Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Error - No worker may execute this task
- Date: Tue, 29 Nov 2011 09:35:58 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thank you Samuel. I will do that. But when I check different devices available to starpu on my setup using starpu_machine_display command, it shows:
StarPU has found :
1 CPU cores
CPU 0
1 CUDA devices
CUDA 0 (GeForce GTX 470)
0 OpenCL devices
Any pointers, why it would show as Zero OpenCL devices, when I have a NVIDIA GPU card GeForce GTX470.
Do we need to do any config. specifically in starpu to enable OpenCL devices?
thank you.
-AD.
On Mon, Nov 28, 2011 at 5:04 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASUDE ASUDE, le Mon 28 Nov 2011 16:48:22 +0000, a écrit :
> But one thing i notice that in my code STARPU initialization function is calledNot a problem, it'd just use the defaults, which is to use all available
> as starpu_init(NULL) , no conf structure there passed
> Do you reckon that could be the culprit?
resources that starpu_machine_display shows you.
You should probably post your source code, so we can check whether
something else lies in it.
Samuel
- [Starpu-devel] Error - No worker may execute this task, ASUDE ASUDE, 28/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, Nathalie Furmento, 28/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, ASUDE ASUDE, 28/11/2011
- Message indisponible
- Re: [Starpu-devel] Error - No worker may execute this task, Samuel Thibault, 28/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, ASUDE ASUDE, 29/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, Samuel Thibault, 29/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, Nathalie Furmento, 29/11/2011
- Re: [Starpu-devel] Error - No worker may execute this task, Sylvain HENRY, 29/11/2011
