Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [patch request] Double comparison
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [patch request] Double comparison
  • Date: Mon, 30 Jan 2012 14:18:09 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On Jan 30, 13:37, Samuel Thibault wrote:
> Nathalie Furmento, le Mon 30 Jan 2012 13:25:52 +0100, a écrit :
> > +int _starpu_approximately_equal(double a, double b)
> > + int ai = (int) nearbyint(a * 1000.0);
> > + int bi = (int) nearbyint(b * 1000.0);
> > + return ai == bi;
> Maybe make 1000 a parameter.
The function is actually no longer needed as it was only used to test against
the value -1.0
> > - if (exp == -1.0 && !model->benchmarking)
> > + if (_starpu_approximately_equal(exp, -1.0) && !model->benchmarking)
> Mmm, no, such kind of comparisons are supposed to be exact: we really
> put exactly there -1.0 as a markup. Using such a long function name
> makes the code way less readable. At best we could introduce
> _starpu_is_nan, and use nan instead of -1 as marker.
> Same for all other occurrences.
Can we directly use isnan() defined in <math.h> ?
I tried to replace all the related occurences of -1.0 by nan. You
should check if i forgot something.
> > enum starpu_perf_archtype arch =
> > starpu_worker_get_perf_archtype(w);
> > - if (t1->duration[arch] == 0.)
> > + if (fpclassify(t1->duration[arch]) == FP_ZERO)
> I'd say introduce _starpu_is_zero.
Done.
Nathalie
Index: src/common/utils.c
--- src/common/utils.c (revision 5389)
+++ src/common/utils.c (working copy)
@@ -1,7 +1,7 @@
/* StarPU --- Runtime system for heterogeneous multicore architectures.
* Copyright (C) 2010, 2012 Université de Bordeaux 1
- * Copyright (C) 2010, 2011 Centre National de la Recherche Scientifique
+ * Copyright (C) 2010, 2011, 2012 Centre National de la Recherche
Scientifique
* StarPU is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published
by
@@ -20,6 +20,7 @@
#include <common/utils.h>
#include <libgen.h>
#include <errno.h>
+#include <math.h>
#ifdef __MINGW32__
#include <io.h>
@@ -92,3 +93,10 @@
return 1;
+ return ai == bi;
Index: src/common/utils.h
--- src/common/utils.h (revision 5389)
+++ src/common/utils.h (working copy)
@@ -1,7 +1,7 @@
* Copyright (C) 2010 Université de Bordeaux 1
Scientifique
by
@@ -50,6 +50,10 @@
} while (0)
+int _starpu_approximately_equal(double a, double b);
+#define _STARPU_IS_ZERO(a) (fpclassify(a) == FP_ZERO)
int _starpu_mkpath(const char *s, mode_t mode);
int _starpu_check_mutex_deadlock(pthread_mutex_t *mutex);
Index: src/core/task.c
--- src/core/task.c (revision 5389)
+++ src/core/task.c (working copy)
@@ -74,8 +74,8 @@
task->profiling_info = NULL;
- task->predicted = -1.0;
- task->predicted_transfer = -1.0;
+ task->predicted = nan;
+ task->predicted_transfer = nan;
task->starpu_private = NULL;
task->magic = 42;
Index: src/core/perfmodel/perfmodel_history.c
--- src/core/perfmodel/perfmodel_history.c (revision 5389)
+++ src/core/perfmodel/perfmodel_history.c (working copy)
@@ -21,6 +21,7 @@
#include <sys/stat.h>
#include <errno.h>
#include <common/config.h>
+#include <common/utils.h>
#include <core/perfmodel/perfmodel.h>
#include <core/jobs.h>
#include <core/workers.h>
@@ -889,7 +890,7 @@
double _starpu_regression_based_job_expected_perf(struct starpu_perfmodel
*model, enum starpu_perf_archtype arch, struct _starpu_job *j, unsigned nimpl)
- double exp = -1.0;
+ double exp = NAN;
size_t size = _starpu_job_get_data_size(model, arch, nimpl, j);
struct starpu_regression_model *regmodel;
@@ -903,7 +904,7 @@
double _starpu_non_linear_regression_based_job_expected_perf(struct
starpu_perfmodel *model, enum starpu_perf_archtype arch, struct _starpu_job
*j,unsigned nimpl)
+ double exp = NAN;
@@ -948,21 +949,21 @@
history = per_arch_model->history;
if (!history)
- return -1.0;
+ return NAN;
_STARPU_PTHREAD_RWLOCK_RDLOCK(&model->model_rwlock);
