Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Script to run buildbot profiles against your source code
- Date: Mon, 28 Nov 2011 20:32:11 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
All,
You may know that StarPU is using buildbot regularly to test its code against different configuration profiles. A new script has been added, it allows to run the different profiles on a source directory without having to use the buildbot mechanism.
The script is available by checking out the following directory:
svn://scm.gforge.inria.fr/svn/starpu/scripts/buildbot/
It is called mybuild.py, it should be called from the source directory where your StarPU source code is located. The command line arguments are:
--deploy: will run the profiles which call make check (by default, these profiles are not run)
--dry-run: will print the commands instead of executing them
Hoping it is going to be helpful,
Cheers,
Nathalie
- [Starpu-devel] Script to run buildbot profiles against your source code, Nathalie Furmento, 28/11/2011
