Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: ASUDE ASUDE <ajitsdeshpande@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Linker errors in make while trying to build starpu
- Date: Mon, 14 Nov 2011 15:56:03 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
ASUDE ASUDE, le Mon 14 Nov 2011 14:30:14 +0000, a écrit :
> $ ./configure --with-opencl-include-dir=/usr/include/CL/
> --with-opencl-lib-dir=/home/deshpandea/moviSimStarPU/trunk/moviSim
> CFLAGS=-I/home/deshpandea/lpng155/
> -I/home/deshpandea/moviSimStarPU/trunk/examples/basic_examples/
> -I/home/deshpandea/zlib-1.2.5/
> LIBS=/lib/x86_64-linux-gnu/libpng12.so.0.44.0
> LIBS=/lib/x86_64-linux-gnu/libz.so.1.2.3.4
> LIBS=/home/deshpandea/moviSimStarPU/trunk/moviSim/moviSimDll.so
> LIBS=/usr/lib32/libm.a LDFLAGS=-l:/usr/lib32/libstdc++.so.6.0.14
> LDFLAGS=-l:/usr/local/cuda/lib64/libcudart.so
> LDFLAGS=-l:/usr/local/cuda/lib64/libcublas.so
> LIBS=/usr/lib/libOpenCL.so.1.0.0 --enable-debug --enable-verbose
> --disable-cudamake
You have to define LIBS and LDFLAGS only once, else only the last
definition is kept. Also, avoid mixing both LIBS and LDFLAGS, just use
LIBS:
CFLAGS="-I/home/deshpandea/lpng155/
-I/home/deshpandea/zlib-1.2.5/"
LIBS="/lib/x86_64-linux-gnu/libpng12.so.0.44.0
/home/deshpandea/moviSimStarPU/trunk/moviSim/moviSimDll.so /usr/lib32/libm.a
/usr/lib32/libstdc++.so.6.0.14 /usr/local/cuda/lib64/libcudart.so
/usr/local/cuda/lib64/libcublas.so /usr/lib/libOpenCL.so.1.0.0"
--enable-debug --enable-verbose --disable-cudamake
Samuel
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, Samuel Thibault, 12/11/2011
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, ASUDE ASUDE, 14/11/2011
- Re: [Starpu-devel] Linker errors in make while trying to build starpu, Samuel Thibault, 14/11/2011