entry = (struct starpu_history_entry *)
_starpu_htbl_search_32(history, key);
_STARPU_PTHREAD_RWLOCK_UNLOCK(&model->model_rwlock);
- exp = entry?entry->mean:-1.0;
+ exp = entry?entry->mean:NAN;
if (entry && entry->nsample < _STARPU_CALIBRATION_MINIMUM)
/* TODO: report differently if we've scheduled really enough
* of that task and the scheduler should perhaps put it aside
/* Not calibrated enough */
- exp = -1.0;
+ exp = NAN;
+ if (isnan(exp) && !model->benchmarking)
_STARPU_DISP("Warning: model %s is not calibrated enough,
forcing calibration for this run. Use the STARPU_CALIBRATE environment
variable to control this.\n", model->symbol);
_starpu_set_calibrate_flag(1);
Index: src/core/perfmodel/perfmodel.c
--- src/core/perfmodel/perfmodel.c (revision 5389)
+++ src/core/perfmodel/perfmodel.c (working copy)
@@ -70,7 +70,7 @@
static double per_arch_task_expected_perf(struct starpu_perfmodel *model,
enum starpu_perf_archtype arch, struct starpu_task *task, unsigned nimpl)
+ double exp = nan;
double (*per_arch_cost_function)(struct starpu_task *task, enum
starpu_perf_archtype arch, unsigned nimpl);
double (*per_arch_cost_model)(struct starpu_buffer_descr *);
@@ -112,7 +112,7 @@
STARPU_ABORT();
/* Never reached ! */
- return -1.0;
+ return nan;
static double common_task_expected_perf(struct starpu_perfmodel *model, enum
@@ -125,7 +125,7 @@
exp = model->cost_function(task, nimpl);
alpha = starpu_worker_get_relative_speedup(arch);
- STARPU_ASSERT(alpha != 0.0f);
+ STARPU_ASSERT(!_STARPU_IS_ZERO(alpha));
return (exp/alpha);
@@ -134,12 +134,12 @@
exp = model->cost_model(task->buffers);
return (exp/alpha);
- return -1.0;
+ return nan;
void _starpu_load_perfmodel(struct starpu_perfmodel *model)
Index: src/profiling/bound.c
--- src/profiling/bound.c (revision 5389)
+++ src/profiling/bound.c (working copy)
@@ -1,6 +1,6 @@
Scientifique
* Copyright (C) 2010, 2011 Université de Bordeaux 1
* Copyright (C) 2011 Télécom-SudParis
@@ -353,8 +353,8 @@
double length =
_starpu_history_based_job_expected_perf(tp->cl->model, arch, &j, j.nimpl);
- if (length == -1.0)
- times[w*nt+t] = -1.0;
+ if (isnan(length))
+ times[w*nt+t] = nan;
else
times[w*nt+t] = length / 1000.;
@@ -429,12 +429,12 @@
for (w = 0; w < nw; w++)
+ if (_STARPU_IS_ZERO(t1->duration[arch]))
double length =
_starpu_history_based_job_expected_perf(t1->cl->model, arch, &j,j.nimpl);
/* Avoid problems with binary
coding of doubles */
- t1->duration[arch] = -1.0;
+ t1->duration[arch] = nan;
else
t1->duration[arch] = length /
1000.;
@@ -456,7 +456,7 @@
- if (t1->duration[arch] != -1.0)
+ if (!isnan(t1->duration[arch]))
fprintf(output, " +t%luw%d", t1->id,
w);
fprintf(output, " = 1;\n");
@@ -470,7 +470,7 @@
fprintf(output, " + %f t%luw%d",
t1->duration[arch], t1->id, w);
fprintf(output, ";\n");
@@ -506,7 +506,7 @@
arch = starpu_worker_get_perf_archtype(w);
-1.0)
+ if
fprintf(output, "s%lu
- c%lu >= -3e5 + 1e5 t%luw%d + 1e5 t%luw%d + 1e5 t%luafter%lu;\n",
t1->id, t2->id, t1->id, w, t2->id, w, t1->id, t2->id);
@@ -651,7 +651,7 @@
fprintf(output, "/* worker %s */\n0", name);
for (t = 0, tp = task_pools; tp; t++, tp =
tp->next)
- if (times[w*nt+t] != -1.0)
+ if (!isnan(times[w*nt+t]))
fprintf(output, "\t%+f *
w%dt%dn", (float) times[w*nt+t], w, t);
fprintf(output, " <= tmax;\n");
@@ -663,7 +663,7 @@
fprintf(output, "/* task %s key %x */\n0",
tp->cl->name, (unsigned) tp->footprint);
fprintf(output, "\t+w%dt%dn",
w, t);
fprintf(output, " = %lu;\n", tp->n);
/* Show actual values */
@@ -747,7 +747,7 @@
fprintf(output, "\n* Execution times and completion of all
tasks\n");
for (t = 0, tp = task_pools; tp; t++, tp = tp->next)
char name[9];
snprintf(name, sizeof(name),
"W%dT%d", w, t);
@@ -830,7 +830,7 @@
int someone = 0;
- if (times[w*nt+t] != -1.)
someone = 1;
if (!someone)
@@ -849,7 +849,7 @@
ia[n] = w+1;
ja[n] = colnum(w, t);
- if (times[w*nt+t] == -1.)
