Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Starpu-commits] [Review needed] Move $HOME/.starpu/sampling to $XDG_CACHE_HOME/starpu/sampling
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Ludovic Courtès <ludovic.courtes@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Starpu-commits] [Review needed] Move $HOME/.starpu/sampling to $XDG_CACHE_HOME/starpu/sampling
  • Date: Tue, 13 Dec 2011 17:02:49 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
What about the recent commit which integrates STARPU_HOME? Could that variable be used instead of XDG_CACHE_HOME ?
Cheers,
Nathalie
On 13/12/2011 15:46, Ludovic Courtès wrote:
Hello!
(Moving to starpu-devel.)
Cyril Roelandt<cyril.roelandt@inria.fr> skribis:
As Ludovic Courtes pointed out, the StarPU samplings should probably
be stored in $XDG_CACHE_HOME/starpu/sampling rather than in
$HOME/.starpu/sampling.
Some of our users are probably used to having these files in
$HOME/.starpu/sampling though, so it would be nice if nothing was to
change for them.
The following patch makes sure we store our perfmodels in
$XDG_CACHE_HOME or $HOME/.cache if $HOME/.starpu/sampling does not
exist :
Nice!
--- src/core/perfmodel/perfmodel.c (revision 4847)
+++ src/core/perfmodel/perfmodel.c (working copy)
@@ -335,9 +335,27 @@
const char *home_path = getenv("HOME");
if (!home_path)
home_path = getenv("USERPROFILE");
- if (!home_path)
+ if (home_path)
+ snprintf(path, maxlen, "%s/.starpu/sampling/", home_path);
+ int ret;
+ struct stat dummy;
+ /* It already exists, let's use it */
+ ret = stat(path,&dummy);
+ if (ret == 0)
+ return;
+ /* $HOME/.starpu/sampling/ does not exist, let's try other
locations */
+ char *xdg_cache_home = getenv("XDG_CACHE_HOME");
+ if (xdg_cache_home)
+ snprintf(path, maxlen, "%s/starpu/sampling/",
xdg_cache_home);
+ else if (home_path)
+ snprintf(path, maxlen, "%s/.cache/starpu/sampling/",
home_path);
+ else
_STARPU_ERROR("couldn't find a home place to put
starpu data\n");
- snprintf(path, maxlen, "%s/.starpu/sampling/", home_path);
#endif
Looks good to me!
Could you update the manual while you’re at it? :-)
Brice Goglin also suggested that if neither $XDG_CACHE_HOME or $HOME
were set, we should probably use $STARPU_PREFIX/share. I'm not sure we
define STARPU_PREFIX though.
I don’t think it’s necessary, especially since $prefix is likely to be
read-only.
Thanks,
Ludo’.
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
