Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers.
  • Date: Wed, 18 Jan 2012 19:01:43 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
In src/core/dependencies/implicit_data_deps.c lies the following code :
unsigned nreaders = 0;
while (l)
if (l->task != post_sync_task)
nreaders++;
l = l->next;
struct starpu_task *task_array[nreaders];
We probably do not want to write this last line if nreaders is 0, since variable length arrays must have a size greater than 0. So we could just write this instead :
struct starpu_task *task_array[nreaders+1];
That would be a little hacky, but still acceptable. The thing is, later, we call starpu_task_declare_deps_array :
starpu_task_declare_deps_array(pre_sync_task, nreaders, task_array);
which immediatly returns if nreaders is equal to 0.
The following patch makes sure that task_array is only declared if nreaders is greater than 0 (thus removing the need to allocate an array of size nreaders+1) and that starpu_task_declare_deps_array is only called if nreaders is greater than 0 (which may be a good thing for the execution speed).
Index: src/core/dependencies/implicit_data_deps.c
--- src/core/dependencies/implicit_data_deps.c (revision 5186)
+++ src/core/dependencies/implicit_data_deps.c (working copy)
@@ -80,21 +80,25 @@
_STARPU_DEP_DEBUG("%d readers\n", nreaders);
- /* Put all tasks in the list into task_array */
- struct starpu_task *task_array[nreaders];
- unsigned i = 0;
- l = handle->last_submitted_readers;
- while (l)
+ if (nreaders > 0)
- STARPU_ASSERT(l->task);
- if (l->task != post_sync_task) {
- task_array[i++] = l->task;
- _STARPU_DEP_DEBUG("dep %p -> %p\n", l->task, pre_sync_task);
+ /* Put all tasks in the list into task_array */
+ struct starpu_task *task_array[nreaders];
+ unsigned i = 0;
+ l = handle->last_submitted_readers;
+ while (l)
+ STARPU_ASSERT(l->task);
+ if (l->task != post_sync_task) {
+ task_array[i++] = l->task;
+ _STARPU_DEP_DEBUG("dep %p -> %p\n", l->task, pre_sync_task);
+ struct _starpu_task_wrapper_list *prev = l;
+ l = l->next;
+ free(prev);
- struct _starpu_task_wrapper_list *prev = l;
- l = l->next;
- free(prev);
+ starpu_task_declare_deps_array(pre_sync_task, nreaders, task_array);
#ifndef STARPU_USE_FXT
if (_starpu_bound_recording)
@@ -121,7 +125,6 @@
handle->last_submitted_readers = NULL;
handle->last_submitted_writer = post_sync_task;
- starpu_task_declare_deps_array(pre_sync_task, nreaders, task_array);
/* Write after Write (WAW) */
static void _starpu_add_writer_after_writer(starpu_data_handle_t handle, struct starpu_task *pre_sync_task, struct starpu_task *post_sync_task)
make check is happy with that, but I am not sure it does the exact same thing as the original code. My main concern is about pre_sync_task, which will be used by starpu_task_declare_deps_array() before being used when declaring dependencies with ghost readers. Is that a problem ? Is the code still as easy to understand as before ?
Cyril.
  • [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers., Cyril Roelandt, 18/01/2012
Haut de le page