+ if (isnan(times[w*nt+t]))
ar[n] = 1000000000.;
else
ar[n] = times[w*nt+t];
Index: src/datawizard/coherency.c
--- src/datawizard/coherency.c (revision 5389)
+++ src/datawizard/coherency.c (working copy)
@@ -1,7 +1,7 @@
* Copyright (C) 2009-2011 Université de Bordeaux 1
Scientifique
by
@@ -67,7 +67,7 @@
if (!link_supports_direct_transfers(handle,
i, destination, &handling_node))
continue;
- if (time == 0.0)
+ if (_STARPU_IS_ZERO(time))
/* No estimation, will have to revert
to dumb strategy */
cost = 0.0;
Index: src/sched_policies/parallel_heft.c
--- src/sched_policies/parallel_heft.c (revision 5389)
+++ src/sched_policies/parallel_heft.c (working copy)
@@ -262,16 +262,16 @@
double ntasks_end = compute_ntasks_end(worker);
if (ntasks_best == -1
- || (!calibrating && ntasks_end <
ntasks_best_end) /* Not calibrating, take better task */
local_task_length[worker][nimpl] == -1.0) /* Not calibrating but this worker
is being calibrated */
- || (calibrating &&
local_task_length[worker][nimpl] == -1.0 && ntasks_end < ntasks_best_end) /*
Calibrating, compete this worker with other non-calibrated */
+ || (!calibrating && ntasks_end < ntasks_best_end)
isnan(local_task_length[worker][nimpl])) /* Not calibrating but this worker
+ || (calibrating &&
isnan(local_task_length[worker][nimpl]) && ntasks_end < ntasks_best_end) /*
ntasks_best_end = ntasks_end;
ntasks_best = worker;
- if (local_task_length[worker][nimpl] == -1.0)
+ if (isnan(local_task_length[worker][nimpl]))
/* we are calibrating, we want to speed-up
calibration time
* so we privilege non-calibrated tasks (but
still
* greedily distribute them to avoid dumb
schedules) */
@@ -300,7 +300,7 @@
local_power[worker][nimpl] =
starpu_task_expected_power(task, perf_arch,nimpl);
//_STARPU_DEBUG("Scheduler parallel heft: task length
(%lf) local power (%lf) worker (%u) kernel (%u) \n",
local_task_length[worker][nimpl],local_power[worker][nimpl],worker,nimpl);
- if (local_power[worker][nimpl] == -1.0)
+ if (isnan(local_power[worker][nimpl]))
local_power[worker][nimpl] = 0.;
} //end for
Index: src/sched_policies/deque_modeling_policy_data_aware.c
--- src/sched_policies/deque_modeling_policy_data_aware.c (revision
5389)
+++ src/sched_policies/deque_modeling_policy_data_aware.c (working copy)
@@ -1,7 +1,7 @@
* Copyright (C) 2010, 2011-2012 Université de Bordeaux 1
Scientifique
@@ -344,17 +344,17 @@
//_STARPU_DEBUG("Scheduler dm: task length (%lf)
worker (%u) kernel (%u) \n", local_length,worker,nimpl);
- || (!calibrating && local_length ==
-1.0) /* Not calibrating but this worker is being calibrated */
- || (calibrating && local_length ==
-1.0 && ntasks_end < ntasks_best_end) /* Calibrating, compete this worker
+ || (!calibrating && isnan(local_length)) /* Not
+ || (calibrating && isnan(local_length) &&
ntasks_end < ntasks_best_end) /* Calibrating, compete this worker with other
non-calibrated */
best_impl = nimpl;
- if (local_length == -1.0)
+ if (isnan(local_length))
calibration time
still
schedules) */
@@ -457,17 +457,17 @@
double ntasks_end = fifo->ntasks /
starpu_worker_get_relative_speedup(perf_arch);
best_impl = nimpl;
calibration time
still
schedules) */
@@ -491,7 +491,7 @@
starpu_task_expected_power(task, perf_arch, nimpl);
Index: src/sched_policies/heft.c
--- src/sched_policies/heft.c (revision 5389)
+++ src/sched_policies/heft.c (working copy)
@@ -139,7 +139,7 @@
exp_end[workerid] = exp_start[workerid] + exp_len[workerid];
/* If there is no prediction available, we consider the task has a
null length */
- if (predicted != -1.0)
+ if (!isnan(predicted))
task->predicted = predicted;
exp_end[workerid] += predicted;
@@ -147,7 +147,7 @@
null length */
- if (predicted_transfer != -1.0)
+ if (!isnan(predicted_transfer))
if (starpu_timing_now() + predicted_transfer <
exp_end[workerid])
@@ -289,9 +289,9 @@
double ntasks_end = ntasks[worker] /
@@ -299,7 +299,7 @@
nimpl_best = nimpl;
calibration time
still
schedules) */
@@ -322,7 +322,7 @@
nimpl_best = nimpl;
Haut de le page
