Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error - No worker may execute this task
Veuillez patienter...
starpu-devel@inria.fr
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: ASUDE ASUDE <ajitsdeshpande@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error - No worker may execute this task
  • Date: Tue, 29 Nov 2011 11:00:19 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
ASUDE ASUDE, le Tue 29 Nov 2011 09:35:58 +0000, a écrit :
> Thank you Samuel. I will do that. But when I check different devices
> available
> to starpu on my setup using starpu_machine_display command, it  shows:
> StarPU has found :
>         1 CPU cores
>                 CPU 0
>         1 CUDA devices
>                 CUDA 0 (GeForce GTX 470)
>         0 OpenCL devices
> Any pointers, why it would show as Zero OpenCL devices, when I have a NVIDIA
> GPU card GeForce GTX470.
It seems you are still using a version of StarPU with CUDA support, and
STARPU_NCUDA not being set to 0.
>  Do we need to do any config. specifically in starpu to enable OpenCL
> devices?
It is as we have said previously: either --disable-cuda on ./configure,
or export STARPU_NCUDA=0. The output above comes from an environment
where none of them was done.
Samuel
Haut de le page
