Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers.
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Cyril Roelandt <cyril.roelandt@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers.
  • Date: Wed, 18 Jan 2012 19:09:19 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Cyril Roelandt, le Wed 18 Jan 2012 18:56:34 +0100, a écrit :
> make check is happy with that, but I am not sure it does the exact same
> thing as the original code. My main concern is about pre_sync_task, which
> will be used by starpu_task_declare_deps_array() before being used when
> declaring dependencies with ghost readers. Is that a problem ?
It's not a problem, the use is simply for trace records.
> Is the code still as easy to understand as before ?
It's fine.
Samuel
  • Re: [Starpu-devel] [Review needed] nreaders might be 0 in _starpu_add_writer_after_readers., Samuel Thibault, 18/01/2012
Haut de le page
