
mv -f .deps/variable_kernels_cpu.Tpo .deps/variable_kernels_cpu.Po
/usr/local/cuda/bin/nvcc basic_examples/variable_kernels.cu -c -o
basic_examples/variable_kernels.o -I/usr/local/cuda/include -m64
variable_kernels_opencl.o -MD -MP -MF .deps/variable_kernels_opencl.Tpo -c -o
variable_kernels_opencl.o `test -f 'basic_examples/variable_kernels_opencl.c'
|| echo './'`basic_examples/variable_kernels_opencl.c
mv -f .deps/variable_kernels_opencl.Tpo .deps/variable_kernels_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/variable variable.o
variable_kernels_cpu.o basic_examples/variable_kernels.o
variable_kernels_opencl.o ../src/libstarpu.la -lrt -lpthread
basic_examples/.libs/variable variable.o variable_kernels_cpu.o
basic_examples/variable_kernels.o variable_kernels_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT mult_impl.o -MD -MP -MF
.deps/mult_impl.Tpo -c -o mult_impl.o `test -f 'basic_examples/mult_impl.c'
|| echo './'`basic_examples/mult_impl.c
mv -f .deps/mult_impl.Tpo .deps/mult_impl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/mult_impl mult_impl.o
basic_examples/.libs/mult_impl mult_impl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fvector.o -MD -MP -MF
.deps/fvector.Tpo -c -o fvector.o `test -f 'filters/fvector.c' || echo
'./'`filters/fvector.c
mv -f .deps/fvector.Tpo .deps/fvector.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fvector fvector.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fvector
fvector.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock.o -MD -MP -MF
.deps/fblock.Tpo -c -o fblock.o `test -f 'filters/fblock.c' || echo
'./'`filters/fblock.c
mv -f .deps/fblock.Tpo .deps/fblock.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock_cpu.o -MD -MP
-MF .deps/fblock_cpu.Tpo -c -o fblock_cpu.o `test -f 'filters/fblock_cpu.c'
|| echo './'`filters/fblock_cpu.c
mv -f .deps/fblock_cpu.Tpo .deps/fblock_cpu.Po
/usr/local/cuda/bin/nvcc filters/fblock_cuda.cu -c -o filters/fblock_cuda.o
-I/usr/local/cuda/include -m64 --compiler-options -fno-strict-aliasing
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fblock_opencl.o -MD -MP
-MF .deps/fblock_opencl.Tpo -c -o fblock_opencl.o `test -f
'filters/fblock_opencl.c' || echo './'`filters/fblock_opencl.c
mv -f .deps/fblock_opencl.Tpo .deps/fblock_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fblock fblock.o fblock_cpu.o
filters/fblock_cuda.o fblock_opencl.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fblock
fblock.o fblock_cpu.o filters/fblock_cuda.o fblock_opencl.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT fmatrix.o -MD -MP -MF
.deps/fmatrix.Tpo -c -o fmatrix.o `test -f 'filters/fmatrix.c' || echo
'./'`filters/fmatrix.c
mv -f .deps/fmatrix.Tpo .deps/fmatrix.Po
-l:/usr/local/cuda/lib64/libcublas.so -o filters/fmatrix fmatrix.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o filters/.libs/fmatrix
fmatrix.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example.o -MD -MP
-MF .deps/tag_example.Tpo -c -o tag_example.o `test -f
'tag_example/tag_example.c' || echo './'`tag_example/tag_example.c
mv -f .deps/tag_example.Tpo .deps/tag_example.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example
tag_example.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example tag_example.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example3.o -MD -MP
-MF .deps/tag_example3.Tpo -c -o tag_example3.o `test -f
'tag_example/tag_example3.c' || echo './'`tag_example/tag_example3.c
mv -f .deps/tag_example3.Tpo .deps/tag_example3.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example3
tag_example3.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example3 tag_example3.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_example2.o -MD -MP
-MF .deps/tag_example2.Tpo -c -o tag_example2.o `test -f
'tag_example/tag_example2.c' || echo './'`tag_example/tag_example2.c
mv -f .deps/tag_example2.Tpo .deps/tag_example2.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_example2
