Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Stojce Nakov <stojce.nakov@inria.fr>
- Cc: Emmanuel Agullo <emmanuel.agullo@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [StarPU] Data prefetch.
- Date: Wed, 29 Feb 2012 15:59:40 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Stojce,
The g++ problem has been identified, and can easily be reproduced. We are currently working on it.
Thanks for reporting it,
Cheers,
Nathalie
On 29/02/2012 14:43, Stojce Nakov wrote:
I'm using the machin mirgage on plafrim.
Stojce
----- Original Message -----
From: "Nathalie Furmento"<nathalie.furmento@labri.fr>
To: "Stojce Nakov"<stojce.nakov@inria.fr>
Cc: starpu-devel@lists.gforge.inria.fr
Sent: Wednesday, February 29, 2012 2:36:28 PM
Stojce,
Could you please tell us on which machin you tried to compile, and
send
us your config.log file.
Thanks,
Nathalie
On 29/02/2012 14:30, Stojce Nakov wrote:
Hi,
I've tested with the last version from the svn and the problem is
still here.
Also i had some problem with the compilation of starPU. When the
file
examples/cpp/incrementer_cpp.cpp is compiled, he can not find CUDA.
I've seen that there is a
Warning that it needs to be fixed, but i could not even compîle
StarPU.
Stojce
From: "Ludovic Courtès"<ludovic.courtes@inria.fr>_______________________________________________
To: "Cyril Roelandt"<cyril.roelandt@inria.fr>
Cc: "stojce nakov"<stojce.nakov@inria.fr>,
Sent: Tuesday, February 28, 2012 2:12:17 PM
Hi,
Cyril Roelandt<cyril.roelandt@inria.fr> skribis:
About a month ago, you reported an issue related to dataAlternatively, you can use a tarball from
prefetching
in StarPU. Can you confirm your bug still appears in the latest
revision of StarPU ? You can get it by running :
$ svn checkout svn://scm.gforge.inria.fr/svn/starpu
<http://hydra.bordeaux.inria.fr/job/runtime/starpu-trunk/tarball/latest/download-by-type/file/source-dist>,
which saves you from the need to have up-to-date maintenance tools
(Autotools& co.)
Thanks,
Ludo’.
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] [StarPU] Data prefetch., Cyril Roelandt, 28/02/2012
- Re: [Starpu-devel] [StarPU] Data prefetch., Ludovic Courtès, 28/02/2012
- Re: [Starpu-devel] [StarPU] Data prefetch., Stojce Nakov, 29/02/2012
- Re: [Starpu-devel] [StarPU] Data prefetch., Nathalie Furmento, 29/02/2012
- Re: [Starpu-devel] [StarPU] Data prefetch., Cyril Roelandt, 29/02/2012