tag_example2.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_example2 tag_example2.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT tag_restartable.o -MD
-MP -MF .deps/tag_restartable.Tpo -c -o tag_restartable.o `test -f
'tag_example/tag_restartable.c' || echo './'`tag_example/tag_restartable.c
mv -f .deps/tag_restartable.Tpo .deps/tag_restartable.Po
-l:/usr/local/cuda/lib64/libcublas.so -o tag_example/tag_restartable
tag_restartable.o ../src/libstarpu.la -lrt -lpthread
tag_example/.libs/tag_restartable tag_restartable.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT spmv.o -MD -MP -MF
.deps/spmv.Tpo -c -o spmv.o `test -f 'spmv/spmv.c' || echo './'`spmv/spmv.c
mv -f .deps/spmv.Tpo .deps/spmv.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT spmv_kernels.o -MD -MP
-MF .deps/spmv_kernels.Tpo -c -o spmv_kernels.o `test -f
'spmv/spmv_kernels.c' || echo './'`spmv/spmv_kernels.c
mv -f .deps/spmv_kernels.Tpo .deps/spmv_kernels.Po
/usr/local/cuda/bin/nvcc spmv/spmv_cuda.cu -c -o spmv/spmv_cuda.o
-l:/usr/local/cuda/lib64/libcublas.so -o spmv/spmv spmv.o spmv_kernels.o
spmv/spmv_cuda.o ../src/libstarpu.la -lrt -lpthread
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o spmv/.libs/spmv spmv.o
spmv_kernels.o spmv/spmv_cuda.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT callback.o -MD -MP -MF
.deps/callback.Tpo -c -o callback.o `test -f 'callback/callback.c' || echo
'./'`callback/callback.c
mv -f .deps/callback.Tpo .deps/callback.Po
-l:/usr/local/cuda/lib64/libcublas.so -o callback/callback callback.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o callback/.libs/callback
callback.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT incrementer.o -MD -MP
-MF .deps/incrementer.Tpo -c -o incrementer.o `test -f
'incrementer/incrementer.c' || echo './'`incrementer/incrementer.c
mv -f .deps/incrementer.Tpo .deps/incrementer.Po
/usr/local/cuda/bin/nvcc incrementer/incrementer_kernels.cu -c -o
incrementer/incrementer_kernels.o -I/usr/local/cuda/include -m64
incrementer_kernels_opencl.o -MD -MP -MF .deps/incrementer_kernels_opencl.Tpo
-c -o incrementer_kernels_opencl.o `test -f
'incrementer/incrementer_kernels_opencl.c' || echo
'./'`incrementer/incrementer_kernels_opencl.c
mv -f .deps/incrementer_kernels_opencl.Tpo .deps/incrementer_kernels_opencl.Po
-l:/usr/local/cuda/lib64/libcublas.so -o incrementer/incrementer
incrementer.o incrementer/incrementer_kernels.o incrementer_kernels_opencl.o
incrementer/.libs/incrementer incrementer.o incrementer/incrementer_kernels.o
incrementer_kernels_opencl.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT matvecmult.o -MD -MP
-MF .deps/matvecmult.Tpo -c -o matvecmult.o `test -f
'matvecmult/matvecmult.c' || echo './'`matvecmult/matvecmult.c
mv -f .deps/matvecmult.Tpo .deps/matvecmult.Po
-l:/usr/local/cuda/lib64/libcublas.so -o matvecmult/matvecmult matvecmult.o
matvecmult/.libs/matvecmult matvecmult.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT profiling.o -MD -MP -MF
.deps/profiling.Tpo -c -o profiling.o `test -f 'profiling/profiling.c' ||
echo './'`profiling/profiling.c
mv -f .deps/profiling.Tpo .deps/profiling.Po
-l:/usr/local/cuda/lib64/libcublas.so -o profiling/profiling profiling.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -o profiling/.libs/profiling
profiling.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64 -lcudart
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dummy_sched.o -MD -MP
-MF .deps/dummy_sched.Tpo -c -o dummy_sched.o `test -f
'scheduler/dummy_sched.c' || echo './'`scheduler/dummy_sched.c
mv -f .deps/dummy_sched.Tpo .deps/dummy_sched.Po
-l:/usr/local/cuda/lib64/libcublas.so -o scheduler/dummy_sched dummy_sched.o
scheduler/.libs/dummy_sched dummy_sched.o /usr/lib/libOpenCL.so.1.0.0
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT dot_product.o -MD -MP
-MF .deps/dot_product.Tpo -c -o dot_product.o `test -f
'reductions/dot_product.c' || echo './'`reductions/dot_product.c
mv -f .deps/dot_product.Tpo .deps/dot_product.Po
/usr/local/cuda/bin/nvcc reductions/dot_product_kernels.cu -c -o
reductions/dot_product_kernels.o -I/usr/local/cuda/include -m64
-l:/usr/local/cuda/lib64/libcublas.so -o reductions/dot_product dot_product.o
reductions/dot_product_kernels.o ../src/libstarpu.la -lrt -lpthread
reductions/.libs/dot_product dot_product.o reductions/dot_product_kernels.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT minmax_reduction.o -MD
-MP -MF .deps/minmax_reduction.Tpo -c -o minmax_reduction.o `test -f
'reductions/minmax_reduction.c' || echo './'`reductions/minmax_reduction.c
mv -f .deps/minmax_reduction.Tpo .deps/minmax_reduction.Po
-l:/usr/local/cuda/lib64/libcublas.so -o reductions/minmax_reduction
minmax_reduction.o ../src/libstarpu.la -lrt -lpthread
reductions/.libs/minmax_reduction minmax_reduction.o
-DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -I../include/
mandelbrot_mandelbrot-mandelbrot.o -MD -MP -MF
.deps/mandelbrot_mandelbrot-mandelbrot.Tpo -c -o
mandelbrot_mandelbrot-mandelbrot.o `test -f 'mandelbrot/mandelbrot.c' || echo
'./'`mandelbrot/mandelbrot.c
mv -f .deps/mandelbrot_mandelbrot-mandelbrot.Tpo
.deps/mandelbrot_mandelbrot-mandelbrot.Po
-l:/usr/local/cuda/lib64/libcublas.so -o mandelbrot/mandelbrot
mandelbrot_mandelbrot-mandelbrot.o ../src/libstarpu.la -lrt -lpthread
mandelbrot/.libs/mandelbrot mandelbrot_mandelbrot-mandelbrot.o
-lstdc++ -L/home/deshpandea/moviSimStarPU/trunk/moviSim
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT ppm_downscaler.o -MD
-MP -MF .deps/ppm_downscaler.Tpo -c -o ppm_downscaler.o `test -f
'ppm_downscaler/ppm_downscaler.c' || echo './'`ppm_downscaler/ppm_downscaler.c
mv -f .deps/ppm_downscaler.Tpo .deps/ppm_downscaler.Po
-l:/usr/local/cuda/lib64/libcublas.so -o ppm_downscaler/ppm_downscaler
ppm_downscaler.o ../src/libstarpu.la -lrt -lpthread
ppm_downscaler/.libs/ppm_downscaler ppm_downscaler.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT yuv_downscaler.o -MD
-MP -MF .deps/yuv_downscaler.Tpo -c -o yuv_downscaler.o `test -f
'ppm_downscaler/yuv_downscaler.c' || echo './'`ppm_downscaler/yuv_downscaler.c
mv -f .deps/yuv_downscaler.Tpo .deps/yuv_downscaler.Po
-l:/usr/local/cuda/lib64/libcublas.so -o ppm_downscaler/yuv_downscaler
yuv_downscaler.o ../src/libstarpu.la -lrt -lpthread
ppm_downscaler/.libs/yuv_downscaler yuv_downscaler.o
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT main.o -MD -MP -MF
.deps/main.Tpo -c -o main.o `test -f 'basic_examples/main.c' || echo
'./'`basic_examples/main.c
mv -f .deps/main.Tpo .deps/main.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT pngutils.o -MD -MP -MF
.deps/pngutils.Tpo -c -o pngutils.o `test -f 'basic_examples/pngutils.c' ||
echo './'`basic_examples/pngutils.c
mv -f .deps/pngutils.Tpo .deps/pngutils.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT refocusing_cpu.o -MD
-MP -MF .deps/refocusing_cpu.Tpo -c -o refocusing_cpu.o `test -f
'basic_examples/refocusing_cpu.c' || echo './'`basic_examples/refocusing_cpu.c
mv -f .deps/refocusing_cpu.Tpo .deps/refocusing_cpu.Po
-I/home/deshpandea/zlib-1.2.5/ -O0 -gdwarf-2 -g3 -MT refocusing_starpu.o -MD
-MP -MF .deps/refocusing_starpu.Tpo -c -o refocusing_starpu.o `test -f
'basic_examples/refocusing_starpu.c' || echo
'./'`basic_examples/refocusing_starpu.c
mv -f .deps/refocusing_starpu.Tpo .deps/refocusing_starpu.Po
-l:/usr/local/cuda/lib64/libcublas.so -o basic_examples/refocusing main.o
pngutils.o refocusing_cpu.o refocusing_starpu.o ../src/libstarpu.la -lrt
basic_examples/.libs/refocusing main.o pngutils.o refocusing_cpu.o
refocusing_starpu.o /usr/lib/libOpenCL.so.1.0.0 -L/usr/local/cuda/lib64
make[3]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make[2]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
make[1]: Leaving directory `/home/deshpandea/moviSimStarPU/trunk/examples'
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, Samuel Thibault, 12/11/2011
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, ASUDE ASUDE, 14/11/2011
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, Samuel Thibault, 14/11/2011
